Old 04-13-2012, 07:59 PM   #26
djw32
Re: Project Underfunded / next phase - LSx carb'd to LSx efi
Originally Posted by 68GMCCustom View Post
Lots of progress. Fuel system is done...but
Bought an inexpensive (well, compared to the others) cold air intake kit for the '99-'07 trucks, plus a 22* 4" tube and extra coupler to work up something to fit... now I'm running that to the drivers side!
Got some rewiring to do, a couple of terminations.....then I can't think of one good reason not to hit the key! Since I have a GoPro now...I suppose I'll set it up to record the event. I'm actually kind of anxious to hear it now...vs w/carb and MSD timing it. get rid of or exaggerate the lope?
I know...............pics.
I can't wait to see your cold air intake.
djw32 is offline   Reply With Quote
Old 04-16-2012, 02:45 PM   #27
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
OK....sorry for the delay guys. Had to leave the computer for a few days to get something done!
lets see Saturday...I got the -6 AN s.s. hose installed for a return line, got the fuel pump mounted, and the Corvette filter/regulator in with Russell efi adapters and -6 AN fittings - 3/8" s.s.hose...then reinstalled tank.
I bought lots of fittings and adapters to change my 1/2" hose and -8AN fittings to 3/8" -6AN...had leaks all over so I pulled it all out
built a new 3/8" s.s. hose w/-6AN ends to replace it all.
new fuel pump power lead being run also:
which takes it all the way to the -6AN to 3/8" Russell efi adapter and the fuel rail.
then it was back to the harness. I started laying everything out on the drivers side, and run the intake to the passengers side like its designed (and checking things with the extra pieces I bought)...
but....wait...there were wires to pull out of my wiring 1st....the 2 UEGO's, the MSD, electric fuel pressure, etc.
and with a little work I think I can make my CAI setup run to the drivers side...
which would put the harness end/power/ecm etc. running to the passengers....and decided I would put it on the passenger side on a shelf (need to build) on the fender. As soon as the budget allows a Vintage Air purchase...the ecm and tcm will be mounted on the firewall.
then they started predicting bad weather thru the weekend that could include hail. That was enough to motivate me to put the truck on wheel dollies and push it to the side (it sat in the middle of the garage and sideways) so I could bring the SS in. That put the rest of the work on hold until Sunday.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-16-2012, 03:09 PM   #28
68GMCCustom
Into the next day...with pulling the a/f gauges, the MSD box, etc....of course there was wiring changes on the inside.
in mocking up I checked clearance...and its either just barely touching the hood...or not.
so...I reworked the original wiring on the drivers side (which is going to be placed behind the fender), moved the Painless Circuit Boss toward the front, and grouped in an new wires...which came out cleaner then it was before.
then I mounted the new relays and fuse panel on the passenger side, and bolted the ecm/tcm together thru one bolt in the inner fender to hold them for now...until I get a shelf built that will hold them until the truck gets a/c and I flush the firewall
that left reworking the CAI...its not all locked down yet....still adjusting.
and with everything in under the truck and under the hood installed, hooked up, plumbed, etc.....it was time to push the pedal harness thru the firewall and push the pins into the connector, and connect the foot pedal. After that....its key on! I will need to get another pedal tho...or make a big base for this one so for now the pedal assembly is just laying in place.
So I'm looking at the schematic and pushing the pins into the connector when I get to the last pin.......and its bent! As I tried to bend it back...it just snapped in the middle. AAAAAAaaaaaaaaahhhhhhhssssshhhhhhhhhhhh!!!!!!
so.....I pushed it back over to the side and wait for parts.
Kurt -
Old 04-16-2012, 09:49 PM   #29
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Isn't that the same pin as the computer connectors? If it is, PM me your addy I'll mail you a couple.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-16-2012, 11:01 PM   #30
awhite4557
awhite4557's Avatar
I used the same Russell Quick Disconnect Fuel Fittings for my fuel rail when I installed the fuel lines in my 5.3 swap. Shortly afterwards, I started my PU and the preasure line came off when the pump preasured up. The plastic retainer clip stayed on the fuel rail and the fitting came off spraying fuel all over my engine. Luckily, my engine was cold. If this had happened while I was driving, it could have caught fire. At first I thought the fitting just wasn't seated correctly and re-installed it. It re-installed fine and re-seated correctly and did not come back off since I added a zip-tie to ensure it didn't come off. I was going to just replace the preasure fitting with a new one and when I checked the LS1 website, I came across a post listing this same problem. It appears this is becoming a common occurance with mostly the preasure side Russell quick Disconnect fitting.
I found out that Russell has a new style fitting that has a screw on c-clip retainer and will not come off. The fitting part numbers are 644120 (Summit #RUS644120) for the 3/8 preasure side and 644110 (Summit #RUS644110) for the 5/16 return line.
I called Summit and at that time, they did not have the part numbers in their system. They called Edelbrock and got the part numbers and I ordered both fittings and have replaced the ones I originally installed.
You may want to consider replacing the fuel rail preasure fittings with the newer style to prevent this from happening. Here is a photo of the new fitting.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2002 Winnebego Class A MH Ford E-550 Chassis V-10
2005 Dodge Ram 2500 5.9 Cummins
2008 GMC Denali
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 04-16-2012, 11:20 PM   #31
85burb
85burb's Avatar
That looks like a very clean install so far. I like the intake a lot.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-17-2012, 12:45 PM   #32
68GMCCustom
Thank you for the offer....but Allen is already sending me some today.
Wow.....you mean the AN/efi fittings I just put in....those fittings, are garbage? That's about the way my purchasing usually goes...wrong part, better solution available, price reduced after my purchase............ now I'll add crappy part that needs upgrading to the list.
Thanks 'burb!
Kurt -
Old 04-17-2012, 03:25 PM   #33
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I had my fuel rail modified to just have -6 screw on connections.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-17-2012, 04:08 PM   #34
68GMCCustom
that makes it easy!
Kurt -
Old 04-17-2012, 05:10 PM   #35
Clyde65
Clyde65's Avatar
Yes Kurt it did, but I had to send it off to be modified. After I thought, heck I could have done that! but oh well.
Clyde65
Rebuild of Clyde
support our troops!
Old 04-17-2012, 10:53 PM   #36
68GMCCustom
I'm not to good with a MIG......much less a TIG.
Kurt -
Old 04-17-2012, 11:10 PM   #37
mcbassin
Still Learning
mcbassin's Avatar
Nice work on this conversion Kurt. You have knocked it out fast like you have a deadline brother
mcbassin is offline   Reply With Quote
Old 04-19-2012, 08:04 AM   #38
awhite4557
awhite4557's Avatar
Thanks 'burb!
The new fittings are basically the same price as the old ones, they need to just remove the old ones and sell the new ones. I took my old ones off and threw them in the trash. As I stated earlier, my truck would have gone up in flames if that had happened while going down the road with a hot engine. I put a post on after that happened about the fittings but I don't think anyone paid any attention to it because I still see people posting photos with the old fittings on their builds. Your build looks awesome. Keep up the good work. I drive mine everyday and love it. (Over 11,000 miles now and no problems so far).
1971 Chevy Chevelle
2008 GMC Denali
Old 04-19-2012, 10:28 AM   #39
68GMCCustom
Thanks Mike!
awhite...maybe when someone gets hurt (or worse) sues Russell....maybe they'll take those old fittings off the market.
Trying to build mine so that I can go beat on it at the track and still trust it to get me home...plus the occasional cruise.
AND BTW...........if anyone is interested in any of the LSx related components that I removed (GMPP dual plane L92/LS3 intake, MSD 6012, 2 different Holley carbs, Holley reg. 2 fuel pumps (1 NIB), 1/2" -8 AN stuff, etc. ....they're for sale. May throw in more left over from the build. I'll be posting a thread with pics and prices. Have to pay for the 4L85e somehow!
Kurt -
Old 04-29-2012, 01:49 PM   #40
68GMCCustom
Ok guys...need some help!
Hoping I can find out something from the knowledge pool!
I have an '09 LY6 that I'm converting back to efi from it being carb'd for the last year. I have a custom built "stand alone" harness with ecm and tcm setup for a 4L80e. There is a 200-4r in place right now so the harness ends for the ISS, VSS, and 4L80e and not connected to anything tho the harness is connected to the tcm.
I have a wiring problem I think.......just not sure. I can apply power to my Walbro external fuel pump and it run all day and build 56psi at the fuel rail. Connect it to the harness and power up the harness....and the fuel pump cuts out within 2-3 seconds. I guess I should clarify...the fuel pumps relay kicks out...the primary relay for the whole system is still active...so its somehow tied to the pumps relay. The vehicle will not start...but a little starter fluid in the throttle body and it will try to fire up and run. I've drained off the fuel in the line so that tho old fuel isn't filling the fuel rails.
Oh.....and the harness builder and tuner are not the issue and not open for discussion. Maybe at a later date once the problem is found and resolved so that everything is working as it should. I don't want this to turn into a bashing thread!
I have swapped the relays and the fuel pump relay still cuts out. So....have I got a wiring issue that needs the harness removed and sent to the builder? Or is it possible that I have an ecm problem? How do I verify the injectors are firing?
Thanks in advance!
Kurt -
Old 04-29-2012, 03:12 PM   #41
jfortvalley
do you have the fuel pressure sensor wired in to the pcm if so its supposed to come on untill the rail is pressurized and then shutoff when the crank sensor reads that the engine is running under its own power
jfortvalley is offline   Reply With Quote
Old 04-29-2012, 03:31 PM   #42
68GMCCustom
don't think this harness has a fuel pressure sensor???
Kurt -
Old 04-29-2012, 03:33 PM   #43
jfortvalley
is the computer programmed for a fule pressure sensor ?
Old 04-29-2012, 03:42 PM   #44
mcmlxix
Collector of Projects
mcmlxix's Avatar
not sure this helps, but when you key on, the fuel pump cycles to build pressure, then doent actually run till the engine is started...
Rich
1972 K5 Blazer CST Click HERE
Old 04-29-2012, 04:15 PM   #45
68GMCCustom
not building a full 56psi in roughly 2 seconds tho.... Using the Corvette filter/regulator which doesn't have a sensor/electronics. I don't have anything on the manifold but a MAP sensor and the TB hookup. Nothing on rails but a schrader valve....so nowhere is something "electronically verifying" the fuel pressure...just the mechanical regulator in the Corvette filter/regulator
Kurt -
Old 04-29-2012, 04:19 PM   #46
jfortvalley
I would still say this is built in to the computer have you gotten far along enough to crank the motor yet ?
Old 04-29-2012, 04:23 PM   #47
68GMCCustom
sure...no fire. add something flammable to the intake and it tries to start.
Kurt -
Old 04-29-2012, 04:27 PM   #48
jfortvalley
when the relay KICKS out have you verified whether the 12 volts is being pulled away or the ground ?
Old 04-29-2012, 04:31 PM   #49
jfortvalley
oh and i use noid light to verify the injectors are firing
Old 04-29-2012, 04:48 PM   #50
68GMCCustom
has to be the +12v....thats the only wire for that relay that needed to be terminated....to + on pump.
Kurt -
