01-28-2012, 02:03 PM | #26 |
Re: Another C20 8-lug wheel question.
Here is mine, 16x9.5 and 285/75 tires, not alot of room left but with stock sagging(broke in) springs it doesn't rub anywhere
1992 Jeep Cherokee 4.0 AUTO 1972 C10 350/350 1971 C1500 350/350 1970 C20 396/400 |
01-28-2012, 03:16 PM | #27 |
Roto Reuter thats the name...
Black rims with black truck looks real good. Like that tire size.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
01-29-2012, 11:33 PM | #28 | |
http://rochester.craigslist.org/pts/2805359875.html
01-29-2012, 11:40 PM | #29 | |
01-29-2012, 11:45 PM | #30 | |
01-30-2012, 12:05 AM | #31 |
H2 caps are ugly (my opinion) and won't clear your rear axle. They may clear the front but I don't think so. The lug nuts, if using the Chevy caps, are available from a couple vendors on eBay. They are conversion lug nuts with the inner and outer threads. If you don't use Chevy caps (or any others that attach to the lug nuts) any lug nut with the right taper will do. As I recall you have a 69 or 70. They had 1/2" studs. 71 and up had 9/16" studs. If you converted to disc brakes, you probably have 9/16.
01-30-2012, 12:39 AM | #32 |
More info....
Here are 3 lug nut sellers on eBay: http://www.ebay.com/itm/300655875649...84.m1423.l2649 http://www.ebay.com/itm/330609381394...84.m1423.l2649 http://www.ebay.com/itm/380398436903...84.m1423.l2649 I bought mine here, but his prices have jumped. The only Chevy or GMC caps that I know will fit properly into the recesses in the H2 wheels are the 2001-2006 and 2007 Classic 3/4 ton truck aluminum wheel caps. All others are too big. |
01-30-2012, 12:51 AM | #33 | |
BTW I have not yet installed front discs, but I'm planning to do it soon. Looking at a couple of suppliers for 8-lug kits (CPP or POL).
01-30-2012, 01:22 AM | #34 |
I bought my caps on eBay and they were new OEM. I put blue painters tape over the gold bowtie on the one in the picture to see how it would look with the period correct color. I am now looking for for something for a permanent fix. There are a bunch of reproduction cap sets like this on eBay now, but no new OEM caps. They have an opening bid price of $80 or $100 buy it now for 4.
10-22-2016, 02:15 PM | #35 |
ok so I am looking for 17 inch wheels to put on my 64 panel, any suggestions?
10-22-2016, 02:22 PM | #36 |
here is a picture of what is on the panel, from what I know these are trailer wheels and should not be used, only for trailer, that was what I have been told, problem, I have new 17 inch tires, that were given to me, so that is why I want to put 17's on it
03-26-2019, 01:42 PM | #37 |
Here ya go! These are BFG ALL Terrain 285/75/16.
I want to go back to original steel wheel with smaller tires. Want to buy em? |
03-28-2019, 01:23 AM | #38 |
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
03-28-2019, 08:31 AM | #39 |
After seeing the resurrection of my original thread, I realized that I never followed up with pictures of my '69 C20. I ended up installing 285/70-17 tires on Hummer H2 wheels with Chevy caps. The truck has since been sold.
C20 with H2 wheels Comparison of original tire size to last tire size. H2 wheel with Chevy cap
03-28-2019, 02:36 PM | #40 |
Here's an update on mine. I accomplished my goal of making the Chevy center caps resemble the centers of the original hubcaps (shown for comparison). I finished the restoration in 2015. A lot has changed in 7 years!
04-25-2019, 08:51 AM | #41 |
Do the H2 wheels bolt right on, no adapter or spacers necessary?
04-25-2019, 12:16 PM | #42 |
35's X 12.5" on 16" wheels on my 72 K20.
1972 K20 2004 Chevy Aveo 2011 BMW X5 Diesel 2018 Chevy Silverado Diesel U.S. Air Force Retired - 1983-2017 |
04-25-2019, 01:52 PM | #43 |
They bolt right on. Center caps may be a problem depending on your rear axle.The Chevy caps I used fit on my Eaton axle. I believe they will require spacers if you have a Dana. Member davepl should be able to provide a definitive answer. The only Chevy center caps I found that fit into the wheel recess are those from the early 2000s 8 lug aluminum wheels.
04-25-2019, 02:06 PM | #44 | |
