11-15-2012, 11:03 PM | #26 |
Petroleum User
Re: Mdo 69
Looks better than I thought it would! Definitely unique. Id leave it with no emblem and let people squirm trying to figure out what kind of truck you have
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
11-15-2012, 11:35 PM | #27 |
Re: Mdo 69
I'll keep my eyes open if I come across one of those grilles i might just try it out
Posted via Mobile Device |
11-29-2012, 10:44 PM | #28 |
Re: Mdo 69
im going a little out of order, i had problems with my desktop. Here are some pics from earlier in the project when i started working on the cab.
11-29-2012, 10:56 PM | #29 |
Re: Mdo 69
When I bought this truck it had a 4yr old paint job, so it looked ok, but under the new paint job were huge dents and lots of rust, had i known what I was getting into I would have not begun this project as I did.
11-29-2012, 10:59 PM | #30 |
Re: Mdo 69
After lots of body work Its now ready for the wet sanding
11-29-2012, 11:04 PM | #31 |
Re: Mdo 69
I had to cut out all the old patch work, and the after market parts are so crappy they dont even work with each other
11-29-2012, 11:14 PM | #32 |
Re: Mdo 69
as you all can see the previous patch work sucks. I painted my frame with POR 15 black on the frame and POR 15 silver on the drive shaft and motor mounts. I went with dirty dingo adjustable brackets and the motor mount perches are from a 78 c10. i went this route because ive got $150 in that setup and has about 4 inches of adjustment
11-29-2012, 11:22 PM | #33 |
Re: Mdo 69
I installed my lowering springs, they are CPP 3 and 5" drop I dont know if im going use those springs, because i dont know how low it will go. Body shop class wont start back up until mid Jan 2013. So i had to bring my cab home, the frame alone looks sexy, with the cab on it, not so much.
11-29-2012, 11:34 PM | #34 |
Re: Mdo 69
I am also attemping to redu my own wiring harness, I figure whats the worst that can happen, I buy a new one, well if I pull it off i save $500+
I've been using lt1swap.com and really its not so bad, the trick is to take your time and double check and trace everything before you clip and wires. |
12-05-2012, 03:00 PM | #35 |
Re: Mdo 69
I ordered a 70 chevelle gas tank from Rockauto it is set up for cars equipped with later model fuel injected motors, I called the manufacturer in Canada and they said the pump is set up to work with ls type motors. The tank, straps,gas cap, and wix 33737 fuel filter, total package shipped was $434. I think it is a great deal, I hope it works.
Posted via Mobile Device Last edited by Rudy-g; 12-23-2012 at 07:18 PM. |
12-07-2012, 08:12 PM | #36 |
Re: Mdo 69
I'm going to do the 5 lug conversion and all wheel disc brakes with a 3,5 lowering, I'm going to use cpp parts,
I received the chevelle tank today, but it was damaged, so I sent it back. In order to mount the tank I need to change my Trac bar due to the 5" drop,after mounting the Trac bar I will know where to mount my tank. Posted via Mobile Device Posted via Mobile Device |
12-09-2012, 06:02 PM | #37 |
Re: Mdo 69
heres a recent pic of the gmc, i added CPP 3" drop coils in the front the rear has 5"
I'm adding a few pics of the suspension parts im getting from CPP, I dont know if im going to stay 3/5 drop or get 3/4 since the kit comes with 2 1/2 drop spindles and what ever coils you want. I added a picture of a sierra I came across online, I like the paint color its got, what do you guys think about it, would it look good on mine? |
12-12-2012, 11:24 PM | #38 |
Re: Mdo 69
set my bed one the frame, for storage, it was at my dad's house. I think im going to go a different route then CPP. I have a friend that has a short wheel base 5 lug frame with new brakes and tie rods and 373 rear end with 15x8 rally wheels with rings and centers for $500, my truck has a 307 rear end so I think getting my friends frame is my best bet.
picture is blurry, didnt wipe the dust off my phone before i took it. |
12-15-2012, 06:13 PM | #39 |
Re: Mdo 69
heres my chevelle tank with efi pump, I had the tank mocked up and forgot to take a pic of it, sorry.
12-19-2012, 09:00 PM | #40 |
Re: Mdo 69
I picked up the 71-72 frame, its been worked on. It has been c-notched and the lower a-arms have been modified. Im only going to use the spindles, rotors, calipers, tie rods, and the rear end.
I haven't been able to work on my gas tank, because I need the bed off the frame. The only time I can work on it is when I have help getting the bed off the frame and then back on the frame. I don't want to leave the bed outside. I hope I can get the gas tank installed and hopefully fire up the engine this weekend. |
12-20-2012, 09:06 AM | #41 |
Re: Mdo 69
Nice Work! I'm right over the mountain in Greeneville, TN. Nice to see these old trucks running around these hills like the old days!
Bake “The Gunny” USMC 1990-2011-Retired 69 C10 Suburban 350/350 69 C10 SWB - project 66 Galaxie 500 - 460/5 speed 99 F550 Crewcab Western Hauler bed |
12-20-2012, 12:15 PM | #42 |
67cheby
Re: Mdo 69
great looking project !
12-21-2012, 12:33 AM | #43 |
Re: Mdo 69
Hello in Tennessee. Thank you guys for your comments.
I believe I have all the hardware that I may need to mount my tank. I'm going to need a few more feet of high pressure fuel hose, radiator hoses, and new oil filter. I ordered Trailblazer SS exhaust manifolds. I also have to add the fuse block and relays to my wiring harness. When I get all that put together I will attempt to start the engine. Hopefully by Sunday. Posted via Mobile Device Posted via Mobile Device |
12-23-2012, 06:42 PM | #44 |
Re: Mdo 69
A to do list, I'm sure ill need a lot more stuff
Body Door patch panels Fuel Strap tank to frame Modify filler neck Modify sending unit Buy more 3/8 hose Assemble fuel hoses Engine Install TBSS manifolds Add fuse block to Harness Buy oil filter Buy Air filter Buy Radiator hoses Plug brake booster vacuum hose Hook up power steering Bypass Heater core Transmission Cut drive shaft Hook up cooler lines Drive ability Swap disc brake front end Buy Shocks Buy Brake lines Buy Brake hoses Buy Rear wheel cylinders Buy Gear oil Buy Tires maybe wheels Buy Wiring harness Buy Instrument panel Maybe replace Steering column Buy Front bumper Buy Grille Buy Carpet Posted via Mobile Device Posted via Mobile Device |
12-23-2012, 08:39 PM | #45 |
Re: Mdo 69
Looking good! I'm in for the project.
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
12-23-2012, 10:02 PM | #46 |
Re: Mdo 69
Loving the progress! You've come a long way already! I bet that motor will be great!
12-23-2012, 10:12 PM | #47 |
Re: Mdo 69
Thanks lefty, I sure hope that motor don't let me down.
12-23-2012, 10:51 PM | #48 |
Re: Mdo 69
Hey Rudy, how did you apply the POR 15 to the frame?
12-23-2012, 10:59 PM | #49 |
Re: Mdo 69
I brushed it on, turned out really nice and smooth, I bought about 10 $1 brushes at the hardware store. I had to through them away after one use.
12-24-2012, 08:44 PM | #50 |
Re: Mdo 69
I recieved my Trailblazer SS exhaust manifolds today.
I'll bolt them up to the motor tomorrow and post some pictures. I mocked up the passenger side and it fit great, plenty of clearance. I might be speaking to soon, but I think $135 shipped from gmpartsdirect.com was a good deal. Posted via Mobile Device |
