#26 |
Carolina Classic Trucks
Man this is some awesome info in this post. I installed an lt-1/4l60e in an 88 Jeep YJ. My motor and trans came out of a 1996 Impala SS.
Some of these items were mentioned but I think they are worth mentioning again. You will need to switch your inlet/outlets on the radiator. We bought a Be-cool Alum. radiator and switched the inlet & outlet ourselves. Becareful with the vats on the newer vehicles (96 & up I think) Vats is vehicle anti theft system. This thing can cause a MAJOR headache. Even with an aftermarket harness we had trouble with this. The chip on this went bad once. When this happened, the motor would turn over but not start for about 5 minutes, then it would finally run. I heard these engines will run in LIMP mode, which basically means it will run but not give you the 300 hp it supposed to have. Watch out for this. Also we had to get our comp. reprogrammed becuase we were running 39" tall tires with 5.39 gears. This really messes with the computer. It would switch to OD when the speedometer was reading 35mph. If you are running a tire that is about the same as what came on the orig. vehicle but are running a different gear, you might have to get the computer reprogrammed. Make sure you get a fan that will cool enough. We had to switch from the perma-cool to the black magic even with the be-cool alum. radiator. Lastly, Watch out for the waterpump and distributor on these engines. The LT-1 we had came out of a 96 Impala SS. When you have to go get a replacement, you better pull up a chair first. These things are outrageous!!
#27 | |
chevelito
thanks, jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
#28 |
Yes, you can. Mine is mounted on the 6cyl mounts in the 6cyl position. It fits right in and looks a little better imo..
Milan 1964 Chevelle SS 283/M20 |
#29 |
chevelito
do I have the terminology correct? engine mounts vs. engine towers or are they the same?
#30 |
chevelito
06/08/03
got my new used engine home. what an ordeal. A deal fell thru on a fairly new engine hoist so I had to scramble to find a new one (not easy on a Sunday). Found a nice fold up one for $300. Got that home and started to put it together. Whatever you could think of that could go wrong, went wrong. The instructions were'nt very clear so we had to redo some bolts about 3 times. It was muggy too with lots of sunshine. We built it on the grass in the sun so I'm a little sunburned from that. We needed to get some chains so we went to Lowes....and then the storm came in. It started to pour elephants and gorillas. I mean flash flood warnings. Thunder and lightning all over. I was thinking "man is god telling me something or what?" Anyway, we had to drive 40mph thru this stuff for 30 minutes which would normally take 10 minutes in normal weather. Anyway, we reach there and it starts to clear up. We got to the guy's house at 2pm and he had to leave for work by 2:30pm. We got out by then. Everything went pretty smooth from then on. I got pretty much everything including the stock e-fans. Anyway, good times are ahead trying to figure out the electrics. It's all intact though. Anybody recommend an assembly manual and where I can find one? Jay
#31 | |
chevelito
jay
#32 |
chevelito
Found a good article in Classic Trucks where they put Auto Meter Ultra lite electronic guages in a carbon fiber guage cluster. The speedo is electronic. Maybe that would be a good idea too? Just checking with the big boys first.
Last question....(well maybe not). Is there a GM part number for the accesory brackets for the corvette version? I think I can get a hookup at the dealership. Jay
#33 |
I don't have the part number, but I believe it requires quite a few different parts...I know you have to use a different flywheel for the vette brackets. By the time you do that, you may be better off getting a Street and Performance set of brackets... www.hotrodlane.cc
I have also heard it is a different AC compressor with the vette style, but am not sure.
69 SWB LT1/4L60E www.classicplace.com |
#34 |
chevelito
Thanks for the info.
Jay
#35 |
Anyone interested, I have a reworked factory harness for sale. I spent $400 having it reworked to be stand alone and to delete emissions and MAF sensor. It also has the diagnostic plug, service light, and a fuel pump relay. I also installed new plugs that go into the computer. I have $450 in it, not including the harness itself. I would be willing to sell it for $400. Anyone interested e-mail me at NPilot1975@aol.com or call me at 360-279-2020. Hope this will help someone.
1972 Blazer body...need to get a thread started for the rest of the story |
#36 |
My only 2 cents is I used the Calif. sending unit for my tank to run the return line to and run an external pump....No need for a special tank. I did notch my frame for the Ac compressor and also notched a little for header clearance, but other than that it was all "bolt in" and runs awesome. I went thru fuel injection specialities for their wiring harness ans computer programming.
'72 Cheyenne super, short-fleet, air-tilt-tach, fuel injected LT1, 700r4, 3.08 posi, 4WDB, step notched and bagged. "the one i wish i still had" |
#37 |
chevelito
Well, I'm relocating the tank to the bed so I'm gonna need the tank anyway. Besides, the engine came with the stock pump so I might as well use it. Nice to hear that your swap went great. I'm not so sure if I want to notch the frame yet.
Jay
#38 |
Anyone need any LT-1 parts? I have a lot of stock parts that I am trying to sell, including stock radiator with dual fans, modified factory harness, all brackets, p/s pump, a/c compressor, lots of other stuff. E-mail me at NPilot1975@aol.com.
#39 |
Here's a pic of the stock fan/radiator set up...
#40 |
And here is the stock condensing coils (when I say stock, I am speaking of the stock camaro units in our trucks)
#41 |
chevelito
Looking good.
#42 |
chevelito
I have another question...will the tranny fit under the low hump? It will be bolted to the stock auto crossmember.
jay
#43 |
Yes, no problem at all...
#44 |
On the fuel tank issue. I have installed a '99 Z28 fuel tank in my '72 Stepside. It did require some work but I really like it. Solves in-tank fuel pump problem.
Craig Berland |
#45 |
I didn't try a 99, but couldn't make the 94 work. I did use the pump from the tank, however.
#46 |
When installing the ECM/PCM, you will have to deal with the VATS system if the car originally had it. Painless sells an entire engine wiring harness that will bypassed the VATS for $$$, or you can have the PCM re-programed. Try here . He specializes in F-Body PCM re-programming, but he may be able to help out on the truck conversion and his prices are extremely reasonable. At a minimum, the shift points for the trans in the PCM will have to be modified. For tech stuff check out these sites here and here. Again, these sites are intended for the F-Body owner, but it will give you a good idea of where stuff is and how to fix the common problems. Okay, now for the known problems with these engines. 1) Intake oil leak. Look here for the details . Do yourself a favor and take care of this before the engine is put into the truck. I have just been living with the leak in my 97 T/A as it's not too bad, and it is impossible to get to stuff on that car. 2) Water pump usually dies after around 70K miles. Just had to replace mine at 65K. $135 and Auto Zone with lifetime warrantee. The other option is to got with an electric conversion. 3) Opti Spark ignition is a pain in the... to replace. It's located behind the water pump, and they seem to cause quite a few problems for some people. Mine has been fine (knock on wood). Just try to keep it as dry as possible. 3) Change the wires and plugs before you put the engine in. Won't be that bad in a truck, but the number 1 cylinder is behind the A/C compressor unless you relocate it. 4) These engines run HOT
'67 1/2 Ton Short Bed / 396 cid / AC w-R134a / 5 Lug Leaf spring rear axel / 5 Lug Frt Disk Brake Conversion '97 Trans Am - Black / LT-1 / K&N FIPK Cold Air Kit / Hooker Cat-Back Exhaust / 160 Thermostat '02 Buick Regal GS / Bone Stock |
#47 |
chevelito
thanks greg. gas hog...I'm keeping you in my buddy file.
jay
#48 | |
chevelito
Just wanted to add this from the other thread. good info.
#49 |
chevelito
alright, I've finally come to a point where I can mock up the engine mounts. I know this is kind of basic, but do I have to drill another hole to mount the bottom of the mounts to the crossmember? I want to use the 6cyl mounting holes.
thanks mucho, jay
#50 |
Hey,
I was reading this thread and wanted to add my .02. I put a '96 Camaro LT1 with 6 speed manual in a '91 S10. You will love this conversion!!!! As for the fuel pump issue. I used the stock intank fuel pump for a 1993 Central Port Injected (CPI) S10 Blazer. This is a direct replacement for the fuel pump in the S10 tank. If you can use the S10 tank in your truck this might help. I wired the whole thing myself using wiring diagrams and the stock harness. Do yourself a favor, BUY AN AFTERMARKET HARNESS!!! It took me 1 week to get the motor swapped and 3 weeks to get the wiring right (and I work on computers for a living). The VATS is a pain, but I went to several LT1 boards and found someone that makes VATS delete boxes. THese are 3 wire hookups and cost about 65.00. They connect to power, ground and 1 wire to the TPS. It is true what is said about the LIMP mode. If you get a pre '96 LT1, exchange the direct spark ignition witha later model Direct Spark Ignition. The newer ones have a vent hole and hose that runs to make sure condensation doesn't form in the DSI. Check that before you install it, it's a pain after install!! DO the thermostat conversion too. I also used the LT1 radiator and fans and it worked great. I hope this helps a little and reinforces your drive!!! BTW I got about 30MPG in my S10, no joke!!!!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
