10-06-2011, 09:14 AM | #26 |
Re: SLOSH TUBZ SQUARED... sneak peek
They look great! When will they be available?
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
10-06-2011, 09:28 AM | #27 |
67cheby
end of this year or jan of next year ...or ASAP
10-06-2011, 10:14 AM | #28 |
Do you think they will work with the Vintage Air SureFit system? Will there be enough room for the a/c lines and heater hoses?
10-06-2011, 10:17 AM | #29 |
67cheby
i dont know can you show me a pic of yours and i will tell you if it will or not, you would probably need to run your hoses down low and come out of the firewall above the frame rail somewhere ?
10-06-2011, 11:57 AM | #30 |
Slots go on anything!
It looks like it will be close with the Vintage Air setup. There are some decent pics of the hoses in my build thread if you want to compare them.
1974 Jimmy- 5.3/4L80e/NP241 |
10-06-2011, 11:59 AM | #31 |
67cheby
can you post a pic of it on here ?
10-06-2011, 12:18 PM | #32 |
Formerly- 1972SuperCheyenne
Super nice man! Great work.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
10-06-2011, 12:40 PM | #33 |
I can when I get home. I'm accessing this on my phone for now.
10-06-2011, 06:24 PM | #34 |
Oooh damn, subscribed. I want these.
10-06-2011, 06:28 PM | #35 |
67cheby
thanks guys the excitement encourages me !! LOL
10-08-2011, 11:32 AM | #36 |
here are some pics of the Vintage Air Sure Fit Gen IV setup at the firewall. Hope this helps. This is on a '74, so the wheelhouses are a little bit different than the 81-up.
10-08-2011, 11:51 AM | #37 |
67cheby
ok you are correct ...no these hoses wouldnt clear they would have to be rerouted coming out closer to the engine side of that filler panel
10-08-2011, 04:55 PM | #38 |
Would 90°elbows work? If they came right off the firewall w/90's toward the motor, then 90'd back toward the core support?
10-08-2011, 05:05 PM | #39 |
67cheby
possibly , since i am still in the fabrication stage maybe i can make for a little more clearance in that area ! maybe if someone has one of these plastic panels that they didnt use they could let me borrow it for mock up
12-16-2011, 04:14 PM | #40 |
Registered Cruiser
Any update on these puppies?
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
12-16-2011, 04:30 PM | #41 |
67cheby
unfortunately no not at the moment hope to get back on them after the first of the year !
12-16-2011, 06:41 PM | #42 |
Garage wrench
^^ that's good news. I can't wait to see them further along. I should be ready to place an order for a set in the next month or two. Keep it up
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
12-16-2011, 07:05 PM | #43 |
Tubs look awesome! Nice work.
01-02-2012, 01:48 PM | #44 |
67cheby
Progress is back under way , for those of you following !!! Pics as soon as we make some progress !
01-02-2012, 03:29 PM | #45 |
Diggin The SquareLife
nice brother!!!
01-02-2012, 03:31 PM | #46 |
67cheby
Thank you , i am really excited about 2012, hope to get my truck done finally and get SLOSH TUBZ going STRONG !!
01-02-2012, 05:38 PM | #47 | |
Registered Cruiser
Can't wait!!!!
01-03-2012, 10:32 AM | #48 |
these tubs bolt into the factory locations? and im guessing if you have the fenders cut out it would only bolt in at the front and rear of the mounting locations?
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy |
01-03-2012, 11:03 AM | #49 |
67cheby
no, i trimmed right at the edge of all of the holes all the way around so all of the factory bolts around the edge will be used, as soon as i have one of the inners unbolted i will get a picture so you can see what i am talking about !
02-04-2012, 11:46 AM | #50 |
Garage wrench
any new updates on these Mike? I am starting to get the itch for a set and it's tax time!!
