Old 09-21-2011, 09:35 PM   #26
Wheelie
Re: Rear custom four link pics!
Originally Posted by mknittle View Post
LOL, Is that good?
YES!
Wheelie is offline   Reply With Quote
Old 09-22-2011, 02:48 PM   #27
tech@scottshotrods
Here are a couple pics of out coil over and air bag 4-links
tech@scottshotrods is offline   Reply With Quote
Old 09-22-2011, 04:58 PM   #28
mknittle
mknittle's Avatar
Originally Posted by blitz'd View Post
The upper or lowers? The lower is the stock S10 leaf spring perch, don't remember how long the lowers I wanna say around 35". I am 1500 miles from the truck right now or I would go measure.
Nope just a fancy shock mount.
thanks That is a work of art
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-22-2011, 09:23 PM   #29
Wheelie
whats that coilover length and spring rate in that nice set-up you have there?
Old 09-22-2011, 10:21 PM   #30
Scottshotrods
In the pic you see above the coil-over length is 13 inches extended and spring rate is 300lb.Keep in mind we do have several different lengths in coil-overs and different spring rates.
Justin
Scottshotrods is offline   Reply With Quote
Old 09-23-2011, 08:39 AM   #31
mknittle
mknittle's Avatar
Isn't 300lbs kind of stiff?
Mark
My GMC build.
Old 09-23-2011, 10:18 AM   #32
LEEVON
LEEVON's Avatar
I was going to use a 4-link, but got a bug to use trailing arms w/ a panhard bar. Shock mounting is the only challenge with this.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-23-2011, 10:47 AM   #33
mknittle
mknittle's Avatar
That's interesting, I like it being not a common swap.
Mark
My GMC build.
Old 09-23-2011, 10:49 AM   #34
Scottshotrods
We have been useing a 300lb in the rear for many years on the rear of trucks and we have had great results with performance and handling.Keep in mind again we have many different weights for the spring rates and we have springs as light as 150lb and we use alot of these springs on the rear of pre 34 coupes.Spring rate will change on the coil-over on the angle you have your coil-over at as well
Justin
Old 09-23-2011, 11:25 AM   #35
mknittle
mknittle's Avatar
Justin
Thanks Justin, I am just trying to get some idea of what works best. I know about the effects of angles on shocks and springs from modifying dirt bikes in the 1970s and recently reading Herb Adams chassis Engineering.
I just don't know for sure what the rear of the AD trucks weigh.
Mark
Mark
My GMC build.
Old 02-19-2012, 02:48 AM   #36
c6_rob
c6_rob's Avatar
Nice ideas here. Im posting to keep this one alive
52 Chevy 3100
c6_rob is offline   Reply With Quote
Old 02-19-2012, 06:27 AM   #37
renegade8720
Here is what our set up looks like.
Renegade
renegade8720 is offline   Reply With Quote
Old 02-19-2012, 10:12 AM   #38
rollinrooster
rollinrooster's Avatar
Here are some better shots of what i posted once before.
rollinrooster is offline   Reply With Quote
Old 02-19-2012, 02:21 PM   #39
nebdrummer
nebdrummer's Avatar
A few of mine unfinished
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 02-19-2012, 04:19 PM   #40
Speedbumpauto
Speedbumpauto's Avatar
Art Morrison equal length 4 bar kit. Love the big bars and the excellent craftsmanship. In my 55 with a 505 BBC. It needs to see at least a couple of passes down the strip.
Speedbumpauto is offline   Reply With Quote
Old 01-12-2014, 07:55 AM   #41
Low_Life86
Low_Life86's Avatar
bump
Jeremy
'86 GMC 1500 dropped 6" in the front and 6" in the rear
2003 Land Rover Discovery
Low Life
Low_Life86 is offline   Reply With Quote
Old 01-12-2014, 11:48 AM   #42
nikwho
nikwho's Avatar
So, This is an amazing thread! Great fabrication to all of you that have posted! I am in the process of designing my rear suspension on my '53 that resides on a '94 S10 frame. I know that there are preferred setups for best traction on the strip and others for street/autocross type of driving. I want to set my truck up to handle well on the street and I am hopeful to maybe get it to some autocross events. So, for street/autocross driving, what is ideal? A parallel four bar with Watts link? triangulated 4 link? a three link? Inverted triangulated four link (I forget the proper name of this setup). I want to determine first the ideal setup, then discuss numbers and setup. Thanks for any help!
Nik
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 01-12-2014, 01:17 PM   #43
nikwho
nikwho's Avatar
I have just started plugging some preliminary numbers into the calculator. Might be a good starting point for some critique.
'68 GMC - BBC/TH400
Old 01-13-2014, 12:06 PM   #44
nikwho
nikwho's Avatar
Originally Posted by rollinrooster View Post
Here's what i came up with.
Rooster,
I love your air bag buckets! Very clever! I was going to fab a bridge and plates but didn't like the thought of the torsional load on the tubing with a big 5" plate sticking off of the side. I really, really dig the tubing recessed into the frame rail! I hate to say it, but I may copy you. Strong work!
Lowlife86, thanks for bringing this back from the dead! Perfect timing for me trying to figure out my rear link suspension. Very motivating!
Nik
P.S. Anyone up on link suspensions enough to know what works the best for street handling and the occasional autocross outing? I have always been drawn to a triangulated 4 link, but like the simplicity of a parallel 4 bar with a Watts link. However, I have also read about a Satchel Link (Spelling?) that is basically an inverted triangulated 4 link. Thoughts? My thoughts were to run air bags, but also be set up for QA1's, for autocross. When I wanted to play with the air bags, I would just have the springs out of the coil-overs. When we wanted to go race, we could yank the bags and air tank to save weight. Kind of a dual purpose type of build.
'68 GMC - BBC/TH400
Old 01-14-2014, 07:32 AM   #45
47 Fasttoys
47 Fasttoys's Avatar
OK, sense you asked with a reference to autocross I'll through in my 2 cents (or 20 cents in this case). I have played the autocross game for 3 years in a FFR Cobra kit car. I started with a triangulated 4 link based on the Mustang GT. later I converted to a Levi Racing 5 link, it was like night and day. The 5 link is basically using the 2 lower bars from the 4 link, removing the upper 2 bars and adding a center bar over the center section. This bar runs strait like the lower bars. At the rear of the center section a watts link is added using a rear cover from a T-bird IRS. All the bars have rod ends at both ends for total adjust-ability. This allows changing the pinion angle for different types of racing (autocross of drag). I have also spent some time driving a track with a car equipped with the same set up but it used a pan hard bar in place of the watts link. On track it was very similar to mine. For me the biggest issue with the tri 4 link is it steps over the edge with no warning where the 5 like is very predictable at the edge and can be held in a 10% oversteer condition which is about as fast as I can go. Sorry I don't have pictures and I am out of town now (like 8000 miles out). You can find pictures at Levi Racing or FFCARS.com.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 01-14-2014, 08:51 AM   #46
buggy5872
buggy5872's Avatar
Here's mine
[/url]
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 01-14-2014, 04:17 PM   #47
wickid demon
wickid demon's Avatar
Nikwho,
I have ran a satchhell link setup in one of my road courses cars before and they work great, you can adjust roll by adjusting the sway bar and not have to move your links to a different mounting whole. One of the keys to a good satchell link is the upper bar needs to be as long as possible so that your roll steer or the quick edge as 47 fasttoys said does not sneek up on you just a smooth transition throughout travel. That is the biggest drawback to putting this setup in a car is packaging, trucks we can just extended the wheelbase a little to gain what we need. I am running the satchell link suspension on my truck. There are no packaging problems and your roll center is low plus I don't have to mess with the pan hard bar. Reason I mention this you can see how close my inner frame bracing comes to the driveshaft. You want the lower links as close to the center of the truck as possible to create single pivot point. But is not achievable due to the drive shaft being in the way.
Ryan
My Wickid 54 http://67-72chevytrucks.com/vboard/s...d.php?t=518657
wickid demon is offline   Reply With Quote
Old 01-14-2014, 06:19 PM   #48
Coach529
Coach529's Avatar
I like this set up. Did you just pull it out of a 60-66 pickup? Did you mount shocks yet?
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 03-04-2014, 04:01 AM   #49
ccrane0044
ccrane0044's Avatar
heres my setup so far, still have some tweeks and adjustments to go. not like some of the ones of here but it works....
let me know what you guys think, im planning on putting the bags behind the 4-link bracket and still working out where the shocks will go.
'80 GMC C15, still in progress... http://67-72chevytrucks.com/vboard/s...d.php?t=651276
ccrane0044 is offline   Reply With Quote
Old 03-06-2014, 07:38 PM   #50
Bagged3100
Heres some pics of my triangulated 4 link setup. Going to have the bags installed on the lower bars.
Bagged3100 is offline   Reply With Quote
