Old 12-31-2012, 10:39 AM   #26
solidaxel
solidaxel's Avatar
Re: Stock Manifold Options for LS Swaps
Thanks guys, all good info for making a "right" decision!!
5.3 2006 going into my "new" 78 Silverado
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-31-2012, 10:43 AM   #27
solidaxel
solidaxel's Avatar
Re: TBSS Exhaust Manifold Info (Pictures)
Originally Posted by MAK191 View Post
I'm using TBSS manifolds with dirty dingo adjustable 73+ mounts with the matching stands and rubber. They fit great with zero issues, they are not even close to the mounts or stands. I did notice the part numbers cast on mine are 12567483(LT) & 12567484(RT). Not sure what the difference is.
I just received my Dirty Dingo motor mounts and compressor mount, but no instructions for the bag of bolts!
Could you show me a pic of the compressor mounted and the idler?
LS 3 4L70E
Old 01-01-2013, 04:56 AM   #28
mcmlxix
Collector of Projects
mcmlxix's Avatar
Originally Posted by mcmlxix View Post
I unded up using the Camaro 2 bolt manifolds but I had the local waterjust guy cut two 3/8" steel flanges for a 2.5" OD exhaust pipe....
GM part number 9220232 is for a 2010 Camaro exhaust manifold collector gasket. Its a metal (looks like stainless) gasket with crush ring of what looks like the old stlye (think lead and brillo pad) material... It has the 2.5" inner diameter.
I also bought a FelPro gasket of the same design but for a 3" diameter exhaust. I may make another set of flanges with the 3" hole. I only bought them becasue I thought they were the correct ones but couldn't get the dimensions. Not cheap at $18 each so I'll see if I can make them work for a 3" exhaust....
Rich
1972 K5 Blazer CST Click HERE
Old 01-26-2013, 10:16 AM   #29
mrhurt73
i went to my local napa store for the gaskets and exhaust studs and nuts.
studs and nuts are the same without the hex end on the stud.
and i did cut off the factory LM7 y-pipes and they do fit TBSS manifolds.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 11-21-2013, 09:44 PM   #30
83GMCK2500
How thick are the flanges on the TBSS Manifolds at the head?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 09-21-2014, 07:17 AM   #31
CharlieSheen
CharlieSheen's Avatar
I tried to order a set of these online through one of the online GM parts suppliers,and after the order was processed,was told that the left hand manifold #12600526 was not available,with no date for availability.Following up,they tell me it is most likely that the left TBSS manifold has been discontinued.Being that these manifolds was used on a fairly limited amount of vehicles it is likely that GM will just sell what is left,and that will be it.The right hand and heat shields are currently available.
Dorman has an aftermarket manifold,appears to be the same,but is more than double the cost.
CharlieSheen is offline   Reply With Quote
Old 01-01-2015, 02:46 PM   #32
cardreams
https://www.holley.com/products/exha...arts/8501-1HKR
You guys thing these would work as we'll ?
cardreams is offline   Reply With Quote
Old 01-01-2015, 07:51 PM   #33
mcmlxix
mcmlxix's Avatar
They seem to have the same basic profile as the 2010+ Camaro manifolds. I wouldn't spend the $400+ USD... They build Camaros in Canada.... find some take off manifolds...
Rich
Old 01-07-2015, 04:31 AM   #34
l92powered77
my stock l92 manifold will clear passenger side of my 77 but drivers side collectors empties into my frame rail...gonna check out if i can find 2010 up camaro ss or tbss manifolds...
l92powered77 is offline   Reply With Quote
Old 01-08-2015, 03:01 AM   #35
mcmlxix
mcmlxix's Avatar
http://www.ebay.com/itm/New-L99-LS3-...76cef4&vxp=mtr
Buy it now @ $159.99
Rich
Old 01-08-2015, 03:09 AM   #36
l92powered77
Thumbs up Re: Stock Manifold Options for LS Swaps
Tempting but 40 dollar shipping! Good eye am thinking about that
Old 01-08-2015, 03:12 AM   #37
mcmlxix
mcmlxix's Avatar
go sign up on Camaro 5 forums.. they are always selling take off manifolds.... thats where I got my sets...
Rich
Old 01-08-2015, 03:17 AM   #38
l92powered77
You slick devil you . Thats a great idea.
Old 01-24-2015, 09:47 PM   #39
Marty68
i just ordered tbss manifolds from gm parts direct. 129 shipped. no indication of back order. used Camaro manifolds on ebay $135. + and i would have to get down pipes i have flanges and down pipes.
Marty68 is offline   Reply With Quote
Old 01-24-2015, 10:17 PM   #40
slotard
I'm looking at buying an 04 2500HD with 6.0/4L80E. Will the stock manifolds on it not fit my '73 C20? Can a little clearancing be done? Probably going with the Dirty Dingo sliders, no AC.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-25-2015, 01:25 AM   #41
Marty68
look through this thread... http://67-72chevytrucks.com/vboard/s...d.php?t=566743
most are using tbss manifolds camaro manifolds or headers. from what i understand there needs to be come frame cutting to make the stock manifolds work. they ARE wide. i dont like the idea of cutting up an original short wb frame.
Old 01-25-2015, 09:57 AM   #42
dayj1
It really depends on exactly where you place the engine. In my '86, I used the stock truck manifolds and only had to trim a place in the passenger's frame rail about 1/2 inch "deep".
dayj1 is offline   Reply With Quote
Old 01-25-2015, 09:50 PM   #43
slotard
1/2" is significant trim, but I suppose I could add a little reinforcement to the flange (and maybe the web too). Where did you place your engine?
1973 C20, 350/350
Old 01-26-2015, 09:36 AM   #44
lowlyfec10
scored some TBSS manifolds for 30 shipped! has one section of a downpipe...so i need to source another or find a flange that works
lowlyfec10 is offline   Reply With Quote
Old 01-26-2015, 08:22 PM   #45
Old_Truck_Fan
Not sure if this is common knowledge but the 2012+ Camaro ZL1 exhaust manifolds are stainless steel versions of the common 2010+ Camaro SS manifolds. Headers are a common upgrade on ZL1s so you can usually find low mileage versions around the web.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675
2011 Dodge Ram 1500
2012 Camaro ZL1
Old_Truck_Fan is offline   Reply With Quote
Old 01-27-2015, 01:04 AM   #46
Marty68
where? if you find a left... the new ones i ordered one was back ordered...
Old 01-27-2015, 01:54 PM   #47
Marty68
Angry Re: Stock Manifold Options for LS Swaps
I ordered a pair from gmpartsdirect. left side back ordered. no time frame to be shipped. they said "we cant cancel whole order." I contacted another online parts seller about availability... left side back ordered from gm. I couldn't find a part number for left side dorman... so I found a Buick Ranier, cross referenced to same part number. $45 ea. however shipping may be $$
I convinced them to cancel order.
Old 07-01-2015, 07:28 AM   #48
mcmlxix
mcmlxix's Avatar
I would love to upgrade to stainless steel manifolds.... anyone find a PN?
Rich
Old 07-01-2015, 10:57 AM   #49
dayj1
12622623 and 12622624 for left and right, respectively. The heat shields are 12596750 and 12611200. List price for all that is $1291.39! I think I'd just buy some headers
Old 07-01-2015, 08:12 PM   #50
Old_Truck_Fan
There is a set on ebay for $385 OBO.
http://www.ebay.com/itm/ZL1-CAMARO-S...5177fe&vxp=mtr
2011 Dodge Ram 1500
2012 Camaro ZL1
fuvk off
