04-03-2017, 05:40 PM | #26 | |
Re: Post your pics of 60-66 BIG BLOCK only trucks / engines
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
04-03-2017, 06:43 PM | #27 |
Moderator
Man there's nothing not to like about that truck.
04-04-2017, 08:25 AM | #28 | |
This is the alternator and PS bracket setup I used. Does this look right to you? My alternator seems to be further back and out of alignment with the crank and WP pulleys which I know are correct. Any help would be great Thanks Keith |
04-04-2017, 08:59 AM | #29 |
Yes , those are what I used but there are SO many different offset pulleys I suspect thats where your trouble is. Pictures of those may help
04-04-2017, 09:02 AM | #30 |
good to know. i will check the pulleys one more time.
so you didnt have to trim the inner fender for the pump to fit?? i was trying to use the PS pump w/reservoir. i may try your remote setup. thanks again. |
04-04-2017, 09:12 AM | #31 |
Your brackets are for the remote setup. Here it is on a 67 Chevelle
http://www.chevelles.com/forums/16-b...ket-66-ss.html
04-04-2017, 09:17 AM | #32 |
Heres a truck unit , same basic thing. The idea is for the pump to raise up over the frame. I did shorten my main bracket just a bit.http://67-72chevytrucks.com/vboard/s...Power+steering
04-04-2017, 09:20 AM | #33 |
thanks!
04-04-2017, 01:43 PM | #34 |
What do I need to take the 292 out and put in my 454? Will the stock small block frame mounts work? Or is there a better way?
04-04-2017, 02:12 PM | #35 |
This is an updated picture from the last.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
04-04-2017, 02:13 PM | #36 |
You can see how I went in my build thread. Been driving the truck for about 3 years now with about 9000 miles put on.
04-04-2017, 02:24 PM | #37 | |
04-04-2017, 06:37 PM | #38 |
CQQL!! Will 68-72 small block frame mounts work? Or should I look for the BB mounts?
04-04-2017, 07:21 PM | #39 |
Big Block only. Junk yards or guys that part these out on our parts boards here are more reasonably sometimes. They can be pricey being for the BB , however I would think unless you can do bodywork for the needed modifications to your firewall, it will equal in cost of the mounts.
04-04-2017, 09:40 PM | #40 |
I saw today that POL has tubular frame mounts that move the engine forward for HEI. They "claim" they will work for big and small block because of that. Do you know anyone who has used them? I don't want to spent $130, but if no firewall work is needed, might not be a bad deal. Like most of the 60-66's, mine needs its share of sheet metal work already. It's a C30 panel, converted to bus when new. That means four more feet of cancer. LOL!!!
Now I'll try to see how to get to the parts section of this website. I'm computer challenged. |
04-05-2017, 08:02 AM | #41 |
I used the tubular mounts but I had to massage the firewall in two places for valve cover clearance just a little.
04-05-2017, 10:28 AM | #42 |
I think I now know what I need to get the power steering mounted to the 409 for my 61 !
Thanks Jon for those photos !!
Living The Canadian Dream in British Columbia |
04-05-2017, 12:10 PM | #43 |
tubular mounts.
04-05-2017, 12:56 PM | #44 |
Did some research and found a hot rod shop in Everett that carries OM frame brackets for the 67-70 BB. WOW!! So I figured what the heck, give Chevy a call to see if the parts are still avail thru them. I'll post what I find out.
Thank you everyone for all the help!! |
04-05-2017, 11:26 PM | #45 |
60-66 Nut
Here is a source for the frame brackets and the big block engine mounts themselves.
http://www.manestruckparts.com/store...Category_ID=16 http://www.manestruckparts.com/store...Category_ID=16 These can sometimes be found in the '67-'72 classifieds here on the forum.
04-06-2017, 12:56 AM | #46 |
Brothers has the frame parts on sale for $120. The motor mount is the same price. Lil more money to go OEM over tubular, but if it saves the firewall ........
Now I know what to do up front. Time to research the rear end. I want to put in my 74 C20 14 bolt. (its new with 3:73) Is there a rear end thread like this engine thread? BTW, My 454 is .30 over, 9:1, balanced, RV cam, air gap intake, full tube headers. 2.5" Flowmasters, TH400 with shift kit and a Gear Venders overdrive. I plan on towing my 1976 32' Silver Streak RV. I think the C30 bus should do the trick in style. |
04-06-2017, 08:59 AM | #47 |
Moderator
Those sure do look like performance online. See the way the top frame rail is trimmed back.
https://www.performanceonline.com/19...-Brackets-V-8/
04-06-2017, 10:39 AM | #48 | |
04-07-2017, 12:02 AM | #49 | |
60-66 Nut
Here is a thread on a 14 bolt swap.
http://www.67-72chevytrucks.com/vboa...d.php?t=624445 And the for sale thread for the mounts that I make. http://www.67-72chevytrucks.com/vboa...d.php?t=620836 Quote:
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-25-2019 at 01:18 AM. |
04-07-2017, 12:46 AM | #50 |
The 65 C30 and 74 C20 have leaf springs. I'll get width measurements from both trucks tomorrow. I hope they are close. The springs are the same width.
