Old 03-21-2012, 10:34 AM   #26
bbbc10
Diggin The SquareLife
Re: Rebuilding Vent Windows, How To...
im in the process of doin my windows now
bbbc10 is offline   Reply With Quote
Old 03-23-2012, 11:18 AM   #27
1425956
1425956's Avatar
Posted this reply by accident. Will have how to up shortly. Or mods, delete this post please.
Jeremy
I have done so much, for so long, with so little, I can do anything with nothing!
1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.)
1986 GMC Suburban 3/4 ton 4x4
2014 GMC Sierra LTZ Z-71 Crew SWB
1425956 is offline   Reply With Quote
Old 03-23-2012, 12:02 PM   #28
1425956
1425956's Avatar
1984 GMC Sierra Classic with power windows and locks.
Bill of materials purchased from Classic Parts in Kansas City, MO.
1 03-809A Vent window weatherstrip
1 03-825 Vent assembly rivets
1 03-835 Vent rivet setting tool
2 18-321 Door bumper (Not required)
1 03-323 Door glass channel left
1 03-324 Door glass channel right
1 03-576 Beaded window seals
First, roll down your window all the way and remove the door panel. Red dots indicate the 11 screws that need to be removed. [IMG]
Next, remove this bolt that attaches to the bottom of the vent window support.
Jeremy
Old 03-23-2012, 12:21 PM   #29
1425956
1425956's Avatar
Remove the 3 screws from the top edge of the door frame. The screws are located directly underneath the red dots. Sorry for the bad picture....
Remove the old weather stripping starting at the red line and work your way to the back of the door frame. Half way back, just before the first curve, there is a small plastic clip that snaps into a hole that is designed to help hold the weather stripping up. Just pull weather stripping away and use a screwdriver to remove it. You can discard it since the new weather stripping comes with it pre-installed. You can continue to rip out the old weather stripping as far as you can down into the door. I was able to just grab and pull all of the old stripping right up and out from behind the edge of the door glass
Jeremy
Old 03-23-2012, 12:34 PM   #30
1425956
1425956's Avatar
Once the old weather stripping is removed, you will be able to grab a hold of the back side of the vent window and pull back to remove it from the door. READ BELOW.
IF YOU HAVE TINTED WINDOWS, BE VERY CAREFUL TO KEEP THE BOTTOM PART OF THE FRAME ON THE OUTSIDE OF YOUR GLASS SO YOU DO NOT SCRATCH YOUR TINT!!!
As you pull back on the frame, the bottom part of the vent window bracket will slide forward. You will have to rotate the vent window and pull up at the same time to get the bracket through the opening in the door. This video I found on youtube shows the process also.
Jeremy
Old 03-23-2012, 01:08 PM   #31
1425956
1425956's Avatar
As shown in the video in the previous post, he inserts the glass from the back edge of the door working it forward with the regulator rollers in the channel. I have found it is MUCH easier, and less chance of scratching your paint on the door frame if you do it the opposite way and remove and install the glass from the front edge of the door. Doing it this way will allow you to complete the job without a helper supporting the glass while you try to fight to get the glass in place while trying not to scratch your paint.
Also, go ahead and get any weather stripping removed from where the back side of the glass sits if you were not able to remove it all earlier.
Now is a good time to clean up all the old grease from the rollers and glass channels. Years of dirt and dust slow down the operation of the regulator and rollers and put unnecessary strain on the window motors that are probably weak anyways if they have not been changed.
Jeremy
Old 03-23-2012, 01:31 PM   #32
1425956
1425956's Avatar
Go ahead and clean the rollers on the regulator that slide in the glass channel and clean the short piece of rail inside the door that is welded to the door frame. Just a couple of quick pics...
I used WD-40 and brake clean to remove grease and lubricate the rollers and channels.
Use a pic and brake cleaner to clean the 3 holes in the roller. The straw from the WD-40 can works well on the brake cleaner to insert it in the 3 holes and flush the junk out. Wear gloves and safety glasses to keep the brake clean out of your eyes as it passes through the small holes in the roller and shoots back out in your face. Protect your paint also.
After. Once cleaned, apply some WD-40 or white lithium grease to holes in rollers and work them around to evenly coats the ball inside.
After cleaning window channel attached to glass.
Jeremy
Old 03-23-2012, 01:47 PM   #33
1425956
1425956's Avatar
Once you have cleaned and lubed up the regulator, lock and handle mechanism inside the door, go ahead and put the glass back in the door and roll the window all the way back down. Again, double check to make sure all the old weather stripping and window channel has been removed from the channels in the door that support the back edge of the glass.
Now we are going to disassemble the vent window to remove the old rubber and install new. Use a screw driver to remove the vent window weather strip that should still be in the back channel of the vent window. This is the part the front edge of the glass rides in and is going to be replaced. This will be all one piece on the new weather strip. I believe these are 2 piece on older model trucks. But I may be mistaken.
Now we are going to disassemble the vent window tension spring assembly. Use a screw driver to open up the small metal locking mechanism so we can unscrew the nut and remove it all.
Once the nut is loosened a little, the tension will be released. It is not under much pressure and will not fly off. Remove it all and lay it out in order so you can reassemble it correctly.
Go ahead and remove these two washers also.
Jeremy
Old 03-23-2012, 02:07 PM   #34
1425956
1425956's Avatar
We are now going to remove the actual glass and metal trim around the glass from the vent window assembly. To do this, we need to remove the small rivet that is on the outside of the glass 3/4 of the way up the vent window. Marked in the picture below:
I used a small drill bit to start a pilot hole for the bigger bit to remove the rivet. I am sure a Dremel tool would work well too, but I do not have one. Just be VERY careful when drilling the rivet so you do not enlarge the hole the rivet goes through. All you are trying to do is remove the head of the rivet so it can fall out the bottom. If you enlarge the hole, the vent window is ruined unless you want to put a small bolt and nut on it, which would look terrible, IMO.
End result:
As you are removing the vent window from the frame, pull up on the window part to separate the stud at the base of the window. It will pass through the 2 little washers in the picture below:
Jeremy
Old 03-23-2012, 02:15 PM   #35
1425956
1425956's Avatar
Next we will remove the actual vent window weather strip that seals the back side of the glass when shut. It is held in place with several metal tabs that are just bent over to hold it in place. Image below:
This shows the metal tabs after they have been bent back up (straight) so the trim can be removed.
Removing the trim piece. It has a little weather strip adhesive on it from the factory, but it is not too sticky.
Removed completely:
Jeremy
Old 03-23-2012, 02:26 PM   #36
1425956
1425956's Avatar
Now we will remove the main part of the seal that the glass sits against when closed. It runs the perimeter of the frame. Use a screw driver to pry the rubber up at the base of the frame:
Before we can completely remove the seal, we need to remove the rivet at the very top edge of the frame.
Again, use a small bit to make a pilot hole then use a larger bit to remove the head of the rivet so it can fall free:
With the rivet removed, the frame will open at the top and the seal can be completely removed:
Stripped frame:
Jeremy
Old 03-23-2012, 02:46 PM   #37
1425956
1425956's Avatar
If your vent windows are anything like mine, the black trim piece and the small bracket on the outside of the vent window (the one that held the 1st rivet we removed) were no longer black, but rusty and ugly. I used a metal brush, lacquer thinner and a scouring pad to remove the rust and prep the metal for some SATIN black paint.
NOTE OF CAUTION, ONLY USE THE LACQUER THINNER TO CLEAN THE SURFACE AFTER YOU HAVE WIRE BRUSHED. IT IS POSSIBLE A SPARK FROM THE WIRE BRUSH COULD IGNITE THE LACQUER THINNER IF YOU USED IT BEFORE WIRE BRUSHING!!!.
Some people have used gloss black, and it will work, but the trim came from the factory as a satin black. Personal preference I guess.
Once cleaned and prepped, tape off the pieces you do not want paint on.
You can see I painted the outside trim and the smaller bracket.
Jeremy
Old 03-23-2012, 03:29 PM   #38
1425956
1425956's Avatar
Once the paint has had plenty of time to cure, you are now ready to reassemble with the new pieces. You could remove the vent window, disassemble and paint the trim black before you clean your regulator and rollers. That way it will be drying while you are working on something else and saves some time.
First, get the jar of Vaseline you keep next to your bed cause we are going to need it to get the rubber in.................................................................
OK, back on track......
Coat the entire inside part of the bottom of the seal, between the two rubber flaps, with Vaseline. Don't be greedy with it either. I coated the rubber strip in 1/3 sections so I didn't have Vaseline all over the place.
We are going to start inserting the seal into the metal frame at the bottom part of the frame where the frame pieces make a 90 degree.
IMPORTANT INFO HERE
If you look at the inside of the rubber seal, the area you put Vaseline, you will see some depressions in the rubber in the same location the rivets are on the frame. You can use these as a guide while you are inserting the rubber to make sure you have it in the correct place in the frame. Kinda hard to mess this part up, just pay attention.
ALSO, you will notice a slit in the rubber at the point the stud at the base of the vent window goes through. Just another reference point. Lastly, you can test fit the rubber in the frame and will notice the cut out in the rubber that is made to go around the bracket that the first rivet was in. Just take a good look at it all and make a mental note of where the rubber should sit as you work your way around.
*****This is the hardest part and was impossible for me to take better pictures of the process since I was flyin solo that day.****You will notice in the next 2 pictures that I am holding the rubber seal at a slight angle to the frame. This is so you can push one side of the rubber into the metal frame while you are pushing the other side into place using a screw driver. Your goal is to put both rubber flaps around the frame as you work the rubber in.
You will have to work the rubber into position inside the frame in 3/4 to 1 inch increments using your screw driver tip. Push in on the rubber with the tip of the screw driver as you use your other hand to help press it in place. It will take a little bit of practice to get it done, but you will have it figured out by the time you complete the other side. Make sure you keep the rubber at an angle so one side is already "pre-inserted" and all you are really doing is "squeezing" the other side in place. You will begin to "feel" and hear the rubber slide into place in the metal track as you work your way around. Getting the bottom part of the rubber, up to and around the bend, is the hardest part. It takes a little extra time, but once it is complete, the 8-10 remaining inches are a breeze. TRY NOT TO GET FRUSTRATED WITH IT AND WALK AWAY FROM IT FOR A FEW MINUTES IF YOU NEED TO. The Vaseline will help you a lot here so use plenty of it. It won't hurt a thing.
Work your way around until you seat the very top part of the seal where the frame comes together. Take a break and drink a cold one. You got this covered and are on the down hill side of the project. You will be rolling in piece in quite before too long....
Jeremy
Old 03-23-2012, 04:48 PM   #39
1425956
1425956's Avatar
I will have the re-assembly steps posted a little later on this evening. It's taking me longer to write the how-to than it did to do the job! Oh well, it's for a good cause...
Jeremy
Old 03-23-2012, 05:06 PM   #40
chrismoore701
chrismoore701's Avatar
haven't gone into detail of your build, but what I have seen, Damn. NICE JOB
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 03-23-2012, 05:09 PM   #41
1425956
1425956's Avatar
Originally Posted by arrover View Post
Looking forward to the tutorial! Where did the parts come from? I think LMC is located in Kansas City but Classic Industries is in California.
I stated I got the parts from Classic Parts in KC. You are correct about Classic Industries, they are in CA, along with Brothers. LMC is actually in Lenexa, KS, a suburb of KC.
Jeremy
Old 03-23-2012, 05:34 PM   #42
hatzie
Moderator
hatzie's Avatar
Nice. Clean & Easy to follow. This one deserves to go in the FAQ.
Old 03-23-2012, 05:38 PM   #43
68Timber
I know the pieces fit
68Timber's Avatar
Before reading this I had a valid excuse to paint either K5 with the vent windows still in the doors... Excellent write up.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-25-2012, 04:44 PM   #44
arrover
arrover's Avatar
My mistake! I actually didn't realize that Classic Parts and Classic Industries were two different companies until now. Great writeup!
arrover is offline   Reply With Quote
Old 03-30-2012, 11:43 AM   #45
RobbySuburban
Nice job on the install. Do you remember what the brand of weatherstrip the seal is? I'm going to need to do mine soon.
RobbySuburban is offline   Reply With Quote
Old 03-30-2012, 11:51 AM   #46
1425956
1425956's Avatar
I don't recall. IIRC, there were 3 letters or numbers on the packaging. Gold something maybe? Blue writing on clear plastic.
Jeremy
Old 03-31-2012, 10:04 PM   #47
'79squared
'79squared's Avatar
Nice rebuild. Oh, and love the those notes on your hand hahaha
1979 SWB 350/350
'79squared is offline   Reply With Quote
Old 04-10-2012, 11:36 PM   #48
1425956
1425956's Avatar
So has anyone else attempted to change their vent window/door rubber sills since this write up? I see a few people posted that they were going to try this soon, just curious of the outcome.
Jeremy
Old 05-06-2012, 04:25 PM   #49
monte0185
monte0185's Avatar
I just did this but i didnt take the top rivet out and i used wd40 for lubrication. took a bit of finegling to get the main seal up in the grove but only took me about an hour to put both seals in. wish i had read this before i did it though. would have answered a few questions!!.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 05-06-2012, 10:42 PM   #50
misternash2
nice write up. i'll appreciate this later this week.
also, we're almost neighbors! my wife is a nurse at freeman ER!
misternash2 is offline   Reply With Quote
