Old 06-18-2012, 08:13 PM   #26
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Parked Indefinite
following along!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-18-2012, 11:25 PM   #27
Desperado454
Desperado454's Avatar
Originally Posted by cory d View Post
looks awesome. i dont know about the twin turbos and non power breaks though
Thanks! Not too worried about the manual brakes as they can work just as good as a power system.
Originally Posted by Dieselwrencher View Post
Awesome fab work and cool idea! I thought about putting a hx35w on my 354 hemi. What are running for timing adjustment when boost comes on? Keep up the great work!
Thanks for the encouraging words! I actually managed to get a MSD 6btm when a friend was putting his car back to stock. Was a good day!
Managed to finish up the turbo mounts, next up will be the hot side piping. Here's the pics
Originally Posted by 68GMCCustom View Post
following along!
Stay tuned!
Desperado454 is offline   Reply With Quote
Old 06-19-2012, 12:26 AM   #28
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Oh yeah, looks awesome! Did you do anything to the old engine to hold boost? And where can a guy get the aluminum inlet that bolts to the carb? You have me thinking.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-19-2012, 10:26 AM   #29
BLK2K2SILVY
BLK2K2SILVY's Avatar
Search carb hat or blow through/thru
Awesome build man, can't wait to see cold pipes routed and this thing running!
BLK2K2SILVY is offline   Reply With Quote
Old 06-19-2012, 11:13 AM   #30
JRANGER
JRANGER's Avatar
wow, thats gonna be awesome
JRANGER is offline   Reply With Quote
Old 06-19-2012, 02:37 PM   #31
spudz
spudz's Avatar
Awesome fab work! I like it! Don't get me wrong... I don't think the motor is going to last without a forged bottom end... BUT all the hard work will be done fabing everything if and when that happens you will just have to swap engines. KEEP IT UP.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 06-21-2012, 01:48 AM   #32
Desperado454
Engine is bone stock as far as I know, and it took 8lbs boost without issue with the old setup. Might treat it to an oil change though, we'll see.
Thanks again! Agree 100%. Forged would be ideal, but just not in the cards right now. I have confidence in the stocker though, and it'll be simple enough to change later on when the right deal comes along.
Anyways, the hotside piping is done, here's the pics
Old 07-09-2012, 12:23 AM   #33
Desperado454
Well, here's where I'm at as of tonight. After I finished mocking up the turbos I decided to turn my attention to the rest of the truck and this what happened:
Hoping to have the frame painted and back on all fours in the next few days. After that I will be repairing the minor rust on the cab and box. Quite happy that the truck turned out to be as solid as it is, not very common around here
Old 08-03-2012, 03:10 AM   #34
Desperado454
Hey gang, progress has been a bit slow, but managed to get a coat of black on the frame. Now with the cab back on, the decision has been made to get that firewall smooth. I've done it on another car I own, but held back a little bit. Think I'm going to challenge myself with this endeavor and shoot for a completely flat 'wall. Just trying to finalize a plan and then its time to juice up the plasma and have at it. Here's some pics of getting the cab prepared as I ponder which cut to make first...
Old 08-12-2012, 04:38 AM   #35
Desperado454
The monotony of my day to day garbage job has been having a direct effect on my life. Depressed, unmotivated and generally lost, I've not only turned to my tried and true mix of Jim Beam and off brand ginger ale, I've been trying to draw inspiration from my first try at a turbo small block. Pictures will follow, but let me set the scene. Young, broke, clueless, yet motivated(!) I hit up craigslist in search of the largest cheapest turbo money could buy. Well i couldn't have been more tickled to have stumbled upon not only an exceptionally large turbo, it was a cheap turbo! $60 was a small price to pay to join to forced induction club i thought, and the process to fit this behemoth to my vortec headed sbc was set to begin! I'll add to this story in time but for now i'll describe the following pics. First 2 are of the relic itself; likely a long forgotten milestone of the pinnacle of turbochargers in the early 60's. The following trio show how to drain a turbo and reference a mechanical pump on the cheap. The last pic, however, is a warning to those who have spent the time to build a turbo setup. Don't waste your time doing this, then invite all of your buddies over with the intent to show off how sweet it sounds spooling up. A turbo most likely won't spool up like you'd wish with zero load on the engine. An embarrassing lesson learned for sure.
Old 08-12-2012, 01:34 PM   #36
DBLSPRT68
DBLSPRT68's Avatar
DUDE, YOU"VE GOT SOME MAD SKILLS!!!!!!!!!!!!!!!!!!!!! Your brain has some awesome ideas in it. Keep it up. If your broke (like I am), just sell some stuff your not using (like I do).
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 08-13-2012, 02:39 AM   #37
Desperado454
Progress!
Old 08-13-2012, 03:51 PM   #38
Flathead Smith
Flathead Smith's Avatar
Originally Posted by Desperado454 View Post
The monotony of my day to day garbage job has been having a direct effect on my life. Depressed, unmotivated and generally lost, I've not only turned to my tried and true mix of Jim Beam and off brand ginger ale, .......
I would argue that garbage collection is one of the most important jobs in existence. If there were no doctors people would survive, many would die from disease, but the fact is most would live. If there were no lawyers … well I’m not going to go into that. I can think of many people this world could possibly do without. Life would be worse and more difficult without many professions, but most people would survive. But if there was no one to take the refuse of the world and put in a safe place, there could not be enough people in the health care profession to deal with the disease that would occur. If you are gainfully employed doing an honest day’s job, you are in fact making the world a better place for us all doing the LORD’s work and have no reason at all to be lost. Plus, you also have the opportunity many of us do not, to run across some pretty cool stuff some idiot does not value, and has thrown away.
Flathead Smith is offline   Reply With Quote
Old 08-13-2012, 04:41 PM   #39
Desperado454
While you make a great point about the importance of garbage collection, I think you may have read into my Jim Beam and ginger ale fueled rant a little too literally. I'm not a garbage collector. I was merely stating how I felt my go nowhere job, which does nothing to make the world a better place, was comparable to garbage.
Old 08-16-2012, 03:04 AM   #40
Desperado454
Tonight concluded with the passenger side of the firewall almost completely welded and ground down. Turned out better than expected with minimal warping, which is rare for me. Next up is the driver side
Old 08-27-2012, 01:18 AM   #41
Desperado454
Almost done
Old 09-02-2012, 02:09 AM   #42
Desperado454
Well, the firewall is flat now. Mission accomplished. Unfortunately I no longer have a heater, wipers or a way to stop this product of the general. So, next on the agenda will be the task of re-implementing those features. Once again, I was sidetracked by future interior ideas when I acquired a center console from a first gen camaro. Looks like a potential fit to me, just hoping the matching shifter will be found. Pics:
Old 09-02-2012, 02:29 AM   #43
VA72C10
VA72C10
VA72C10's Avatar
Looking good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-02-2012, 06:47 AM   #44
burb1085
burb1085's Avatar
Very nice. Subscribed.
burb1085 is offline   Reply With Quote
Old 09-02-2012, 10:26 AM   #45
(541)COLD_beer
(541)COLD_beer's Avatar
I like your style Mr.
(541)COLD_beer is offline   Reply With Quote
Old 09-05-2012, 01:32 AM   #46
Desperado454
We have brakes again!
Old 09-05-2012, 05:58 AM   #47
79shortbed
79shortbed's Avatar
Hey man, I know how it is to not be motivated. I'm broke too! I wish I even had a job. Hang in there, let the truck be your motivation. The light at the end of the tunnel, this truck will be totally badass and built with YOUR hands. Great progress man, can't wait to see a video of it when you're finished.
1979 Custom Deluxe C10 SWB Fleetside
Help encourage me in my build.
LS 5.3 swap in progress!
79shortbed is offline   Reply With Quote
Old 09-05-2012, 09:04 AM   #48
JRANGER
JRANGER's Avatar
dang i like this build and that center console could turn out real nice
Old 09-05-2012, 11:52 AM   #49
canadian trucker
A day should have 30 hours.
Good Job,
keep up the great work.
canadian trucker is offline   Reply With Quote
Old 09-05-2012, 08:45 PM   #50
y5mgisi
Second Chance Program
y5mgisi's Avatar
This is one of the coolest builds on here right now to me. Much more interesting than the million dollar builds with a bunch of bolt on parts. I cant wait to see more progress on this.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
