Old 03-18-2012, 02:11 AM   #26
KY Colonel
KY Colonel's Avatar
Re: Grant steering wheel install info
Ne wheel installed (finally uploaded pics)
Thanks again RRR, couldn't have done it without ya!
1970 K20 Custom 427/TH400/PS/PB and a dash of badass!
I was made in America, my truck was too...4 years before me.
KY Colonel is offline   Reply With Quote
Old 03-18-2012, 09:12 AM   #27
RRR18
RRR18's Avatar
Looks Great! Glad that I could help in any little way. After all that this forum has done to help me this little posting of mine was least I could do as some form of payback.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 03-26-2012, 11:13 PM   #28
Snake41_83
Snake41_83's Avatar
RRR, I've been sitting here scratching my head about this now for a while. I had a hunch the problem was somewhere between the cancelling cam and the hub, but never thought to put something between them. Genius! I'm going to throw that in there tomorrow and see if it fixes the problem.
Thanks for the help, I was pulling my hair out!
1972 Chevy K5 Blazer CST, 350
USAF Herk Driver
Snake41_83 is offline   Reply With Quote
Old 03-26-2012, 11:43 PM   #29
aventur1
aventur1's Avatar
Installed mine last weekend...although I must have lucked out and did not use the bud gasket and all worked great. I did refer to your help. About the only thing I had to do was make the hole where the pin goes into the stock horn thing where the short spring goes, I used a #2 phillips screw driver and it made it the exact size for the pin. Other than that Thanks for your post, made it easier for me.
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline   Reply With Quote
Old 03-27-2012, 12:12 AM   #30
RRR18
RRR18's Avatar
It's amazing how something so little and stupid can piss ya of so bad ain't it?
'67 BAD IDEA
Ryan
Old 03-27-2012, 06:41 AM   #31
FLDBRED
Great Post!
FLDBRED is offline   Reply With Quote
Old 05-01-2012, 11:33 AM   #32
ryanmctee
ryanmctee's Avatar
Subscribed. Hooked up my battery last night and my horn blows non stop same as described here. I installed the wood grant steering wheel a couple of months ago and just got power to the truck. I will do the cardboard in between as well. Thanks for posting!!
Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=512620
ryanmctee is offline   Reply With Quote
Old 05-01-2012, 02:17 PM   #33
RRR18
RRR18's Avatar
Something tells me only beer box cardboard works! Haha. Ok, maybe I'm just making that up but, it gave me another reason to tear up a box of beer and what was inside it.
'67 BAD IDEA
Ryan
Old 03-09-2013, 09:28 PM   #34
SuperC10Tex
SuperC10Tex's Avatar
Thank You RRR18 !!! I took on and off my new Grant steering three times today (horn would not stop blowing). I was going to call Grant on Monday....your cardboard gasket did the trick!!!
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
Old 03-09-2013, 09:30 PM   #35
RRR18
RRR18's Avatar
Glad I could help!
'67 BAD IDEA
Ryan
Old 06-30-2013, 08:33 AM   #36
calvin78612
calvin78612's Avatar
Thanks for posting this,that long spring was pissing me off.It seems my hub fits better with the top pointing down.I will try it again in a few days.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 02-15-2014, 11:00 PM   #37
gdiwicker
Thanks! This helped me finally get my new wheel installed. After all the hassle of one part interfering with another's operation, having this already spelled out was a huge help. Hopefully I've had to pull my steering wheel for the last time!
gdiwicker is offline   Reply With Quote
Old 02-16-2014, 12:12 AM   #38
cool68
great post Thanks. before starting double check to make sure that the front wheels are lined up straight forward and that they are in same position when you finish.
cool68 is offline   Reply With Quote
Old 02-16-2014, 12:25 AM   #39
Tillik
Tillik's Avatar
Subscribed
James B.
1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful)
1971 Chevy Fleetside Shortbed 4X4 (White & Rough)
Tillik is offline   Reply With Quote
Old 02-16-2014, 02:33 AM   #40
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
awesome info . now I've got finish the contents of my gasket and things should fall into place. hahaha
FRANKENSTEINC10 is offline   Reply With Quote
Old 02-16-2014, 09:27 AM   #41
Hugh Mongus
I had the same problem when I installed my steering wheel. I drilled a small hole in the copped band on the bottom of the plastic horn contact assembly and secured a small wire with a screw to the contact band then ran the wire through the plastic tower, hub, ect. to connect it to the horn button. I tossed the spring and plunger.
Hugh Mongus is offline   Reply With Quote
Old 07-25-2014, 10:03 PM   #42
JonnyC10
The cardboard goes between the turn cam and Grant hub? I was looking at mines and made the cardboard piece and noticed that the Grant hub doesn't even make contact wit the brass on the turn cam anyway... Is that what the purpose of the cardboard is? If so, I don't see what the cardboard is doing... What am I missing? Installing a Grant 377. Have the 3162 kit and I really need help figuring this out.
JonnyC10 is offline   Reply With Quote
Old 09-08-2014, 04:56 PM   #43
POPO1984
POPO1984's Avatar
Good info
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 09-08-2014, 07:08 PM   #44
WiggyHD
RRR, that's the wheel I just installed. Haven't checked the horn yet. Wiring is a mess. It is a comfortable wheel though!
Mark
Retired Air Force/Disabled Vet
1969 Chevy C-10, On the way to greatness!
WiggyHD is offline   Reply With Quote
Old 09-08-2014, 07:18 PM   #45
RRR18
RRR18's Avatar
It's a pretty damn comfortable wheel for me.
'67 BAD IDEA
Ryan
Old 09-08-2014, 07:20 PM   #46
stefan
New Member
RRR whats the part number for that steering wheel i like it,Thanks
stefan is offline   Reply With Quote
Old 09-08-2014, 09:47 PM   #47
RRR18
RRR18's Avatar
Here it is.....
http://m.summitracing.com/parts/grt-457
'67 BAD IDEA
Ryan
Old 12-23-2014, 11:16 PM   #48
hdff
hdff's Avatar
Originally Posted by RRR18 View Post
Ya. I left that out on accident.
Good info, thanks. Looks good!
Subscribed for future help
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
