Old 09-29-2011, 12:48 PM   #26
rollinrooster
rollinrooster's Avatar
Re: The beginning, my 57 LS powered streetrod
Looking good!! I also love the ghia I drove a red '69 ghia to high school that sat about like yours.
rollinrooster is offline   Reply With Quote
Old 09-29-2011, 03:03 PM   #27
ZR2RICK
ZR2RICK's Avatar
Thanks, I loved that car, she is the reason I decided to bag the 57, just couldn't drive it anywhere without dragging the pan.
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline   Reply With Quote
Old 09-29-2011, 03:44 PM   #28
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Nice Ghai, What size motor and are those Webers? Back in the day I have a 67 bug with a 2110cc with dual 48s, my problem was I couldn't stop it when I needed to.
BTW: Look at Cal58GMC thread regarding baggin the truck, he has most of the info needed.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 09-29-2011, 06:21 PM   #29
ZR2RICK
ZR2RICK's Avatar
Well I got the bag mounted, took a lot of trial and error but 'm pleased how it turned out, the crossmember being the lowest point I set it up so there should be 1.5" when aired out completely, I have a 3" cup tapered to 2.5" on the bottom(plus 1/4" plate) and a 2" cup on top (plus 1/4" plate). the taper straightened out the bind the bag got into when fully compressed. I will do the same for the other side and then hook up some air to them.
Old 09-29-2011, 06:30 PM   #30
ZR2RICK
ZR2RICK's Avatar
The Ghia had a 1776cc engine, w/dual Dellortos, it was a blast to drive, I built a 3" narrowed adjustable beam in front,adjustable springplates in back,disc brakes all around. It sold to a guy in Stockholm Sweden, it had a perfect nose and he said he couldn't find a non wrecked Ghia in Europe, imagine that?
Old 09-29-2011, 07:11 PM   #31
scooterskoolkustoms
scooterskoolkustoms's Avatar
man I love old trucks with new motors loooooking good
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 09-29-2011, 07:21 PM   #32
Kabwe
Certified Car Nut
Kabwe's Avatar
Once again its looking good man.
Kabwe is offline   Reply With Quote
Old 09-29-2011, 08:34 PM   #33
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice install!
ChuckDriver is offline   Reply With Quote
Old 09-29-2011, 08:50 PM   #34
ZR2RICK
ZR2RICK's Avatar
Thanks so much, I have learned a lot reading this forum, even when you have the years behind you that I do building bikes and cars it helps speed things along with less mistakes when you can see someone else's work and how they accomplished something. I only hope my work can help someone else also.
Old 10-03-2011, 10:41 PM   #35
ZR2RICK
ZR2RICK's Avatar
Well I got the drivers side finished and almost done w/ the pass.side, still need to mount the air tank, I'm using 1/2" SS braided hose I'l probably need to use some sort of air volume reducer to have good control of the speed, Tank will be under the cab floor just inside of the step area. I plan on valves being mounted at the tank, anyone see any reason not to mount them there?
Old 10-04-2011, 09:07 PM   #36
pbeguy
pbeguy's Avatar
The S10 Blazer (or any) 4wd S10 rear is about 4 inches wider than a 2wd. The 98-up Blazer comes with disc brakes already. That is what I am running on mine.
pbeguy is offline   Reply With Quote
Old 10-04-2011, 09:15 PM   #37
50seven
50seven's Avatar
That is gonna be nice and low
50seven is offline   Reply With Quote
Old 10-04-2011, 10:58 PM   #38
ZR2RICK
ZR2RICK's Avatar
THANK YOU, yea thats what I need , wrecking yard here I come!
Old 10-04-2011, 11:50 PM   #39
Rods57
Rods57's Avatar
Hey just noticed your down the road from me. Nice build, good to see more Idaho builds...let me know if you need anything.
Rods57 is offline   Reply With Quote
Old 10-26-2011, 01:59 PM   #40
ZR2RICK
ZR2RICK's Avatar
That is so cool there are Idahoans on here, I am following your thread as well, love the red and black! Well I got both air bags installed and set her down, but mis-judged my aired out height about 1-1/2" or so, I wanted her to sit 1-2" off the ground at the cross member but it just sits on the floor, so I'll have to make taller cups.(but Damn she looks cool layed out!) Also got the harness a bit closr to what I need, sill waiting on a TAC module to get here so I can figure out where to mount it and modify the harness for it. Also have the gas tank in place but not bolted down ,still working out the mounting.
Old 10-26-2011, 02:27 PM   #41
BShort
Looks great! That is the beauty of air ride, if you want it 2 inches off the ground you just bump the switch! I say leave it, so you can lay it out when parked.
BShort is offline   Reply With Quote
Old 10-26-2011, 02:30 PM   #42
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking great man. Keep the pics coming.
Old 10-26-2011, 04:40 PM   #43
Kim57
Kim57's Avatar
That thing sets real low, looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-26-2011, 05:02 PM   #44
ZR2RICK
ZR2RICK's Avatar
Hanging fenders so I can fit the inner fenders and finish the core support mounting, I don't like the ball joint angles, especially the uppers, of course this pic is aired out but even when I bring her up to ride height the angles are a bit sharp, haven't seen any special ball joints like I bought for my Karmann Ghia that allow more travel and avoid binding the joint, anyone know of any available? may need to look into some aftermarket arms?? or maybe modify the ends myself.
Old 10-26-2011, 05:03 PM   #45
Tri5Nerd
Tri5Nerd's Avatar
Looks good, is that a 22 gallon tank? What are type of pump you going to use to send the fuel to the motor? I'm using a stock pump in the bucket with some mods to the tank.
Tri5
Old 10-26-2011, 05:06 PM   #46
ZR2RICK
ZR2RICK's Avatar
Thanks so much, yea I like the idea of setting her on the ground,I guess I just don't know if I trust the bags enough to risk having it drop to the ground while driving.
Old 10-26-2011, 05:09 PM   #47
ZR2RICK
ZR2RICK's Avatar
It's an 18 gal. tank, I plan on using a Walbro or similar type pump in the tank and making my own mount set up like "Tanks inc." sells.
Old 10-26-2011, 05:29 PM   #48
hotrodrookie
hotrodrookie's Avatar
If you haven't already seen in, Delmo built a nice intank pump setup from an OE pump and a salvage tank flange. Being that you have a steel tank, it makes it easier to make it work because you can just weld in a flange or make your own and weld it in.>>> http://www.vetteworksonline.com/ls1_conversion_fuel.htm
hotrodrookie is offline   Reply With Quote
Old 10-26-2011, 07:20 PM   #49
ZR2RICK
ZR2RICK's Avatar
Thumbs up Re: The beginning, my 57 LS powered streetrod
Thanks so much, great idea, i'll have to do some research on the height of the stock pump set up to see if it would fit.
Old 10-26-2011, 07:27 PM   #50
Kim57
Kim57's Avatar
These guys sell a tall ball joint that may help cure some of your ills.
I'm using a set of their polished nickle ones on my project.
Kim
http://www.howeracing.com/c-575-4-bolt-gm-uppers.aspx
My build thread
