07-09-2012, 01:43 PM | #26 | |
Re: 64 1ton (delivery day)
07-09-2012, 04:23 PM | #27 |
The first two she thought were cool, number three was just a cab to replace one I sold off and was a factory A/C cab....then number four just "showed" up.....she didn't think they were cool anymore. I have a 1965 SWB BBW thats getting close to being done and will be fun to drive before I sell it, then onto a 1964 SWB BBW. She see's cost and thats about it...Its all good!
I do need a frame of a 1 ton for the 1965 A/C cab (with bill of sale) so when I sell it someone won't have issues in some of those other states! |
07-10-2012, 12:03 PM | #28 |
well moved my 454 today, i had to pull it and move it from my house next door and as always it worked like a charm and the ole truck hardly even knew it was hanging off the back.
07-10-2012, 12:08 PM | #29 |
nice putting that truck to work. bet she didnt feel the weight hanging in the back of her, what about that 57 in the garage?
Posted via Mobile Device |
07-10-2012, 12:16 PM | #30 |
well the 454 will be going in the ole truck once it cools down and i can work outside more than a few hrs, the 57 is one i just got done with about 3 yrs ago. SBC and 4spd, leather interior, P/S Disk Brakes ETC.
07-18-2012, 04:28 PM | #31 |
hey do you guys like the sign on the side box ?
07-18-2012, 06:16 PM | #32 |
neat sign, looks like you are putting the old truck to work, nice.
-W |
07-18-2012, 07:13 PM | #33 |
08-06-2012, 09:31 PM | #34 |
well i painted the front bumper and crane, what do you think.
08-06-2012, 11:44 PM | #35 |
60-66 Nut
Looks good
It helps break up all the white. Real nice crane you put on the bed.
08-07-2012, 10:04 AM | #36 |
yeah i agree just to much white, next i will paint the chevrolet script on the grill red,
08-11-2012, 11:17 PM | #37 |
ok i suck at detail painting, i tried to paint the chevrolet script oh not good any hints ? help
oh i found my gas air compressor, i go pick it up tomorrow. |
08-12-2012, 12:14 AM | #38 |
Rollin' Old Skool
are you referring to the script in the grille? if so, they make decals for that
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
08-12-2012, 12:22 AM | #39 |
i did not know that ! thanks.
08-12-2012, 12:34 AM | #40 |
Rollin' Old Skool
no problem! i know classicparts.com carries them, & i'm sure several other classic truck part vendors do as well....someone also mentioned a vendor on Ebay as well that offers them in various color choices, but i'm not sure which seller it was
08-12-2012, 03:17 AM | #41 |
I think you need to have some bedliner shot on it. Since your in the heated south talk to them about going with a colored liner, like tan. It will protect the bed, give a little cushion to what ever you set on it and not be so hot like black would be.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
08-12-2012, 09:32 AM | #42 |
that is on my list of things to do, yeah black would be bad in Az. tan would be good, or maybe a gray.
08-12-2012, 08:25 PM | #43 |
cool i found the script decals, $5.00 saves alot of frustration
today i got my gas powered air compressor, i will work on getting it mounted this week, next i need to find a Onan electric start gen. then i will just about be done with the service bed, then i can start on the interior. once i get the compressor mounted i will update the pictures. this has been a fun build. |
08-14-2012, 06:43 PM | #44 |
well i got the compressor mounted, all with grade 8 hardware, it's starting to look like a small service truck.
08-24-2012, 10:03 PM | #45 |
well i worked on it today, hung the hyd. ram. and jacked it up for the first time, wow it's tall, i also fabricated the the rest for the boom, i cant weld so i will have to get a friend to take care of that for me (pacemaker) can't do it just sucks , but better then dead.
08-25-2012, 12:50 AM | #46 |
60-66 Nut
Is there a winch at the base of that boom? Are you going to add some outriggers?
08-25-2012, 04:02 PM | #47 |
there will be a winch soon, i bought this crane cheap knowing it would need work, i have started fabricating the outriggers just need them welded up , they should come out about 2.5 ft on each side, the max weight is 3000 lbs.
09-03-2012, 09:16 PM | #48 |
well last week i got the winch mounted on my crane, but i still need to wire it up, i also mounted and plumbed my generator, since the tank on the generator was bad i plumbed the fuel from my main tank, and hooked up a low PSI electric fuel pump, i have not run this thing in about 12 yrs, so i changed the oil primed the carb, and gave it a pull and WOW it started on the first pull and ran it for about an hr, i was just amazed it ran that good.
i will get some pictures posted soon. does anyone else have a vintage service or work truck that they want to post some pictures ? |
09-12-2012, 02:18 PM | #49 |
so i got the crane working, it's like a big toy, LOL.
i also found and hung my other tool box on the passenger side , i took the brown box off i did not like it, i hope to find one about 48" long but aluminum on Craigslist or ?? i also put my vice on the bed it's like a big roll a way tool box that i can drive. i hope to move on to the inside of the cab next but we will see. |
09-12-2012, 02:40 PM | #50 |
Rollin' Old Skool
very cool! I think it looks great...nice work
