Old 02-06-2012, 08:13 PM   #26
UPNADM
UPNADM's Avatar
Re: 1981 Chevrolet C50 Pick-up Conversion
Here is how the truck is currently sitting.
Planning to get the box in next and get it prepped for paint.
Then shorten the drive line and prep cab.
UPNADM is offline   Reply With Quote
Old 02-06-2012, 08:23 PM   #27
UPNADM
UPNADM's Avatar
In between the body prep, I have been sandblasting small pieces.
Old 02-07-2012, 12:16 AM   #28
Leedogg
sweet!
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline   Reply With Quote
Old 02-07-2012, 07:40 PM   #29
UPNADM
UPNADM's Avatar
Just found a 5 speed transmission out of a split rear end medium duty truck not to far from my house. The truck currently has a farmer 4 speed.
50 mph = 3100 rpm.
Also made a trade for a regular bench seat for my Bostrom and buddy seat combo. Good riddance.
As far as I know the transmission swap should be a non issue. Any thoughts...
Old 02-07-2012, 07:47 PM   #30
JRANGER
JRANGER's Avatar
this should be cool
JRANGER is offline   Reply With Quote
Old 02-07-2012, 08:29 PM   #31
J Knight
J Knight's Avatar
This is going to be bad azz! Im curious, what is different about the firewall and floor of the c50 and c60 trucks? Does it have the same cab mounting points as a c10,20,30? Ive always wondered if I could use a c50,60 cab on a c10 frame for the small back window.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 02-07-2012, 08:36 PM   #32
UPNADM
UPNADM's Avatar
Thanks for the compliment, I am looking forward to it being done.
The cabs are quite different, and in my opinion you would be up for some major modification to mount on a traditional frame.
The floor in the cab is flat from front to back.
The firewall is also recessed. Above photos show it.
Old 02-07-2012, 08:56 PM   #33
J Knight
J Knight's Avatar
If you take the cab of the frame post some underside and firewall pics if you can.
John
Old 02-07-2012, 09:03 PM   #34
JRANGER
JRANGER's Avatar
WOW< I cant even paint my house with a roller that well lol
Old 02-07-2012, 09:13 PM   #35
matchstick321
matchstick321's Avatar
Dude that is sweet now I want one!
matchstick321 is offline   Reply With Quote
Old 02-07-2012, 09:17 PM   #36
UPNADM
UPNADM's Avatar
I was a long time finding a suitable project truck. I was originally going to buy a medium duty with a Detroit Diesel, but after countless less than favorable reviews of that engine and my limited experience with diesel engines I decided to go with gas.
The next thing was finding a truck that was not completely rotted. That was a bit of a challenge. I do not mind a bit of body work, but cab corners and rockers are not my forte.
My next thing was finding a truck with budd style wheels and not Dayton style wheels. After about a year of searching this truck appeared. And so the story goes...
Old 02-07-2012, 09:23 PM   #37
matchstick321
I wish I had the time and money to do these kinds of projects! I need to find me a sugarmomma.
Old 02-07-2012, 11:27 PM   #38
J Knight
J Knight's Avatar
A little inspiration.
http://houston.craigslist.org/cto/2820130221.html
John
Old 02-09-2012, 06:47 PM   #39
UPNADM
UPNADM's Avatar
Took some photos for you to see of the cab floor and firewall...
Firewall is kind of forward over the engine. The floors are flat.
Old 02-09-2012, 06:55 PM   #40
UPNADM
UPNADM's Avatar
Moving forward...
Slow day, so I came home early and power washed a bunch of mud and dirt off my dually box. The underside of the box is a little punky for my liking.
A question... Can I modify a fleet side box to make it a dually box side. Has anyone done this before. Any suggestions.
After that I got eager and cut the dump box off. See photos...
The truck frame is pretty clean considering its a 30 year old Ontario truck.
Old 02-09-2012, 06:57 PM   #41
UPNADM
UPNADM's Avatar
I look forward to the day when its complete... Ha..
Old 02-09-2012, 09:24 PM   #42
JRANGER
JRANGER's Avatar
good work so far man....
Old 02-09-2012, 09:35 PM   #43
ghettoluxury
ghettoluxury's Avatar
It is easy, edually bed is just a chopped up fleetside. There is a thread here called dually bed with out fenders, or something like that. Just look for it and you will see the difference.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-10-2012, 01:41 AM   #44
matchstick321
http://67-72chevytrucks.com/vboard/s...d.php?t=486779
Make sure to put some big mudflaps on it!
1979 chevrolet k-20 "O'l Blue" 350 muncie 465. Project in process.
Old 02-11-2012, 08:20 AM   #45
truckfan
truckfan's Avatar
I'll lurk
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 02-11-2012, 08:45 PM   #46
J Knight
J Knight's Avatar
Thanks for the firewall/floor pics, it looks like the front cab mounts are the same as a c10 but I didnt see the rear cab mounts.
You mentioned cuting the frame to shorten the wheelbase, a common technique used on big class 8 trucks is to move the suspension and crossmembers forward, remounting it to the frame and cut the excess off of the end of the frame rather than cut a section out of the middle then welding it back together. Just thought I would share that as an option.
John
Old 02-11-2012, 09:17 PM   #47
UPNADM
UPNADM's Avatar
Absolutely my man. That is what I plan to do, got the truck in my shop now and that is soon to come on the list.
Old 02-11-2012, 09:33 PM   #48
UPNADM
UPNADM's Avatar
I spent the morning organizing and moving some stuff around in my garage. Finally got the truck into the shop.
Started stripping paint on the cab. I hope to get it in primer this week.
I will also be pulling the engine and transmission this week. I will be sandblasting all covers and brackets.
I am painting the truck yellow... What are peoples thoughts for block color. I am leaning towards keeping the blue.
Old 02-12-2012, 10:25 PM   #49
UPNADM
UPNADM's Avatar
Another good day's work.
Got up and pulled the engine out of the truck. Degreased the engine and stripped it to the long block.
Wire buffed the block. Tomorrow I will blast the intake, valve covers, timing cover and oil pan. I will also be blasting all pulleys and brackets.
Will pick up new gaskets, plugs, wires cap and rotor tomorrow.
Decided on Ford Blue for the engine, yes I know that may be a little blasphemous but I like the bright blue better.
Now that the engine is out, I will be degreasing the inner frame rails, and other spots I missed on the front end. Then I will be hitting it with a high gloss black.
I will also be prepping the firewall and changing the color to bright yellow.
I hope to have most of this done during this week.
I also ordered a pair of block hugger headers last night, hoping that works out...
Old 02-12-2012, 11:56 PM   #50
ghettoluxury
The Ford Blue will really pop against the Yellow. I did the engine bay in my old civic Ford Blue and Daytona Yellow. They complement each other so well.
