12-23-2011, 03:25 AM | #26 |
Re: 6 lug front disc brakes
We swapped lower arms and spindles from a 84 burb, ordered the 1 1/4" rotors from CPP ( they were like $90 for both), bolted it all up. No worries since.
We had to make ab 15 trips to the parts store to find the right combo for the steering link but it was super easy. Posted via Mobile Device |
12-23-2011, 05:09 AM | #27 |
If you look at the backside of an original drum brake wheel you will find the barrel of the wheel to be "rounded"... that is what causes the interference when installing on a disc setup.
6 lug wheels off of a mid 70's - late 80's 4x4 should clear and all aftermarket wheels will as well. |
12-24-2011, 12:59 AM | #28 | |
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
12-24-2011, 08:07 AM | #29 |
67-72 parts collector,…
What wheel is that?
It's different than the style we are talking about. It won't accept a standard 1/2- ton hubcap. (no outside nubs). Posted via Mobile Device
12-24-2011, 07:11 PM | #30 |
My bad, forgot about the standard hubcap. My wheels are 12 series smoothies 15x7. I have many choices of hubcaps to mount in the inside center and beauty rings but I left them alone.
02-05-2012, 01:03 AM | #31 |
But Found Her 25yrs Later!
I still have the complete front axle off my 79 4X4 donor - 6 lugs.
Can the calipers and rotors be used on 2 wheel drive spindles? Edit: Found my answer:
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 02-05-2012 at 01:21 AM. |
02-05-2012, 08:19 AM | #32 |
I used the info in the thread mentioned in post #2. We went the 73-87 donor truck route. I installed the disc brakes and power steering. It was some work, but not hard. Then again I like doing stuff like this with my son. I used the steering box plate offered by Captainfab. Here's what I did if you’re interested.
http://67-72chevytrucks.com/vboard/s...d.php?t=453346
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
