#26 |
![]() Join Date: Jun 2009
Re: Factory Rear Swaybar Hard to come by
I don't know what this would take to put on a coil spring rearend. I don't ship greyhound as I don't have a terminal near me. I ship these FedEx and it usually runs from $30-45 depending on where it is shipped. They weigh 45 pounds boxed
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
#27 |
pm me with a price please
riding... just riding....... |
#28 |
I actually picked the last one up I had available yesterday. I had someone else contact me first and didn't want to get back to anyone until I physically had it in my possession. I will give Cheyenne Dan until tomorrow night and then you are up if you still want it.
#29 |
thanks
#30 |
how do these attach to 1/2 ton rearends?...the tube dia is larger for the 14 bolt diffs isnt it? so u-bolt spacing for that bracket wouldnt match right?
If they do fit add me to list
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
#31 |
The bottom plate holes are oval so there is some room for adjustment
#32 |
okay great...thanks
#33 |
Any word?
#34 |
#35 |
PM him for direct contact.
#36 |
#37 |
Sent a PM. Came up with another rear bar today.
#38 |
There's no difference between a reason and an excuse... I am sorry
![]() These rear sway bars are stiffer than all aftermarket bars I've researched. (Not Bethlehem steel, metallurgy, and surface area) make them PERFECT for building a corner carving machine. With a flip, 1" shackle (to keep pinion angle,) THIS BAR, and a fairly soft shock, the rear would be done. Well, on a longbed. With the shorter frame, for less flex, a softer (aftermarket) bar would work. However, I will add that no matter the genre of vehicle I've built, I've NEVER had an aftermarket part fit nearly as well... Never! I'm surprised one of the cats off the "make it handle" topic haven't been all over this! Good luck with the sale and we'll be in touch for parts!!!
#39 |
Drag Racer
do these change ride quality at all, also, do these work well with flip kits that already have VERY tight clearances between the shock mounts and bottom of leaf spring assy? i had to fight hard just to get my shocks in, and the plate is actually sitting on my shock mount, or within literally a HAIR away from it.
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 |
#40 | |
Per your PM no worries! I understand. Good luck on your recovery and God bless Posted via Mobile Device
#41 |
Junior Member
![]() Join Date: Dec 2011
I'm interested if you still have one.
If it wasn't for the last minute, nothing would ever get done. 1953 3800 - SRW C&C Dump - 216/SM420 1985 K30 Scottsdale - SRW - 6.2/SM465/NP205 (Sold) |
#42 |
I do still have it. Will send you a PM with my email address
#43 |
The rear bar is still available. Will be starting a seperate post for the 1 and 1/4" front bar
#44 |
just found this thread, any idea if one could work on the rear of a k30 with 4 inch lift blocks if you used longer rod ends? (or whatever those connecting rods are called)
1987 GMC V3500 Sierra Classic |
#45 | |
![]() I am more interested in experimenting with those mounting plates and seeing if I could use those plates on top of the springs as opposed to outside the saddle for the tube. I HATE that style of axle-spring connection.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
#46 |
I am also not sure on using this on a lifted vehicle. I would think longer end links would do the trick
#47 |
They work fine on a lifted truck. I had one on my old k30 that was lifted. You just need longer sway bar endlinks. You can get 3/8" ID seemless tube to make longer links.
#48 |
I will take one...33578
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#49 |
I am out of town but will returning Sunday. I will get a quote then.
#50 |
Sending PM now. I need to know what you are putting this on to know what parts you will need. Less parts = Less shipping cost
