Old 06-23-2012, 06:40 PM   #26
laplander
Re: Serpentine belt conversions
Are you going to be getting anymore BBC ones?
laplander is offline   Reply With Quote
Old 06-24-2012, 02:39 AM   #27
tll74
"Junkyard Dog"
tll74's Avatar
Originally Posted by orngsikL View Post
so how would I tell if this would fit on my 350?
It will fit any 350. If your engine is 86 or older there will be one hole in the front of the passenger side cylinder head you will not have. I used and sold these w/o using this mounting hole with no problems. These use the "long" water pump with reverse rotation. The sample that I have pictured is bolted to a common 69-86 350 engine. It will not work with 68 and older cylinder heads as they do not have accessory holes.
Originally Posted by orange 69 View Post
Will this fit a 1976 SB 400 factory motor(no mods) with out A.C.?
If you don't have AC there is a idler pulley that takes the place of the AC pump. I may have this idler pulley in place of the AC pump. Yes it will fit the SB 400.
I may have one off a 95. I'll check monday and let you know.
Thanks to all, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 06-26-2012, 08:14 AM   #28
dbstepside
dbstepside's Avatar
i would be intersted in a big block set as well.
dbstepside is offline   Reply With Quote
Old 07-01-2012, 10:32 AM   #29
DD1
Hi, do you have any left? Also, where do I get the belt? If I want to use a local auto part store like auto zone, what would I ask for?
Also, I have an alternator and PS pump for a 350; would I be able to use those, or do I need to get the ones wit your kit?
DD1 is offline   Reply With Quote
Old 07-01-2012, 01:37 PM   #30
tll74
"Junkyard Dog"
tll74's Avatar
Yes I still have them. You would need to use the kit complete. Your alt and P/S will not fit. Thanks, Tom
Old 07-05-2012, 01:19 PM   #31
tll74
"Junkyard Dog"
tll74's Avatar
ttt
Old 07-05-2012, 05:51 PM   #32
huey-71
huey-71's Avatar
PM sent
huey-71 is offline   Reply With Quote
Old 07-05-2012, 07:21 PM   #33
clb1024
clb1024's Avatar
Originally Posted by tll74 View Post
The kit includes RH AC bracket, AC R-4 pump R134 or R12, LH Alt-power steering bracket, 100A Alt, power steering pump, belt tensioner, fan clutch, fan blade, clutch mounting studs & nuts, water pump pulley, crankshaft pulley w/bolts, braces and nuts & bolts.
You will need a new water pump, belt, and pig tail for alt.
What year truck are the alt, PS pump, and A/C pump out of? Also what would shipping be to 32068(home) or 32257(bussiness addy)? Also are they new items or tested used ones?
Favorite quote: "I'm sick and tired of being sick and tired BĦħ@h!" - Drunk guy in one of my accounts
Rides:
67 Chevy C10 LWB Stake Bed(in bad shape)
04 Miti Endeavor AWD(wife's ride)
76 Dodge D100 Club Cab(Hand-me down from my Grandfather)
clb1024 is offline   Reply With Quote
Old 07-06-2012, 06:08 PM   #34
tll74
"Junkyard Dog"
tll74's Avatar
Shipping to the bussiness is 63.80, I have several of these off 89-95. Thanks, Tom
Old 07-06-2012, 07:34 PM   #35
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Hey Tom,
What water pump does this use and can I find it locally? How much wiring trouble to replace old ext. reg. alt? Thanks
TobyArnot is offline   Reply With Quote
Old 07-06-2012, 08:01 PM   #36
Lee H
Lee H's Avatar
As far as parts go just pick a year, 89-95 pick-up C1500 or K1500. All the parts (water pump, idler pulleys, power steering pump, alternator, A/C compressor, pulleys, drive belt) for these serpentine systems are interchangeable.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-06-2012, 08:27 PM   #37
clb1024
clb1024's Avatar
I'm subscribing. Would love to get a setuo to finish my 350, but the little one's 1st birthday is very close and we have to have a party. I'll definitely be hitting you up when I get the funds.
Thanks,
Chris
Rides:
Old 07-07-2012, 02:34 AM   #38
tll74
"Junkyard Dog"
tll74's Avatar
Originally Posted by TobyArnot View Post
Hey Tom,
The water pump is very common that any parts house would stock. It fits any 88-95 C/K truck and some passenger cars. A sure way to identify the correct pump is that it will NOT have any accessory holes. Nothing bolts to the pump on these serpentine setups. These alternaters require a "exciter wire" which is a key on hot wire. You may want to consult a wiring wizard be sure how to do correctly.
Thanks, Tom
Old 07-07-2012, 04:43 PM   #39
huey-71
huey-71's Avatar
Got your payment info, will send payment out Monday. Thanks again!
Old 07-09-2012, 05:49 PM   #40
huey-71
huey-71's Avatar
Payment went out today!!
Old 08-09-2012, 02:59 PM   #41
SunSoaked
SunSoaked's Avatar
Tom,
Do you have a SB kit available? I'm interested in a kit but without the following:
-No fan or clutch (I'm using electric)
-No A/C Compressor (I'm using Sanden Comp)
I'm using an 87 (late model with two bolt attachment) power steering pump. It's hard to tell in your photo but I think its the same? I want to keep what I have as it's part of a hydroboost system and the pump is brand new. I will need the pulley for it though.
My block/heads are newer w/accessory holes.
Thoughts? Price?
Thanks, Mike
SunSoaked is offline   Reply With Quote
Old 08-10-2012, 02:34 AM   #42
tll74
"Junkyard Dog"
tll74's Avatar
Originally Posted by SunSoaked View Post
Tom,
Thoughts? Price?
Thanks, Mike
Hi Mike, your 87 pump will not fot this bracket kit. The can (reservior) is timed wrong for the bracket. I could do it with a dual return pump assembly or just the reservoir to accomadate your hydro boost brakes. Also you could put your new pump in this reservior. The fan and clutch in these kits are basicly a gift as the value is in the AC, Alt, and brackets. I could take off 50.00 if I keep the AC pump.
Thanks, Tom
Old 08-10-2012, 04:56 PM   #43
jrdv
jrdv's Avatar
I am interested in one, but I have a 4x4. How did your friends 2wd shroud work out?
jrdv is offline   Reply With Quote
Old 08-10-2012, 06:52 PM   #44
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Is the ps pump used?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 08-10-2012, 09:29 PM   #45
tll74
"Junkyard Dog"
tll74's Avatar
Just got a BBC set up. 325.00 plus shipping
Same as above Lets give laplander a chance to respond.
Humm...good question. I'll find out.
Smitty
Yes the pump is used.
Thanks Guys, Tom
Old 08-12-2012, 12:19 AM   #46
dbstepside
dbstepside's Avatar
if it gets to me i'd be intersted in the bbc set. also could you put pics of the current setup and also let me know what year it's from.
Old 08-12-2012, 12:24 AM   #47
dbstepside
dbstepside's Avatar
also shipping to 42071 if needed i could use a business address.
Old 08-12-2012, 01:35 AM   #48
tll74
"Junkyard Dog"
tll74's Avatar
The sbc kits run about 60.00 shipping. The bbc kits have cast iron brackets so it will weight more therfor shipping will be more, I'm guessing about 75.00. This will be off a 94-95 454. I can get pics Monday. I actually have two of these so if you want one it's yours. Thanks, Tom
Old 08-15-2012, 09:56 AM   #49
dbstepside
dbstepside's Avatar
any pics of a bbc setup, also what style p/s pump comes with this kit? also would you happen to have the air comp. delete pulley if so would setup be less $ without the compressor?
Old 08-15-2012, 04:24 PM   #50
rushingg149
rushingg149's Avatar
Cool Re: Serpentine belt conversions
I'm looking for a set to put on a 1970 Chevy 1 ton with a 396 BB. What do you have that would work?
rushingg149 is offline   Reply With Quote
