Old 04-08-2011, 08:09 AM   #26
bigsnookmaster
bigsnookmaster's Avatar
Re: Post Your Engine Bay Pics!!!!!!
My 68:
bigsnookmaster is offline   Reply With Quote
Old 04-08-2011, 08:31 AM   #27
67_ShortFleet
67_ShortFleet's Avatar
Originally Posted by bigsnookmaster View Post
My 68:
Where did you buy the brake booster?
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 04-08-2011, 08:40 AM   #28
bigsnookmaster
I bought the brake booster from Master Power Brakes, I think. I had to make the mountong bracket myself out of a piece of 2x3 tubing that I split and machined. The original "bolt in" bracket that came with it, put the booster up at an angle, and it hit the drivers side hood brace. I like the level look of it now.
Old 04-08-2011, 09:34 AM   #29
roadracer9
Retired from a track near you!
roadracer9's Avatar
My 68:
Dat's nice, reeeeal nice!
roadracer9 is offline   Reply With Quote
Old 04-08-2011, 10:30 AM   #30
68Stepbed
68Stepbed's Avatar
I'll get in on this.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-08-2011, 02:14 PM   #31
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Nice lookin bays you'se guys!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-08-2011, 02:55 PM   #32
allengator
allengator's Avatar
Gary
no kidding... makes me want to go work on my truck!!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 04-08-2011, 04:24 PM   #33
68jewel
On the path to financial ruin!
68jewel's Avatar
Originally Posted by 67C10BUB View Post
Here's mine, just in case anyone likes to see the fuel injected ones.
I sure do!!
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
68jewel is offline   Reply With Quote
Old 04-08-2011, 04:29 PM   #34
Tmwoodall
So I always see the concerns about rubber hoses. Is this in regards to making the full run out of rubber, or at all? I have steel from the tank just down a bit into the frame rail so that it has some flex, same for the front. Steel all the way up to the pump, and a steel line from the outlet up to the carb in which there is another small section of rubber.
Ok or no?
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 04-08-2011, 04:29 PM   #35
Classic69
Love That '69
Classic69's Avatar
Originally Posted by allengator View Post
No kidding...makes me want to go work on my truck!!
X2!!
I AM CANADIAN!!!!!
1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights
2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates
Classic69 is offline   Reply With Quote
Old 04-08-2011, 04:48 PM   #36
68Stepbed
68Stepbed's Avatar
Ok or no?
A little bit(about 2-3") is ok just to use to make connections. It's not a good idea to use it for the entire line. The modern fuels with ethanol can eat through rubber pretty quick. Alot of new rubber lines are impregnated with silicone to keep this from happening as fast, but will still eat through over time.
Matt
Old 04-08-2011, 04:49 PM   #37
Tmwoodall
Hmmm I probably have a ~6" run on the back and a shorter 2-4" run upfront.
Old 04-08-2011, 05:28 PM   #38
68Stepbed
68Stepbed's Avatar
I wouldn't fret it too much, then. Just keep a close eye on that rear section every so often.
Matt
Old 04-08-2011, 08:36 PM   #39
dandansuperman
dandansuperman's Avatar
I am super impressed with how much work went into some of these engines bays. I want to keep the heater and A/C, but hide as much of it as possible. This has some great ideas.
dandansuperman is offline   Reply With Quote
Old 04-08-2011, 08:51 PM   #40
oldman3
oldman3's Avatar
These aren't the best pictures, but are of a friends truck that I did a few years ago, cost was important so most of the stuff was painted and detailed.
oldman3 is offline   Reply With Quote
Old 04-08-2011, 11:07 PM   #41
Hubscrub
Cruzin
Hubscrub's Avatar
i agree i use as much metal as i can thats one good thing about Q-jets no need for rubber lines fuel filter is built in. I've had rubber lines let go and gas go everywhere on the engine lucky it didn't go whooof. I have seen many a cars burn to the ground (for various reasons) when i was in the fire dept. believe me a couple min. is all you got most of the time/ i keep a extinguisher in all my cars/trucks. Also nice engine bays guys sharp!
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 07-26-2011, 08:23 PM   #42
jondancer
Ttt
jondancer is offline   Reply With Quote
Old 07-26-2011, 08:41 PM   #43
bruin_d
bruin_d's Avatar
Almost finished.
bruin_d is offline   Reply With Quote
Old 07-26-2011, 08:46 PM   #44
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Just FYI the Batwing Caddy Air cleaners are being repopped.I'm not sure where to get one but I have seen them at swap meets and somewhere in a mag.Maybe one of the "Old School" type mags.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-26-2011, 09:48 PM   #45
Red68
Red68's Avatar
Heres my 69 327
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 07-26-2011, 09:56 PM   #46
cjohnson6772
cjohnson6772's Avatar
Originally Posted by Red68 View Post
Heres my 69 327
Info on the dipstick please
cjohnson6772 is offline   Reply With Quote
Old 07-26-2011, 10:02 PM   #47
mrhino
sorry no bling!
mrhino is offline   Reply With Quote
Old 07-26-2011, 10:05 PM   #48
Fldawg
Fldawg's Avatar
Jeeze Louise... relax on your "the truck will burn to the ground comment". He has braided fuel line. Perfectly acceptable. Even the NHRA allows braided fuel line...
Here is the SBC in my 1972 GMC 1500 Super Custom.
Gary
I agree totally i've ran rubber fuel line on everything i have, i hav'nt had the the first fire, of course anybody that loses a truck to a hurricane it ain't like a hurricane sneeks up on ya you have a few days to get ready. what are the odds of a hurricane claiming a truck over a rubber fuel line, by the way here is my pics with those dreaded rubber fuel lines
Fldawg is offline   Reply With Quote
Old 07-26-2011, 10:32 PM   #49
Red68
Red68's Avatar
I purchased it from LMC truck I think. It is a billet alm. With a Crome tube.
Old 07-27-2011, 12:29 AM   #50
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Mine all new and shiny with rattlecan restorations (should make that a shop door logo lol)
Now its leaked gas oil and its not that pretty (DD) with 5kmiles at least already
One of these days i'll pull it and re seal gasket the whole thing repaint etc (1st motor I learned as I went on). I did learn alot though
John
1999 Toyota Tacoma 4x4
