Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 06-26-2012, 10:51 PM   #26
Last_Paladin
Re: 13" and 14" Corvette Brakes for C10's
Do you have something for the rear in 6 lug?
Last_Paladin is offline   Reply With Quote
Old 07-13-2012, 05:28 PM   #27
gringoloco
A guy with a truck
gringoloco's Avatar
PM sent...
gringoloco is offline   Reply With Quote
Old 10-11-2012, 11:19 AM   #28
slimneverdies
slimneverdies's Avatar
Is there any partcular Mcguaghys spindle that you need to work with this setup or is are they all compatable with the brackets?? Does the rotor thickness matter?
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 10-11-2012, 11:23 AM   #29
way2lo2
way2lo2
way2lo2's Avatar
we can machine any mcguaphys drop spindles to work with our vette kit but its probably cheaper to sell your used spindles with brakes and buy a brand new set of our machined spindles. You won't be able to reuse any of the orig. brake components from the original spindles anyway and can sell them complete already mounted on your spindles.
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Way2Lo2@aol.com <----also my paypal
http://www.hubgarage.com/mygarage/way2Lo2
way2lo2 is offline   Reply With Quote
Old 10-12-2012, 05:54 PM   #30
stempy4930
do you have any of the 13" assembled kits and are they still 999?what would shipping be to 50428?thanks
stempy4930 is offline   Reply With Quote
Old 10-19-2012, 09:36 AM   #31
way2lo2
way2lo2
way2lo2's Avatar
yes, c5 z06 are available, $100 shipping
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 11-07-2012, 10:30 AM   #32
nlped
nlped's Avatar
Question... I already have the McGaughy 13" Big Brake kits front and rear...Can the already cut spindle I have be adapted to work rather than buying another set of spindles. Mine are already on the truck, but I'd love a better looking caliper
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-07-2012, 11:09 AM   #33
way2lo2
way2lo2
way2lo2's Avatar
yes, I have a bracket that will work, you will probably have to turn the Mcgaughys hubs' diameter to fit the c6 z06 rotor and the spacing bushing will need to be made but otherwise it will all bolt together. I can walk you through it if you need help with it
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 11-07-2012, 11:33 AM   #34
nlped
nlped's Avatar
Great! Can you PM me a price shipped to 35079? 14"
Carter
Old 11-07-2012, 01:43 PM   #35
way2lo2
way2lo2
way2lo2's Avatar
pm sent
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 11-26-2012, 10:16 AM   #36
Hart_Rod
Hart_Rod's Avatar
I have a set of ECE 2 1/2" dropped spindles. What options do you have available to go with it? TIA.
R/
Hart_Rod is offline   Reply With Quote
Old 11-26-2012, 10:18 AM   #37
way2lo2
way2lo2
way2lo2's Avatar
R/
does it have mounting bosses for a backing plate
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 11-26-2012, 10:50 AM   #38
Hart_Rod
Hart_Rod's Avatar
Here's a couple pictures of the spindles:
Old 11-26-2012, 10:55 AM   #39
way2lo2
way2lo2
way2lo2's Avatar
yea, pretty sure I can come up with something if you can send me the spindles
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 12-10-2012, 02:33 PM   #40
65sw
I sent you a PM about your brake kit.
65sw is offline   Reply With Quote
Old 12-10-2012, 02:49 PM   #41
way2lo2
way2lo2
way2lo2's Avatar
got it, my brackets will not work with the cpp spindle. If you want to send me your spindles, we can design a bracket to work.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 12-10-2012, 03:03 PM   #42
65sw
Thats cool! I have the calipers and rotors. When you get a chance shot me a cost on your spindles, hubs and brackets.
Old 12-10-2012, 03:13 PM   #43
way2lo2
way2lo2
way2lo2's Avatar
To the guys who want to source their own c5 or c6 parts. I supply the drop spindle, 4.75" bolt pattern hubs with bearings, seal, dust caps, and screw in 7/16" wheel studs, along with a bolt on mounting bracket for $600+shipping. You will need the rotors and loaded calipers to finish off the kit. I've seen take off vette parts as cheap as $100 on craigslist and swap meets
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 12-22-2012, 09:46 PM   #44
kevhill85
91 SWB 383
kevhill85's Avatar
Will the hubs work on the 04 trucks . If not do you have a 5lug kit for the 99-04 truck
kevhill85 is offline   Reply With Quote
Old 12-22-2012, 10:00 PM   #45
way2lo2
way2lo2
way2lo2's Avatar
99 and up have a one piece hub and bearing assembly unlike the earlier trucks so no they wont work but I'm pretty sure I can redrill your hubs for a 5 bolt pattern
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 12-22-2012, 10:23 PM   #46
kevhill85
91 SWB 383
kevhill85's Avatar
How much?
Old 12-22-2012, 10:25 PM   #47
way2lo2
way2lo2
way2lo2's Avatar
$65 each
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 12-22-2012, 10:40 PM   #48
kevhill85
91 SWB 383
kevhill85's Avatar
Where are you located at? I am looking to buy a new set of hubs from eBay right now and rotors from r1 concepts
Old 12-22-2012, 10:42 PM   #49
way2lo2
way2lo2
way2lo2's Avatar
Cleveland Ohio
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 12-27-2012, 07:47 PM   #50
skorpioskorpio
OK, so if I'm starting from scratch and want 4 corner 13" brakes with single piston sliding caliper brakes with parking brake and the goal of easy service on the brakes, what can you do? I'd prefer to use something like SPP diamond slotted rotors with Hawk HPS pads. I think I'll get better pad area out of single piston sliders than some multi piston caliper, and I don't like drilled rotors, they tend to crack when you run them hard and eventually they look crappy anyway. I'm OK with going to 5 on 4 3/4" and changing out the rear axles to do that if it makes it easier to do off the shelf replacement parts in the future.
I'm planning out a project right now and want to do this all at once, I'm probably going to be using a Porterbuilt dropmember front with coilovers. Looking to do probably a 3" drop front and 4" or 5" in the rear.. I'm not just looking for brakes that look good behind wheels, I plan on using them and using them hard. Oh, project is a 69-72 Blazer/Jimmy and 18" wheels BTW, also want to stuff 295/45/18s on all 4 corners so I'm probably going to have to play around with backspacing to get everything to clear. Since these trucks lack a locking column I also plan to relocate the parking brake to inside of a Tuffy center console using a Lokar hand parking brake though I don't think that matters much.
Way2lo2 sounds like you could supply such a requirement, no?
skorpioskorpio is offline   Reply With Quote
