Old 03-06-2012, 02:32 PM   #26
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Project: LS1ick68
Lookin' good so far! Making a nice truck that much nicer
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-09-2012, 02:35 PM   #27
68Stepbed
68Stepbed's Avatar
Progress!! I was getting some floor work done on our house, so I took a vacation day yesterday. I don't really like bugging people or getting in their way when they're working, so I worked in the garage.
I pushed the truck out so I had more room. I cleaned and prepped the block deck surface. Then, I cleaned, prepped, and masked the block and heads for paint, primered and painted them.
With etching primer.............
.............and, with fresh paint.
I also got in some more new parts.
ECE 2" drop springs
New aluminum radiator.
Figured I better test fit the radiator. It fits!!
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-09-2012, 02:47 PM   #28
nibs
JRods Garage
nibs's Avatar
I really like that radiator... Where did you get that? You gonna be ok running the coolant hose all the way to the other side?
Orange Julius-My dropmember'd, LS'd, SWB street machine...
nibs is offline   Reply With Quote
Old 03-09-2012, 03:00 PM   #29
68Stepbed
68Stepbed's Avatar
I got the radiator from Dave's Truck Parts in Claremont, NC. It cost me $260+$18 for shipping.
Matt
Old 03-09-2012, 03:52 PM   #30
nibs
JRods Garage
nibs's Avatar
Is it a direct fit for our trucks? I just wish the top hose would be on the pass. side
Old 03-09-2012, 04:02 PM   #31
funkytechmonkey
funkytechmonkey's Avatar
I am glad I finally found this.... Good job so far. Its good to see that this motor will actually be put to good use instead of collecting dust in my garage.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 03-14-2012, 08:36 AM   #32
68Stepbed
68Stepbed's Avatar
Yes, the radiator is a direct fit. As for the top hose, I plan to use a stock 99-06 truck upper hose. The rad. outlet on trucks is on the drivers side.
Matt
Old 03-14-2012, 08:47 AM   #33
68Stepbed
68Stepbed's Avatar
Got my intake in and painted. I also cut off that goofy looking mounting tab on the front runner tube.
Do you guys like the Gray/aluminum two-tone, or all aluminum color?
My camshaft also came in. It's slightly used, but It's a custom COMP grind. 232/240 dur. @.050 .580/.580 lift 110+2
My POL tubular engine towers also finally arrived.
I've recieved a few other parts not pictured.
-Carter electric fuel pump
-used truck accessory drive system(it's being cleaned)
-oil pressure and water temp sender adapter fittings and an oil level sensor plug from Speedway
I'm hoping to decide on new valve covers today and order them, and go pick up all the gaskets I need today.
Matt
Old 03-14-2012, 09:11 AM   #34
funkytechmonkey
Looking good! The two tone gives it a little color. Id stick with the two tone
Old 03-14-2012, 10:01 AM   #35
gringoloco
A guy with a truck
gringoloco's Avatar
Nice cam specs- should lumpy and high-winding. What's the part number on that oil level plug?
Looking good!
-Chris
Old 03-14-2012, 12:08 PM   #36
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
cam is close to mine with just a little less lift. Should make good power for you!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-14-2012, 03:25 PM   #37
68Stepbed
68Stepbed's Avatar
Looking good!
http://www.speedwaymotors.com/LS1-Lo...ugs,35277.html
Matt
Old 03-17-2012, 12:22 AM   #38
68Stepbed
68Stepbed's Avatar
The big brown truck showed up again today!!
I was going to try to do something with the stock valve covers, but I just wasn't "feeling it" with them. So, I decided to bite the bullet and get these.
I'm certainly Feeling it, now!
Also got some plug wires and boots.
Got to deliver fuel somehow!
Test fit! This is a 570 Street Avenger that I had on my old 350. I have a feeling it may be a bit wheezy on this LS1, but I'm going to stick with it, at least until the initial tuning and first drives are done, then I may upgrade.
I also went and picked up all the gaskets I'll be needing.
Got my water pump, dampener and PS pulley(not shown) painted. I'm in the process of cleaning the truck alt./PS pump bracket. I may see if I can do some custom bracket fab, though to get a cleaner look. I'll make that final decision soon.
BTW, I'm having a 700R4 transmission built with a 2800 stall converter. I'll probably be switching out the 3.07 gears to 4.10 gears.
Matt
Old 03-17-2012, 01:37 AM   #39
funkytechmonkey
It's coming along nice.
Old 03-17-2012, 09:20 AM   #40
68Stepbed
68Stepbed's Avatar
I'm fixing to drop in the engine for a test fit today.
Matt
Old 03-17-2012, 01:11 PM   #41
68GMCCustom
motor looks sweet......you're going to need more carb tho!
Kurt -
Old 03-17-2012, 07:26 PM   #42
Lower
Lower's Avatar
Im interested in your old cam if you are getting rid of it, its looking great and your making good progress. If I would have seen those mounts and how fast you got them I would have went with them, its been a week already and cpp just shipped mine today.....
BTW your truck is definitely clean
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 03-17-2012, 07:28 PM   #43
Lower
Lower's Avatar
Sorry double post
~Jon
My build thread
Old 03-17-2012, 10:34 PM   #44
68Stepbed
68Stepbed's Avatar
Got her set in, even if for only and hour or so. I was checking for all clearances. The truck oil pan hangs about 1 1/4 - 1 1/2" below the crossmember. I'm going to do some checking around, but I may switch to an F-body pan.
Matt
Old 03-17-2012, 10:42 PM   #45
mooseknuckles
mooseknuckles's Avatar
that looks awesome man!....I dont like the news about your pan tho...
mooseknuckles is offline   Reply With Quote
Old 03-17-2012, 10:57 PM   #46
68GMCCustom
mine does about the same...haven't decided how to correct it but it isn't low enough to cause a problem with the area speed bumps...so far.
Kurt -
Old 03-21-2012, 08:30 AM   #47
CrazyJesster
CrazyJesster's Avatar
looks like a nice build going here man
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842
CrazyJesster is offline   Reply With Quote
Old 03-21-2012, 09:48 AM   #48
Custom 68
Custom 68's Avatar
my pan was too low also so I did the swap to the camaro pan. Helped a ton on clearance. Looking good.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-21-2012, 12:32 PM   #49
68Stepbed
68Stepbed's Avatar
Yeah, I think I'm going to swap to an F-body pan. Speed bumps don't worry me, it's the uneven surfaces if I have to pull off the pavement or drive up on a curb.
Matt
Old 03-23-2012, 10:03 PM   #50
CROWN
Are you going run those manifolds?.. Please tell me no!! Not bashing you but this is to nice of a build to me to run those, not to mention you won't get the full potential out of your cam with them.
CROWN is offline   Reply With Quote
