Old 01-05-2012, 11:04 PM   #26
tecky11
Re: Cat 3116 build in 1972 IH Pickup
thank you. it is lots of work, pictures do it justice for the amount of work needed.
Truck: 1972 International Harvester 1210
Engine: Caterpiller 3116 220 HP 630 tq
Transmission: Eaton Fuller rt 6610
Axles: Merritor I beam front axle
tecky11 is offline   Reply With Quote
Old 01-07-2012, 12:42 AM   #27
jbclassix
Junk Yartist
jbclassix's Avatar
K. just the title hooked me! I've seen Travelettes with Cummins swaps, IDI IHC swaps, 6.5L swaps, and powerstroke swaps. I've ALWAYS liked Cat engines. I'm in!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-07-2012, 12:44 AM   #28
tecky11
welcome to the club
i will have more pics this weekend. things should go according to plan and set right in, and the hood should be right on without a cowl.
Old 01-07-2012, 02:34 AM   #29
Maxxd07
Maxxd07's Avatar
In to see this thing running!
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 01-07-2012, 02:35 AM   #30
tecky11
thanks i cant wait to see her running either
Old 01-15-2012, 02:21 PM   #31
tecky11
small update for those are following. i have to notch the firewall 4 inches to fit in the engine bay. will also be replacing cab mounts and that should help a little bit too.
Old 01-15-2012, 05:29 PM   #32
jbclassix
Junk Yartist
jbclassix's Avatar
Back or up on that notch?
-Jeremy
Rebuilding an NP205
Old 01-15-2012, 05:30 PM   #33
tecky11
from the center notch section.
Old 01-22-2012, 02:37 AM   #34
tecky11
small update, i got oil in the block,fuel in the filter,fuel line ran to gas can, just eed to get fuel shut off then i will have a video up tomorrow
Old 01-23-2012, 05:25 PM   #35
CowboyProtectionUnit
CowboyProtectionUnit's Avatar
Sawwwweeeeeeeeetttttttttttt!!!
Eric "Target" Sherwood
Professional Bullfighter For Hire
God Bless and Gods Speed!
TheCowBoyProtectionUnit@yahoo.com
http://www.facebook.com/pages/Eric-T...59496227444241
CowboyProtectionUnit is offline   Reply With Quote
Old 01-28-2012, 12:32 PM   #36
pickup67man
pickup67man's Avatar
I love to watch a challenge.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
Project Family Hauler
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 01-28-2012, 01:47 PM   #37
tecky11
and a challange it is. going to get startere tested today then going to try an start the SOB
Old 01-30-2012, 12:01 AM   #38
tecky11
still havent got the starter off. as soon as i do will get a vid up
Old 02-04-2012, 01:16 AM   #39
tecky11
ok got the starter off yesterday had to modify a socket tho, cut it off almost to nothing, just enuf to grab, 1/4 drive 13MM. got the damn thing off now trying to find a pace to test it.
next question how do i fill the block? take the thermostate out and fill with coolant? then hook the rad up?
Old 02-04-2012, 01:59 AM   #40
jbclassix
Junk Yartist
jbclassix's Avatar
should have 1/4" bleed lines on it... maybe... I have been around too many C7s to remember too much about 3116s. I would fill through t-stat, but if I remember, Cat engines do air-bleed themselves durring filling... could just always fill with 200deg coolant!
-Jeremy
Rebuilding an NP205
Old 02-04-2012, 02:11 AM   #41
tecky11
want to fill block before i start so it has some coolant and dont crack anything. (enigne aint paid for yet)
Old 02-07-2012, 11:47 PM   #42
Squareforceone
Squareforceone's Avatar
I love the old internationals and with a caterpiller even better!
Squareforceone is offline   Reply With Quote
Old 02-07-2012, 11:49 PM   #43
tecky11
well as soon aas i get the rest of my starter figured out i will let yall know.
Old 02-08-2012, 12:04 AM   #44
spudz
spudz's Avatar
OMG thats a big engine for that truck!!!! I love the cats! I cant wait to see it run!.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 02-08-2012, 12:22 AM   #45
tecky11
big??? no it isn"t big. it is flipping HUGE
Old 05-07-2012, 12:24 AM   #46
tecky11
no real updates. been busy and no $$$. still working on this tho
Old 07-23-2012, 06:55 PM   #47
cAlvis165
cAlvis165's Avatar
I'm in. My truck is a IHC '65 d1300, 4x4 with a 304. I'd like to swap in a diesel some day. I was thinking more along the lines of a 7.3, but I have to admit that CAT is going to be cool.
cAlvis165 is offline   Reply With Quote
Old 07-23-2012, 07:08 PM   #48
tecky11
The cat is cool but if you are going 7.3 use the idi version no HEUI bs to ddeal with
Old 07-24-2012, 06:11 PM   #49
cAlvis165
cAlvis165's Avatar
But can I get awesome horsepower without direct injection? I know you can boost the old 7.3 and 6.9s. But isn't the horsepower still much less than the "power stroke" diesels? I can't pretend to know much about diesels, but I'm trying to learn as much as I can. Not trying to highjack your thread. You can answer by PM if you would rather.
Chad
Old 07-24-2012, 07:41 PM   #50
6lcummins
He just doesn't like HEUI systems because of his Kitty Cat
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
