08-31-2012, 11:21 AM | #26 |
Re: $219.99 for 3" Drop Spindles
Some of the spindles we have are QC rejects from Belltech. Meaning the finishing on the casting is not up to par or cosmetic defects. Belltech holds a high standard to their products.
08-31-2012, 05:47 PM | #27 |
shipping to 62401?
09-03-2012, 11:30 AM | #28 |
landarts
need total cost for a set of 3" drop spindles for a 72 shipped to 83669,
Also how do I order ? Directly from you or through your website? Jim
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
09-05-2012, 11:30 AM | #29 |
09-18-2012, 02:54 PM | #30 |
VA72C10
Any more of the "blem" belltechs? Do you offer brake setups also (6 lug 6x5.5) and how about tranny crossmembers or shock relocators/trac bars?
also...fyi your link is dead in your signature...tried to check your website out...
Looking for a 67-72 swb or blazer project in or around VA. |
09-18-2012, 03:02 PM | #31 | |
We offer a ton of brands just not on our website. If you can get me part numbers of what you want then I can get you pricing. The link redirects you in our sig. |
09-18-2012, 03:25 PM | #32 |
VA72C10
must be my old browser on this office comp because it's simply a dead link there...
Thanks for the quick response... I'll have to get part numbers but looking for Rear shock relocators Front shock relocators or at least reinforcements (2pr) Rear super trac bar (bolts to trailing arm not rear) Shocks (probably going with KYB because I have the part numbers for them and can get them cheap on ebay unless you have a better deal ) rear bag brackets (hats for the top) 5 gal air tank avs d2600 bags 6 lug 6x5.5 rotors with hardware (bearings/etc) to mount them to the spindles...
09-18-2012, 04:05 PM | #33 | |
Front shock relocators or at least reinforcements (2pr) $35.00 Rear super trac bar (bolts to trailing arm not rear) nada for you Shocks (probably going with KYB because I have the part numbers for them and can get them cheap on ebay unless you have a better deal ) I might just have a better deal. I just need your measurements rear bag brackets (hats for the top) you just need the circle or d shaped plates? 5 gal air tank $85.00 for 5gal aluminum avs d2600 bags $75.99 each 6 lug 6x5.5 rotors with hardware (bearings/etc) to mount them to the spindles... nada for you |
09-18-2012, 06:02 PM | #34 |
VA72C10
going with bags on the shocks...the ones you posted in the other thread will be fine since I'm planning the relocators...seems they end up being stock size...
what brand shock relocators? any pics? do the fronts raise them or just reinforce? on the rear bag mounts this is what I'm looking for...
09-18-2012, 10:09 PM | #35 |
anymore of the 3" belltech spindles? price and shipping to 78953?
flip kits? |
09-19-2012, 12:34 PM | #36 |
I have a 67 w/disc brakes on the front... would that make it compatible w/your drop spindles? If so, very interested
09-19-2012, 12:54 PM | #37 | |
What is the diameter of that bracket? |
09-19-2012, 12:55 PM | #38 |
09-19-2012, 12:57 PM | #39 |
09-19-2012, 02:36 PM | #40 |
09-19-2012, 02:50 PM | #41 |
03-31-2013, 09:43 PM | #42 |
how much for 3" drop spindles for 67" C-10
04-01-2013, 12:15 AM | #43 |
Belltech 3 inch drop part# Bell-3120 $311.00
04-01-2013, 03:53 AM | #44 |
Got some for a 73 c10 with the HD 1 1/4" rotors? 33578
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
