05-22-2011, 07:42 PM | #26 |
My Carbon Footprint
Re: Quick easy horsepower
problem is that farm truck is not cheap at all. That is the wiki def of a "polished turd". I can't imagine how many people he has embarrassed!
05-22-2011, 08:24 PM | #27 |
A fake scoop is worth 150 horses at least.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
05-22-2011, 08:35 PM | #28 |
well heres 2cheap horsepower gain options changed my fan blade to one like we use on our shorttrack car it's a nylon blade gained 13 hp proven on dyno and you can also change air cleaner and pickup horse power you'll just to ask your speed shop on the air cleaner or do research online.......hope this has helped
05-22-2011, 09:01 PM | #29 |
05-22-2011, 11:22 PM | #30 |
Some glue on vents will get you +10
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
05-22-2011, 11:36 PM | #31 |
The leaf blowers Hot Rod put on their vette gained 20-something HP! not to bad!
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
05-22-2011, 11:52 PM | #32 |
The Niner
Remember the old Splitfire spark plug commercials?
"5 extra horsepower by merely installing the plugs"
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
05-23-2011, 11:21 AM | #33 |
Funny that you guys mention the leaf blower.
My grandpa has two boat bilge pumps in line on his intake on his 89 Chevy with a 350. When you put that thing to the wood and click on them pumps that thing comes on a like a raped ape and boy do they push a boat load of air! :P |
05-23-2011, 11:36 AM | #34 |
Don't be in such a hurry to get where your going. Low horsepower means less tickets and enjoy the sights while your cruising in your cool retro ride.
05-23-2011, 04:35 PM | #35 | |
If you're going to spend money on your motor, you need to put things in perspective. If you've got a tired old 350, putting a cam or headers or an intake and carb on it aren't going to get you a lot of results for the money you spend. I've thought about rebuilding my 350, but for what I'd spend on machine work and parts, I can buy a crate motor with a warranty or put in a used LS motor. Either one seems like a better option. |
05-23-2011, 05:38 PM | #36 | |
05-23-2011, 06:23 PM | #37 |
05-23-2011, 09:34 PM | #38 |
laying low
Depends on how easy and how quick you want it to be. A rear gear change to a lower ratio won't add any actual horsepower but it will make your engine pull like it's had the hp bumped up. For instance changing from a 3.08 gear to a 3.73 is very noticeable. Yes fuel mileage will suffer with a lower gear but no more than putting power adders on your engine.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-24-2011, 01:44 PM | #39 |
Back in the day, guys used to put moth balls in the gas tank before going to the track to make a little more power.
1970 Chevrolet C-10 w/355sbc 2010 Silverado Daily Driver 1971 Mercedes 280sl project car |
05-24-2011, 01:53 PM | #40 |
When I was 18 I owned a nicely modified Tri-Power GTO that could run mid 12's with slicks and open exhaust. I had a "tuner" (former mechanic at Royal Pontiac) spend 2 hours on it and I ran an 11.7 sec 1/4 mile. He adjusted my carb settings, changed advance weights and sent me away with a a tune-up sheet that included timing, dwell, etc. I was able to keep it running great after doing this. I think at the time (1982 or so) I paid him $100 plus parts to do the work. It was the best money I ever spent. Bottom line is there was plenty of power that was not being taken advantage of the tuner was able to find.
05-25-2011, 10:30 AM | #41 |
that's what i'm talking about .. the little small things .. i just read an article about this and they replaced the fluids, flowmaster mufflers, and k n filter and got like 18 h.p. out of a newer v6 .. yes and tuning is key.
05-25-2011, 10:50 AM | #42 |
Mine always seem to run a little better after a wash, wax...vac...windex...tire shine...
05-25-2011, 12:50 PM | #43 |
