12-05-2012, 03:13 AM | #26 |
Re: 1972 Jimmy 4x4-Hillbilly Budget Build
mcmlxix, I just checked your build thread and all I can say is wow...im jealous
"You may be a redneck if... you have spent more on your pickup truck than on your education." |
12-05-2012, 03:23 AM | #27 | |
Collector of Projects
06-10-2013, 08:35 PM | #28 |
I haven't been home much lately but I have been able to get some work done here and there.
I had a couple of engines laying around so I was able to piece together a decent one. Its a 350 with 4 bolt mains, flat top pistons, edelbrock performer intake, summit 1103 cam, camel hump heads and the stock carb for now. I also purchased some 37" Goodyear MTR HMMWV takeoffs.
02-10-2014, 05:26 AM | #29 |
Been a while since I updated this thread but I have not been slacking on the work! I pulled the front end off again to finish up the front suspension and put in the engine.
I cut F250 shock towers and welded/bolted them on to fit the extended shocks. I was a little disappointed with how much droop the Superlift softrides had at full bump, we will see how it handles... Engine in!! Engine build ended up being flat top pistons, summit 1103 cam and lifters, camel hump heads, edelbrock performer intake, holley 670 truck avenger and summit headers. <br> I ended up putting in a 1" zero rate to recenter the rear axle from the shackle flip and 63's. I am really happy with the height/tire combo and should be ok off road. The truck is now registered/insured and I recently drove it for the first time ever. I was surprised with how healthy the engine turned out! The ride seems pretty smooth so far but it wanders like crazy. Next on the list is to put on side mirrors, get an alignment/fix wander, rhino line the cab and roof, and enjoy it! How bad does everyone else's truck wander around 55mph? is it normal?
"You may be a redneck if... you have spent more on your pickup truck than on your education." Last edited by The Gibster; 02-10-2014 at 05:41 AM. |
02-10-2014, 09:56 AM | #30 |
GEARHEAD
Its coming along nice. Looks good. You got the stance good. Congrats on driving it. As for the wandering, it's not normal to wander all over. Not unusual for a little bit, but it probably needs more caster angle and the toe in my be off a bit. The alignment should help.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
