Old 05-06-2012, 10:22 PM   #26
npc1
npc1's Avatar
Re: 1970 Chevy AKA "Hammer"
A couple more pics.
Check out my Build http://67-72chevytrucks.com/vboard/s...d.php?t=517150
npc1 is offline   Reply With Quote
Old 05-06-2012, 11:04 PM   #27
67cheby
67cheby
67cheby's Avatar
Nice work
67cheby is offline   Reply With Quote
Old 05-07-2012, 10:50 AM   #28
BossHogg69
motor exploder
BossHogg69's Avatar
nice work so far, I love me some Pro-Touring trucks subscribed!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-07-2012, 08:51 PM   #29
Tinkermc
nice looking work and pics show some great parts
Tinkermc is offline   Reply With Quote
Old 05-20-2012, 09:32 PM   #30
widewhite70
widewhite70's Avatar
Looking good! you'll love the LS being able to jump in and turn the key is great. The first time we fired mine up it took off the second time it turned over.
-Calvin
http://67-72chevytrucks.com/vboard/s...d.php?t=512270 my build, tube chassis and LS2
How I keep the truck shining, Detail thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=697902
widewhite70 is offline   Reply With Quote
Old 05-25-2012, 11:11 PM   #31
npc1
npc1's Avatar
Well Its been a couple of long weeks. I havent been able to work on the truck as much as I have wanted to but Ive been knocking somethings out here and there. Ive got both doors done allthough the drivers door is not exactly making me happy right now so I may end up re doing the outer door skin. I bought my cpp modular drop spindles, rack and pinion, and I bought a ls3 intake since my truck intake is a bit tall with this drop member. I blasted and painted my control arms today. My goal this weekend is to get what I have of the front end put together and finsih my fenders and get them in primer. Anyways heres some pics I hope yall enjoy.
Old 05-25-2012, 11:14 PM   #32
npc1
npc1's Avatar
more pics
Old 05-25-2012, 11:17 PM   #33
npc1
npc1's Avatar
more
Old 05-25-2012, 11:18 PM   #34
npc1
npc1's Avatar
Control arms
Old 05-26-2012, 02:34 AM   #35
butternut1972
butternut1972's Avatar
Nice project.
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 05-26-2012, 12:15 PM   #36
67cheby
67cheby
67cheby's Avatar
looking good man !
Old 05-27-2012, 10:57 PM   #37
npc1
npc1's Avatar
Thanks guys. Its comming along slowly but I try and some of it just depends on how the money situation looks. I got the control arms and spindles put on and installed the rack and pinion. I measured to see how much ride height I was going to have and with 315/30/18 in the front and 335/30/18 in the rear I should have 4" from the ground to the bottom of the frame which is great cause thats what I was shooting for. I got the drivers side fender blasted and primered and filled in all the holes and shaved the parking light and I fixed the lower part of the cab that was broke off on the cab. Anyways heres some pics
Old 05-27-2012, 10:59 PM   #38
npc1
npc1's Avatar
More
Old 05-28-2012, 10:35 PM   #39
Tinkermc
looks good
Old 06-15-2012, 11:04 PM   #40
npc1
npc1's Avatar
Sorry its been so long since I posted anything. Its been pretty busy around here lately and not to mention its getting hot but Im still plugging away at her. I filling in all the holes and parking lights in both fenders and I replaced both rocker panels and replaced the drivers cab corner since it was bent up pretty bad. I decided that since I was going to be using coil overs I would rather have a 1 piece drive shaft instead of a 2 piece so I raised the drive shaft hoop on the crossmember and started working on the cab tunnel for the trans and drive shaft. I found some seats and started working on mounting them in the truck and I found a 59 impala dash thats in really good shape. I put the heads back on the engine and mounted the ls3 intake. On a side note I found out I have to buy new brackets for the a/c compressor and alt/ps because of the drop member. Anyways I leave you with more pics.
Old 06-15-2012, 11:07 PM   #41
npc1
npc1's Avatar
more
Old 06-15-2012, 11:08 PM   #42
67cheby
67cheby
67cheby's Avatar
That is a lot of great progress !
Old 06-15-2012, 11:09 PM   #43
npc1
npc1's Avatar
more pics
Old 06-15-2012, 11:11 PM   #44
npc1
npc1's Avatar
Thanks 67cheby. Its going slower than I would like but alot of it just trying to sweet talk the old lady into letting me buy stuff for it. Haha But one day it will be done.
Old 06-15-2012, 11:13 PM   #45
67cheby
67cheby
67cheby's Avatar
Love everything , great dash project !
Old 06-16-2012, 07:02 AM   #46
c10327
c10327's Avatar
looks like it will be one hell of a c10 !!! great pic's keep up the good work .
c10327 is offline   Reply With Quote
Old 06-23-2012, 03:58 PM   #47
npc1
npc1's Avatar
Ok slight change of plans. I found a 6l80e and got a good enough deal on it that I couldnt refuse. So I changed out the trans yesterday and now I need to clean up the frame a bit from some scratches that have accured from trying to build a tunnel. I dont remember if I said this before but I have decided to run a 1 piece drive shaft instead of a 2 piece so I had to raise the drive shaft hoop a bit anyways here are some pics.
Old 06-23-2012, 04:00 PM   #48
npc1
npc1's Avatar
Pics
Old 06-23-2012, 10:13 PM   #49
Tinkermc
I gotta tell ya this is shapping up, would be glad to store that dash in my GMC 4 you
Old 06-23-2012, 10:51 PM   #50
npc1
npc1's Avatar
Thanks Tinkermc. If I would stop changing my mind on certain things I would be alot closer to finishing. As for the dash I started looking and found this one for 100 bucks which was way cheaper than anything others that I could find and alot more complete. I hope it looks pretty nice when Im done.
