06-21-2012, 10:41 PM | #26 |
Re: My Red '70 Chevy Stepside
get the estimates but more important is a game plan and a time frame.
07-09-2012, 05:13 PM | #27 |
Updates:
-Put a new Edelbrock 1406 carb on, runs a lot smoother and doesnt cut out on me anymore! -rewired and resprayed a bunch of crud under the hood, looks a lot cleaner -Purchased Front Disc Conversion kit from ECE, going to install it when it isnt 100+ degrees outside -Still hunting for an auto column shifter
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
07-16-2012, 10:18 AM | #28 |
Installed some new valve covers over the weekend. Not much but they look nice haha.
09-25-2012, 11:06 AM | #29 |
[QUOTE=dmw319;5421717]thanks i appreciate it! Here are some more photos:
Great looking truck! And cute pup!!
__________________ Rob '72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187 Semper Fi and Gig'em Aggies! |
09-25-2012, 11:07 AM | #30 |
thanks Rob! I've done some more since last time I posted. Hopefully will post more pictures soon.
09-25-2012, 11:10 AM | #31 |
I have a question based off your pic....Where does the brake booster hose connect... Is it going into the Breather?
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
09-25-2012, 11:15 AM | #32 |
it connects to the back of the carb i believe
11-15-2012, 11:11 AM | #33 |
Update on the truck:
I purchased the 1" front / 3" rear drop springs for the truck with some new shocks too. But when I went to install them in the rear of the truck I found that the crossmember shell pieces that attach inbetween the frame and the rear springs were all rusted out. So I got some replacement steel and with the help of my friend and his welder we replaced that section of the frame! Its all patched up now and ready for some black spray paint. I bought a "new" crossmember and connecting shell pieces from a board member. Now I also have to make the decision about whether to replace the bed wood (10 years old, some is rotted on the sides) and also the cross sills and hardware, strips, etc. Either way, I am ready to get it done! My wife is pregnant and due Jan 28th so I am trying to get the bulk of this part of the project done. Here are some pics:
11-15-2012, 11:55 AM | #34 |
looking good !!!!!
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
11-20-2012, 10:14 AM | #35 |
Some more pics.
I went to put the new relocation brackets for the rear shocks and found the nuts rusted solid to the u-bolts/brackets that hold the trailing arms to the rear axle. So, I cut the u-bolts and new ones will be installed when they come in next week! Trailing arm ends are splitting a little but hopefully a large vice will close the gap up a bit, could also weld a small bead on the end of it too if needed. Im just ready to finish this suspension stuff!
11-20-2012, 09:43 PM | #36 | |
11-26-2012, 12:06 PM | #37 |
Well I got both u-bolts off in the back and decided to buy a NOS set of trailing arms from another forum member here. Mine were splitting really bad and also rusted through to a 2x4" hole on either side where they mounted to the axle. Hopefully once the u-bolts and new trailing arms come in I can bolt all this stuff back together!
11-26-2012, 08:02 PM | #38 | |
Eddie |
11-26-2012, 09:01 PM | #39 | |
11-27-2012, 09:59 AM | #40 | |
yea i had thought about swapping everything onto a new frame but dont really have the time, $, or space. so this will work. and i learned how to weld!
11-27-2012, 10:03 AM | #41 |
double post. sorry!
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 Last edited by dmw319; 11-27-2012 at 10:11 AM. |
12-04-2012, 10:09 AM | #42 |
Some more progress done last night. Got the NOS rear cross member installed, NOS trailing arms installed, new u-bolts for the axle, shock relocation brackets installed, new hardware all around and basically sprayed everything with some semi-gloss black spray paint. All it needs now is springs, shocks, and the bed put back!
12-04-2012, 11:27 AM | #43 |
Looks awesome man!!!
12-12-2012, 10:21 AM | #44 |
Shocks and springs are in! Got the wheels back on and remeasured the distance from the ground to the rear wheel well. Looks like it lowered it 2" on either side (still doesnt have the bed in it and front hasnt been lowered yet either)!
12-12-2012, 10:28 AM | #45 |
looking good !!!!!
12-12-2012, 12:34 PM | #46 |
Just found your project man. That's a clean lookin truck ya have there. Absolutley a fun truck to tinker with and cruise around! You'll like that ECE stuff, they make great stuff for exactly the kind of project you've got goin on here. Always good to see people taking on tasks for themselves and learning as they go! That is the same route I took, nothin beats hands on experience!
Keep workin forward man, you're making great progress! Subscribed.
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold *** First Ride <> '81 C10 Long Fleet *** Current Project *** |
12-12-2012, 02:21 PM | #47 |
Depending on where you live Body work can be as cheap as $45 an hour and if the shop is honest they wont charge you 6 or 7 thousand dollars that is a huge RIP OFF but dont take my word for it ask the guys here on the forums.
I like your truck very much, the guy who had it took care of it, lets just hope who ever did his body work did it right and there isnt an inch of bondo under the paint. Nice work on the repairs, it always brings a smile to my face when someone loves their truck enough to do it right. |
12-12-2012, 02:29 PM | #48 |
12-12-2012, 03:14 PM | #49 |
Thanks yall! I cant wait to get the front disc conversion and 1" drop finished off so I can drive her again.
02-18-2013, 11:24 AM | #50 |
Update with some pictures. Front disc conversion is complete!
Out with the old, in with the new
