#26 |
![]() Join Date: Jan 2012
Re: truck wont stay running while driving
ok so its been awhile and i dont know if anyone above will see this or not, got sidetracked with another project but i got back to this one i put a new carb and a new fuel pump on and its still doing it, so i bought a new module and im just wondering if the silver transistor thing beside it will effect how it runs, its corroded and im not sure what the inside is like, the distributor was under water at one time i also checked the springs and vac advance and everything springs back into place properly
heres a pic of the module and silver transitor thing i took off |
#27 | |
78K & 79C Jimmys
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#28 |
so i should get a new condesor then?
#29 |
78K & 79C Jimmys
Yes it looks rough, and very blurry lol
Needs a good contact Posted via Mobile Device
#30 |
i can get a better pic lol
#31 |
VA72C10
![]() Join Date: Mar 2008
I'd definitely replace that condenser...
...if not that, then I'd think about replacing any rubber fuel lines as they can collapse inside before they show signs of it outside and cut off the fuel flow once the engine is drawing in more gas...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#32 |
will do, thanks!
#33 |
did you ever get this problem fixed? i have the exact same issue with my truck, starts, idles fine for an hour. drive it a block and it chokes, backfires and stalls. usually wont start right away, i let it sit for an hour or two and it will start up again, same problem again....i find its when i shift into second gear it starts to stall.
#34 |
kinks in any fuel lines? do you smell a lot of gas? could be flooding
#35 | |
