Old 04-23-2012, 08:57 AM   #26
ramrod7373
Re: 69 GMC Short Stepside
Finally got her running. But having a problem getting the shift linkag to work right. Might be the steering column I got for free. My truck was originally a 3 on the tree, so I put in an automatic column I got from a friend. Can't get the column to match up with the right gear on the selector. Might have to just go to a floor shift. It's frustrating all the "mod's" I have to do to this truck. It will be worth it when it hits the road though.
ramrod7373 is offline   Reply With Quote
Old 04-23-2012, 01:39 PM   #27
FrankieD
FrankieD's Avatar
Did you use the Radiator and shroud from the 81? I want to put a larger clutch fan on but my shroud is too small. You should check this stuff out I soaked all my rusty bolts and clips over night and they came out nice and clean with a black oxide color on them non toxic or corrosive. Around $8 at Auto Zone for a qt.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 04-23-2012, 04:50 PM   #28
ramrod7373
I used the radiator and shroud from the 77, the shroud took 1/2 a day to cusomized so it would work in mine. Trimmed and trimmed some more, I think I had to install and remove the radiator and shroud 8 times b4 I got it to look and fit right.
I will check out that stuff, thnx for the input.
Old 09-02-2012, 06:32 PM   #29
ramrod7373
Got her on the road....still much to do, but at least she is road worthy
Old 09-02-2012, 10:26 PM   #30
Tinkermc
nice to get it on the street.
Tinkermc is offline   Reply With Quote
