Old 10-29-2011, 12:27 PM   #26
Doug_J
Doug_J's Avatar
Re: '06 HD Straight Axle Conversion Build Pics...
If you dont mind me asking how much do you have in that frontend?
Doug_J is offline   Reply With Quote
Old 11-10-2011, 07:09 PM   #27
Solego
Dr. Frankentruck's Monster
Solego's Avatar
I love Chevy trucks. But this is why I bought a Jeep. I don't have the talent to do that.
I'm not prejudiced, I hate everyone.
Project SLOMO
http://67-72chevytrucks.com/vboard/s...d.php?t=430494
Solego is offline   Reply With Quote
Old 11-10-2011, 08:32 PM   #28
47thriftmaster
47thriftmaster's Avatar
Work looks great, should be a lot of fun when finished. I did my '06 a few years back, but did coil overs in all 4 corners rather then leafs. It's a blast and he won't have to worry about replacing the CV shafts all the time. Here's a quick pic.
47thriftmaster is offline   Reply With Quote
Old 12-17-2011, 10:43 AM   #29
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Looks good man, what axle you running ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 12-17-2011, 10:56 AM   #30
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Hey guys !!!
I have been really busy lately as far as updates go ... but I did finish her up last week !!
Came out really nice ... with ZERO bump steer on the steering.
Finnally....here are some more pics....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-17-2011, 11:27 AM   #31
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
OK, when left off...we were working on the steering.
My buddy wanted to try our old skool way of Z's the draglink like we used to do back in the day on Samurais...
I insisted that it was a ghetto way of doing it, considering the amount of lift and how heavy this vehicle was...so here goes... Had to prove it the hard way !!
He quickly realized I was right ... ... but at least we were able to steer the truck, take it outside for some air, and test it with the forklift....
The truck was flexing a lot better than I thought...I could of lift the forks alot higher without lifting a rear tire, but the tire was starting to slip on the forks. I need to build a tire cradle to slip onto the forks for safety.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-17-2011, 11:39 AM   #32
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
With the truck flexing, we were able to measure for shocks. After a little massaging of the factory upper a-arms mounts for the shock mounts....then moe clearanceing of the mounts themselves, we were able to get his shocks in....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-17-2011, 11:47 AM   #33
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Extended brake lines and custom ABS wires were made:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-17-2011, 11:52 AM   #34
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
OK.....now we had to get back to the STEERING !!
Since no one makes a HI-STEER for the Dodge AXLE...we had to design something !!
Came out so well....I think we might start production....
We cut up what was left of the Z bar () and used the ends in some tubing...plans are to replace with HD rod ends, as well move the crossover up high as well...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-17-2011, 12:19 PM   #35
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Next what the track bar ... the supplied tabs were too small to get the bar parallel with the drag link, so news pieces had to be made....
The supplied tabs were then used to locate the steering shock...
We utilized the existing hole in the crossover link to locate the steering shock...worked out great.
My buddy is not going to be rock-crawling, so for now this lower steering arm and shock will be fine.
In the future, we will be make new links to go 'over' the springs.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-17-2011, 12:25 PM   #36
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
A simple crossmember was welded in place of the stock low slung one (NOTE: the stock crossmember does not need to be removed for this converison)...we just wanted to clean things up.
Capped, and sanded to look 'one' with the chassis:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-17-2011, 12:34 PM   #37
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The previous, custom made front hitch/generator mount was re-worked and reinstalled:
This front end ended up being roughly an 8-10" lift. After lifting the rear truck on the lift...we were almost 4-5 inched high than before in order to get it level.
However, a jack lifting from the rear ballmount will give us a better reading.
A full 8" spring pack will be next for the truck, along with modifing the rear airbag mounts.
During the summer, this truck hauls a massive cab-over and tows a boat..
I TOLD HIM SHOLD OF GOT A DURAMAX !!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-17-2011, 05:40 PM   #38
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Amazing work man!
By the way, for you guys razzin on the 6.0 you can buy the truck then really wake them up with cam, tune, exhaust, throttle body, etc and get about 475hp for less $$ than if you bought a stock dmax... just sayin
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-25-2011, 11:30 AM   #39
kevinwcmo
hey ya got any info on the tire/wheel combo? ie, wheel style, size and backspacing? they look like pro comp tires. size? great build, got an 05 dmax that would look good under
kevinwcmo is offline   Reply With Quote
