10-11-2012, 09:11 PM | #26 |
Re: PROJECT EVOLUTION 70 jimmy build
Nice work!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
10-13-2012, 07:24 AM | #27 |
its coming along,,goin through the diffs now,,puttin new seals and bearings
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
10-17-2012, 08:28 PM | #28 |
getting the transfer case all tore down,,replacing all gaskets and checking all the bearings...those needle bearings are a serious PITA.
10-17-2012, 08:30 PM | #29 |
found some center caps that cover the lug nuts,,i really dont like looking at lug nuts,,i remembered eagle made some of these caps about 10 years ago,,so i just had to find some,,had to cut the fronts to fit,,but i like the look
10-30-2012, 11:43 PM | #30 |
finally got the transfer case done and painted,,also got the front bumper brackets blasted and painted,,,still looking for my donor truck for my ls swap
11-09-2012, 05:12 PM | #31 |
scored this roll bar today..oh yeah...it was FREE
11-12-2012, 06:06 PM | #32 |
Neat trick covering the front hub, I like the nice clean look.
11-16-2012, 10:13 PM | #33 |
me too,, i really hate looking at lug nuts
11-18-2012, 06:55 PM | #34 |
11-19-2012, 10:39 AM | #35 |
PROJECT 7DEUCE
Chassis is really comming along... Congrats on getting all the rust removed..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-19-2012, 09:23 PM | #36 |
it slides right over the hub,,about an 1/8 of an inch clearance all around it..no issues what so ever
11-19-2012, 09:25 PM | #37 |
thanx..it would be coming along alot faster if i had a chance to get a doner truck for the engine/tranny,,been workin 14 hr days for awhile now...just aint enough time in the day
12-02-2012, 11:18 AM | #38 |
FixerUpper
Thats looking real good your boy should like it alot , with all the work to get it back in shape .
1-Cheyenne 72 700R4,camper special all original when i got it then i improved it a little Blue and White 3.73,4 core rad, 700r4,MSD hei ,turbo muffs dual exhaust only had 50 k on it when i bought original mile sweet old ladies truck turned into a stump puller No. 2 C-10 72 w/air and Tilt and power and the cheyenne trim package shtbd is dropped 2-3w/factory tilt has torq thrust 2 rims 2003 dodge neon steel blue color |
12-13-2012, 03:28 PM | #39 |
not a whole lot of progress, but got the shocks,front braided stainless steel brake lines and the steering stabilizer on
12-21-2012, 08:58 PM | #40 |
Just like to part out trucks!!
WOW your doing AWSOME!!!
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
12-21-2012, 10:14 PM | #41 |
finally got my donor vehicle..ended up buying a 2001 yukon that was rolled, has 130k on it so it will be just right for this baby. i should have it home on monday then get to takin it apart
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 Last edited by hilljob26; 12-25-2012 at 11:05 PM. |
12-24-2012, 02:29 PM | #42 |
finally got the doner truck here 2001 yukon
12-26-2012, 01:39 AM | #43 |
Your truck looks great, what brand of sandblaster are you using? I'm considering sandblasting and painting my small parts and frame myself to save alot of cash and not to mention paying someone to haul everything back and forth to the sandblaster and paint shop and not scratch anything.
Scott |
12-26-2012, 01:50 AM | #44 |
i just bought one from sears for like 60 bucks, and ordered a blasting helmet off ebay for 20 bucks,,i get 50lb bags of blasting media at orschelins for around 10 bucks a bag..as far as my cabinet, it was just one i picked up at harbor freight
12-26-2012, 01:54 AM | #45 |
So it's definitely worth it to do it myself. I hope the neighbors don't mind a little dust, they've been supportive this far along in my build. Thanks
Scott |
12-26-2012, 02:23 AM | #46 |
well, the guy in town wanted 250 bucks to sand blast it,,but i would have to haul it,wait,then haul it back...but yeah it was worth it, i saved about half of that i guess
12-28-2012, 10:07 PM | #47 |
finally got the engine pulled
12-30-2012, 07:49 PM | #48 |
got 90% of the motor mounts done, still have to get it on the frame, but waiting on getting the spacer for the tranny and transfer case,,but lookin good,,just ended up buying the actual bushing from DIY and fabbed up the rest
01-01-2013, 03:21 PM | #49 |
GEARHEAD
Looking good.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
01-11-2013, 02:59 PM | #50 |
well, i got the engine all cleaned up,,looks pretty cool
