Old 04-19-2012, 09:57 AM   #26
Last_Paladin
Re: Kooks 1 7/8 headers+ stage2 dropmember= WINNING
Is there any chance you could measure from the center of the bolt on the Xmember gusset to the engine block on the DM engine mount? I got mine in today and they do not fit. Looks like I need to go up with the engine.
Last_Paladin is offline   Reply With Quote
Old 04-25-2012, 12:54 AM   #27
c10seconds
c10seconds's Avatar
Could you post a pic of what you are having issues with? Also my dropmember is the one that does not require the c-notches for the rack so it may be a little different including the motor mounts
c10seconds is offline   Reply With Quote
Old 04-25-2012, 08:50 AM   #28
Last_Paladin
I ordered some from Nathan. You're right, in that we're on different Dropmembers.
Old 05-19-2012, 11:01 AM   #29
Last_Paladin
Mine are scant MM away from the frame rails.
Old 07-19-2012, 08:51 AM   #30
paul66c10
paul66c10's Avatar
Did you ever get the steering linkage routed? wondering how this turned out im in the process of looking for headers for my 86 with a extreme dropmember and thinking these may work just wondering about the steering linkage.
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy
paul66c10 is offline   Reply With Quote
Old 07-22-2012, 06:26 PM   #31
c10seconds
c10seconds's Avatar
I havent got that figured out yet as I havent had much time to work on the truck. Its gonna be a tight fit but it will work out.
Old 11-21-2012, 08:00 PM   #32
Revolution
Any more updates on these? I was wondering if I could see a shot from below. I am a kooks dealer and we are doing a 67 c10 for a customer he would be thrilled as would I if these work out for his 408
Revolution is offline   Reply With Quote
Old 11-30-2012, 04:43 AM   #33
c10seconds
c10seconds's Avatar
Sorry for the delay...
Here are a couple extra pics so you can get a better look at clearance. The collectors sit much higher with the trans xmember mounted
Old 11-30-2012, 03:29 PM   #34
Hart_Rod
Hart_Rod's Avatar
It is the mild dropmember and as far as I know, it leaves the motor in stock location.
For the guys with the extreme dropmember the DT 's didn't work because of the motor being raised. There are clearance issues at the firewall. They probably would have worked for me but I just decided on the kooks. The driver side collector is slightly lower than the passenger but I don't think it will be an issue.
I haven't checked to see if the stock inner fender will work. Would be great if they did but Ill have to check with Nate
Which Doug Thorleys wouldn't work with the extreme DM, the small tubes or the big tubes?
Hart_Rod is offline   Reply With Quote
Old 11-30-2012, 03:39 PM   #35
c10seconds
c10seconds's Avatar
The big tube DT headers hit the firewall. You ready to buy some big brakes?
Old 11-30-2012, 03:49 PM   #36
Hart_Rod
Hart_Rod's Avatar
So the small tubes work OK? Man, I would love to have the brakes, BUT, I have 18s on the front of my truck, and I'm not putting $5k worth of brakes on my sons truck....
Old 11-30-2012, 05:23 PM   #37
Revolution
Thanks so much for the pictures. I am going to order a set from Kooks tomorrow for our customer they look great. If anyone on the thread needs or wants a set let me know I will gladly hook it up for anyone on the forum I am loving this build I have only done later silverados till now but I am loving this build.
Old 12-01-2012, 08:42 AM   #38
smartass12
smartass12's Avatar
I didnt see a clear answer (i am blind though) so do these kooks work with the extreme dropmembers??
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 12-02-2012, 10:30 PM   #39
c10seconds
c10seconds's Avatar
From this post I would say the kooks wont work with the extreme dropmember. But you could try sending last_paladin a message for more info.
Old 12-02-2012, 10:32 PM   #40
c10seconds
c10seconds's Avatar
Im not sure about the small tube DT headers. If the big ones didnt fit then i dont see why the small ones would but you never know.
Old 12-02-2012, 10:39 PM   #41
BigShoe24
True Addiction
BigShoe24's Avatar
c10seconds, sweet ride dude. What wiring harness are you using?
RCC
BigShoe24 is offline   Reply With Quote
Old 12-02-2012, 11:21 PM   #42
Last_Paladin
Im not sure about the small tube DT headers. If the big ones fit then i dont see why the small ones wouldnt but you never know.
They didn't fit. I have the extreme. I ended up making some for my LS3 based motor. I also have custom engine stands from Nate, so I am a little taller.
Old 12-03-2012, 04:55 AM   #43
c10seconds
c10seconds's Avatar
Thanks! I got the harness from SSP wiring. Seems to be a good product with everything nicely wrapped and them being only about a 1.5 hour drive was a plus. There wont be very many wires exposed when its all tucked away. Especially with this little TVS on top
Old 12-03-2012, 09:57 AM   #44
smartass12
smartass12's Avatar
So it seems the pasesetters are the way to go for extreme?
Old 12-03-2012, 10:07 AM   #45
Hart_Rod
Hart_Rod's Avatar
The "huffer" looks good! What do you have underneath it? (specs please, ) Also, what angle did you set your motor at?
Old 01-13-2015, 11:03 AM   #46
slowcpe
slowcpe's Avatar
Going to bring this back from the dead. I know I sent you a PM but also wanted to see if anyone else had success with the steering linkage and these headers. Or any other long tube for that matter.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 02-27-2015, 06:17 PM   #47
Hillbilly Deluxe 65
Wheelin' and Dealin'
Hillbilly Deluxe 65's Avatar
what part number pacesetters worked?
why dont the kooks work on the extreme dropmember?
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside
Porterbuilt Extreme front and rear
12bolt w/ eaton tru-trac 4:11 gears
1BADD65
my build thread:
http://67-72chevytrucks.com/vboard/s...=1#post2601700
Hillbilly Deluxe 65 is offline   Reply With Quote
Old 06-20-2016, 10:48 PM   #48
Parishchief1
Parishchief1's Avatar
I'm running a 67 with a mild pb dropmember and I'm looking to run these long tube headers has anyone got the steering linkage working??
67' C-10 PBFAB suspension,Accuair, Baer Pro+ 14" big brake kit F&R, Narrowed moser 12 bolt,Boyd Slayer 24x9's & 24x15's. 405 GANG500HP Ls "Da Green Beast"
Parishchief1 is offline   Reply With Quote
