Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-14-2012, 12:47 AM   #26
redsled87
redsled87's Avatar
Re: My BBC couple pictures.
Originally Posted by Blue Rat View Post
I ended up going with the M77 pump. Changed out the spring in favor of the high pressure spring. Had the M77HV pump but changed my mind on it. Still have it setting on the table in the box.
I have always used the M77 an never had a problem. "So if it's not broke don't fix it". I heard the argument on both sides. I decided to go with what I know an have always done.
I also have a M77 pump for my 496. The spring that you installed, is that the optional one that comes with the pump? I know SBC's better than the BBC's. I remembered that you don't want a HV oil pump in them either.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 03-14-2012, 06:44 AM   #27
Blue Rat
Yes that's the one I installed. That's the other the extra spring that comes with the M77 pump it's the high pressure spring.
Blue Rat is offline   Reply With Quote
Old 03-14-2012, 12:28 PM   #28
redsled87
redsled87's Avatar
What kind of pressure do you normally get out of it?
60' 1.49
1/4 10.93
MPH 120
Old 03-14-2012, 04:24 PM   #29
mud.man.rj
mud.man.rj's Avatar
Thats funny I always use the M77 pump and only had the extra spring come with the small block pump not the Big block pump, the spring doesn't change volume though only adds some pressure which is alright on the BB. My BB idles at about 18psi operating temp with the M77 stock spring.
mud.man.rj is offline   Reply With Quote
Old 03-14-2012, 08:20 PM   #30
Blue Rat
I figure between 25-30 psi at idle an 65-80 on the other end with the HP spring. Of course it also depends on clearances.
Was going to work on it this evening but worked over some an just did not have it in me when I got home.
Old 03-16-2012, 06:39 PM   #31
Blue Rat
Did everyone see that nice looking timing cover? Well, it is coming off this coming week it will not match up with the Milidon oil pan. Then it is going back where it came from. Have a Milidon cover on the way. Should be here Tuesday or Wednesday this coming week.
By the way it is not a name brand cover. Told him I would try it.
Old 03-25-2012, 02:15 PM   #32
Blue Rat
Well got the new cover in an it fits perfect. But, going to have to buy a another cam button. I have bought my last off brand timing cover. No pictures, but should have some middle of week or this coming weekend. I went to the round track racing last night for the first time in 15 years an it kind of got me stirred a little.
Old 03-27-2012, 06:33 PM   #33
Blue Rat
Well, could not find a cam button close to home. So, going to make a trip to the Speed Shop saturday an pick up one. He did not have any either. He said he would have some by this weekend.
Old 04-01-2012, 09:04 PM   #34
Blue Rat
Well my camshaft end play is set. Put the timing cover on.
Old 04-03-2012, 07:53 PM   #35
Blue Rat
Re: Picture update
Old 04-04-2012, 12:53 PM   #36
Blue Rat
I get to start on the top side this weekend.
Old 04-07-2012, 05:01 PM   #37
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Went to put my my timing chain cover on it it would not fit right so I could set my camshaft end play. So going try an get time to work on that this week.
Man....should have went with the Cloyes quick button timing chain cover. Those things rule! I had my roller endplay set and final in about 7 minutes.
prostreetC-10 is offline   Reply With Quote
Old 04-07-2012, 06:57 PM   #38
Blue Rat
You are not going to believe this but was thinking about what you did the whole time. Just did not want to spring for that money. But it is done now. Never got time to work on it today. May work on it tomorrow after easter stuff is finished.
Old 04-07-2012, 07:00 PM   #39
prostreetC-10
My Carbon Footprint
As long as it's done and done right, stock chrome looks just fine!
Old 04-07-2012, 08:09 PM   #40
Blue Rat
That is the Milidon cover to match that pan. It seems a lot thicker an more heavy duty than the stock cover that I recall an it has the wear plate. It was actually close. Did not need a lot of work.
Old 04-09-2012, 02:24 AM   #41
BossHogg69
motor exploder
BossHogg69's Avatar
Hey Blue Rat, where at in Arkansas are you?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-01-2012, 04:07 PM   #42
Blue Rat
I still got your number call you when things slow down a little.
Old 05-03-2012, 11:02 AM   #43
BossHogg69
motor exploder
BossHogg69's Avatar
Whenever you're ready! I'm on my days off from work right now and I'm bored out of my mind!
Adam
Old 05-21-2012, 08:54 PM   #44
Blue Rat
I checked my rocker arm geometry yesterday afternoon. I went back an checked it again this evening. I had a light bulb come on in my head. If you take a white LED light for that matter most likely any light. Shine toward you from the backside of the rocker arm. Then put a sheet of copy white paper between the light an the rocker arm. You can see where the roller on the rocker is making contact on top of the valve as clear as day.
Old 05-26-2012, 12:42 PM   #45
Blue Rat
My Smith brothers pushrods came in yesterday.
Old 05-26-2012, 03:05 PM   #46
BossHogg69
motor exploder
BossHogg69's Avatar
It won't be long and you'll have that baby fired up!
Adam
Old 07-08-2012, 09:09 PM   #47
Blue Rat
Well work an the temps being high have kept me busy. I did manage to get all the head studs in today. Heads next!
Old 07-29-2012, 11:55 AM   #48
Blue Rat
I put the heads on it this morning.
Old 07-29-2012, 12:01 PM   #49
mud.man.rj
mud.man.rj's Avatar
Nice Brodix heads, what heads are they CC wise and what do they flow are they setup for low to midrange or mid up. Looks like a large oval port.
Old 07-29-2012, 12:39 PM   #50
Blue Rat
They are 270cc suppose to be good from idle to about 6800. I am putting the Brodix HV 2007 intake on it.
