Old 05-15-2011, 10:43 AM   #26
Kim57
Kim57's Avatar
Re: My 58 Fleetside
Green 1959
Here are a couple of picks of my support.
It's just made of 2x4s with spacers in the middle so it is slightly wider than the boom on my hoist. The part that attaches it is a metal construction "T" strap.
Kim
Kim57 is offline   Reply With Quote
Old 05-16-2011, 10:22 AM   #27
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
I'll have to try to make one of those
I pity the fool with only 2 headlights!
Green 1959 is offline   Reply With Quote
Old 05-17-2011, 12:39 PM   #28
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
I have a question on the powertrain. I have a 1/2 ton with 4.11 rear and set up for a turbo 350. There is a place locally that can convert to 3.38 ratio, I was thinking about maybe using a 700r4 trans, is this setup going to be overkill for something that I want to daily drive and that is freeway friendly? Im hoping to get the best fuel mileage possible with a 250 l6
Old 05-17-2011, 10:53 PM   #29
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Its primer now. Dont be hating on how spacious my HUGE garage is.
Old 05-17-2011, 10:56 PM   #30
longbike
longbike's Avatar
Re: My 58 Fleetside
Your cab looks to be in great shape! 4 eyes!!!
longbike is offline   Reply With Quote
Old 05-17-2011, 10:56 PM   #31
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
And booooom it has the charcoal part painted!
Old 05-17-2011, 11:27 PM   #32
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: My 58 Fleetside
Looks like you've been busy, keep up the good work.
Kabwe is offline   Reply With Quote
Old 05-21-2011, 11:49 PM   #33
zellway
zellway's Avatar
Re: My 58 Fleetside
what no update with the green!
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 05-21-2011, 11:57 PM   #34
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Now GreeN!!!!!
Old 05-22-2011, 12:16 AM   #35
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
I'm waiting for a repair panel for the radio before I paint the bottom on the dash, I'm going to get a USB deck that fits in the factory location. Should be good stuff.
Old 05-22-2011, 12:24 AM   #36
Kim57
Kim57's Avatar
Re: My 58 Fleetside
Looking good.
Kim
Old 05-22-2011, 12:34 AM   #37
dicer
Re: My 58 Fleetside
Whats the post for in the cab? Looks good. You have tons more garage space than me.
dicer is offline   Reply With Quote
Old 05-22-2011, 11:01 AM   #38
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Tons???? I had a load lock in the for stabilizing the roof while I welded some holes that were drilled in it and did the body work
Old 07-11-2011, 06:33 PM   #39
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Here are the picts of the dash panel and dash before I started, and the dash cut out for the fitting
Old 07-11-2011, 08:00 PM   #40
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
The frame is now at the house
Old 07-11-2011, 08:04 PM   #41
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
This is the old wagon wheel rims and low pro tires. Now with taller tires on ralley rims. Looking for a taller tire though, what do you think?
Old 07-11-2011, 08:09 PM   #42
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Last shot of the frame with the cab on and BAM there it is
Old 07-11-2011, 09:27 PM   #43
longbike
longbike's Avatar
Re: My 58 Fleetside
Looking great, I like the rallies with taller tires.
Dude where did all your grass go??? At least you have the perfect weather for working outside. "No rain"
Old 07-11-2011, 11:46 PM   #44
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
No grass here, and its been too hot to work after 10 in the morning. The days we drug the frame here it was 118!!!
Old 07-12-2011, 12:30 AM   #45
Kim57
Kim57's Avatar
Re: My 58 Fleetside
I love the truck rallies.
Kim
Old 07-16-2011, 01:11 PM   #46
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Thank you Kim, hey you 55-59 guys can I get some picts of how the front shocks are mounted? My truck was kinda tore apart when I got it. Also would it be cool to paint the rims Kelly Green? I think it would look good with the trim rings and caps on there. I also think that doing a "truer" green would be cool, thats why I am thinking Kelly Green. Please let me know. And as always
Old 07-19-2011, 12:14 AM   #47
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Working on the frame. Got the suspension off
Old 07-19-2011, 12:19 AM   #48
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Got the frame done and this much of the front suspension this weekend
Old 07-20-2011, 09:30 AM   #49
vwjohnny
vwjohnny's Avatar
Re: My 58 Fleetside
These help ya?
vwjohnny is offline   Reply With Quote
Old 07-20-2011, 02:19 PM   #50
OrrieG
OrrieG's Avatar
Re: My 58 Fleetside
Check the upper brackets carefully for cracks right below the shock bolt hole were it widens out. When I was running stock shocks in the 70's both of mine broke off. A search of wrecking yards showed that it was a common problem, all had been removed. I made replacements out of flat stock.
OrrieG is offline   Reply With Quote
