Old 07-18-2011, 12:00 PM   #26
parkwood
parkwood's Avatar
Re: 1951 Suburban a 4 year project....
Getting the seams sealed up and filling the 90+ holes in the fire wall..
parkwood is offline   Reply With Quote
Old 07-18-2011, 12:07 PM   #27
parkwood
parkwood's Avatar
Originally Posted by duwem View Post
Any tips on filling in all the rivet holes in the frame? Did you have someone punch out inserts for you?
That thing is SWEET
Thank you glad you liked it... what i did to fill the holes in the frame was to buy some round stock and cut slugs the thickest of the frame and hold them up with magnet and weld them in.. I tried to use stock close to the hole size and if the hole in the frame was some off size i just drilled the hole to the size of stock i bought .. 1/2'' and 1/4'' etc.. i'll see it i have pictures..
wayne
Old 07-18-2011, 12:34 PM   #28
juanz1947
rusty 66
juanz1947's Avatar
Nice build I think iseen this suburban in person at pomona swapmeet
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
Old 07-18-2011, 12:39 PM   #29
hotrod1
56 - autocross
hotrod1's Avatar
Do you just spot weld the panels on or do you go back and weld the entire seam?
hotrod1 is offline   Reply With Quote
Old 07-18-2011, 11:24 PM   #30
lonelywanderer
beautiful finished product
lonelywanderer is offline   Reply With Quote
Old 07-19-2011, 01:07 AM   #31
parkwood
parkwood's Avatar
No sorry this one has never been to the pomona swapmeet...
Old 07-19-2011, 01:18 AM   #32
parkwood
parkwood's Avatar
Hotrod, the floor pans just got spotted about every 3-4" and then seam sealer was put on all seams.. the cowl panels and any other patch panel was weld all the way around and then grounded smooth..
Old 07-19-2011, 01:19 AM   #33
parkwood
parkwood's Avatar
Thank you... glad you liked it..
Old 07-19-2011, 01:25 AM   #34
parkwood
parkwood's Avatar
Getting the a/c mounted and running the lines.. making room for the a/c lines to get into the engine bay..
Old 07-19-2011, 01:29 AM   #35
parkwood
parkwood's Avatar
One more shot of the cut away for the a/c lines and building trans cover
Old 07-19-2011, 01:32 AM   #36
parkwood
parkwood's Avatar
Getting the electric fan mounted..
Old 07-19-2011, 01:39 AM   #37
parkwood
parkwood's Avatar
Door gaps, everyone loves these.......
Old 07-19-2011, 02:00 AM   #38
parkwood
parkwood's Avatar
Both rear lower corners were rusted out so they got new ones..
Old 07-19-2011, 02:05 AM   #39
parkwood
parkwood's Avatar
The barn door on the pass side was push in on the bottom so i split the door pulled it out level with the outside and welded it up..
Old 07-19-2011, 02:09 AM   #40
parkwood
parkwood's Avatar
Now the top was pulled out on the pass side, so split it just under the window and pushed it in and welded it up
Old 07-19-2011, 02:13 AM   #41
parkwood
parkwood's Avatar
all that left a huge gap between the doors so welded them up and ground the gaps to my liking..
Old 07-19-2011, 02:18 AM   #42
parkwood
parkwood's Avatar
The center of the driver's door stuck out to far so cut and weld...
Old 07-19-2011, 02:23 AM   #43
parkwood
parkwood's Avatar
Getting a gas door in fender
Old 07-19-2011, 02:29 AM   #44
parkwood
parkwood's Avatar
You can see how much better the fender fit on the drivers side than the pass side.. cut it moved it in a little and reshaped it to fit..
Old 07-19-2011, 02:34 AM   #45
parkwood
parkwood's Avatar
On the suburban's the drivers seat sits up on a riser so we were able to put the radio, computer for air ride and some relays under the seat making a neater install and to hide some of the ugly stuff..
Old 07-19-2011, 02:39 AM   #46
parkwood
parkwood's Avatar
Running lines for a/c
Old 07-19-2011, 02:46 AM   #47
parkwood
parkwood's Avatar
Breaking it all down so all the welding can be completed and sent out for power coat ....
Old 07-19-2011, 02:51 AM   #48
parkwood
parkwood's Avatar
More parts off to power coater along with the frame , body gets under coating...
Old 07-19-2011, 02:55 AM   #49
parkwood
parkwood's Avatar
The frame all power coated and ready to be put together..
Old 07-19-2011, 03:00 AM   #50
parkwood
parkwood's Avatar
Body back on frame and welding up factory seam's where the lead use to be..
