02-07-2013, 08:49 PM | #26 |
Carpe manana
Re: Anyone rebuilt an OEM sliding rear window?
Aftermarket pieces are available. Not an OEM match but they work. Last one I got was from Mike's Bump and Grind Garage, now out of business I believe. I'd call Wes at Classic Heartbeat or try another board vender.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-07-2013, 10:29 PM | #27 |
If one is patient one might try and find a slider that is cheap and buy it for parts.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
02-07-2013, 10:57 PM | #28 |
Looks good, I cant wait until you get it back together. If everything is tight and leak free I will by me a slider and do the same thing. Thank you for posting this up for everyone.
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985 "The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945 |
02-07-2013, 11:22 PM | #29 |
My 80 K10 has the rear slider. The local auto glass shop here in Lewiston had the upper and lower sweeps. Perfect match. They also had the catch assembly. Another perfect match. If I remember correctly these two items came to around 20 bucks. The rubber between the two glass panels came from the RV shop here in Clarkston. Perfect match and free at that.
71 Chevy Suburban build 71 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=556132 80 K10 http://67-72chevytrucks.com/vboard/s...d.php?t=559565 |
02-08-2013, 08:25 AM | #30 |
1969 Custom 30 wrecker
I hear that. You'll just end up with another one that needs new seals.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
05-04-2013, 12:27 PM | #31 |
Anyone has done rebuilding his sliding window? After all discussion.
What model of sliding woindow? What website did you buy from? What is the spesific size or number of product? Posted via Mobile Device
email me @ nasser_060@hotmail.com and Check out my flicker @ http://www.flickr.com/photos/0060/ |
05-04-2013, 12:35 PM | #32 | |
Can you tell the PART NO for each one? How many inches did you need? Posted via Mobile Device
05-04-2013, 12:40 PM | #33 |
Carpe manana
Sorry no more progress on my end yet - have been way too busy but my schedule is slowly easing up. I've posted all the details I have so far as regards the specific parts. I will finish this. I have to for my K20 build (link in signature below) and will post here once I'm back on the job. It's getting the right rubber parts that's the challenge - the slider is easy to assemble/disassemble.
06-20-2013, 06:55 PM | #34 |
Does anyone have the part number or company of the OE latch? I always thought my slider was aftermarket, but now I'm not sure, maybe just my latch. It was built by SouthCo Lester Pa. The rest of the window looks too contoured to be aftermarket.
-Mike Psalm 25 '71 Custom Camper 20-400 http://67-72chevytrucks.com/vboard/s...d.php?t=421720 |
06-20-2013, 07:21 PM | #35 |
Carpe manana
These are/were available - I got one a while ago from Mike's Bump and Grind Garage - not sure the company is currently in business. Maybe Wes at Classic Heartbeat would have an idea?
06-20-2013, 08:26 PM | #36 |
If I remember correctly that latch was used on numerous years after 1972 and was still available from GM the last time I got one. I have 2 maybe 3 factory sliders up in my attic!
09-27-2013, 01:17 PM | #37 |
Carpe manana
Finally completed the slider rebuild and it works well (pics installed on my K20). However, the vertical aluminum trim/handles had to be re-attached with silicone so I have concerns about long term longevity. As a consequence. I open the slider windows using the firmly affixed midline trim where the latch pieces attach. Who knows, it may hold up for a long time. The white weatherstrip shown in post #24 worked fine but I had to shave the base of the molding's "T" with a scalpel in order for it to fit inside the trim channel. Even with that, the fit was snug so I used Windex along the channel and inserted a dowel inside the wstrip to apply force along its long axis so as not to pull it out of the channel. The chunky rubber corner blocks (ex. on last pic post #8) cleaned up real well and honestly look fresh.
As an aside, I had rear window trim installed with the slider but GM shipped slider-equipped trucks without the rear window trim.
09-27-2013, 03:00 PM | #38 |
Wow Pete...truck and slider window look really nice.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
09-27-2013, 04:36 PM | #39 |
Looks good at 20-ft .....
Try a local "aluminum products," & storm windows, & window replacements store. Auto glass shops probably wouldn't have the same kinds of weatherstripping on hand.
I had a siding, guttering & window replacement & storm window business for many years, & we had rolls & rolls of lotsa (dozen or more) different styles of similar weatherstripping that I kept on hand to do repairs. Had what looked to be a twin for the compressible tube weatherstripping in the photos. Not an uncommon type at all. Shouldn't be too hard to find. If it wants to slip out after installed, "stake-it" into place near the bottom of the track - we always used a small straight tipped screw driver to punch down (lightly) the sides of the track that the bottom (T-part) slides in. That stops it from sliding down / falling out when the sun gets on it & softens the rubber & stretches the aluminum track a little bit. Dave Ellis Mtn Home, AR Last edited by 68shortstep; 09-27-2013 at 04:40 PM. Reason: added some words |
09-27-2013, 04:56 PM | #40 |
is the outside gasket/seal the same as the regular glass, i noticed that they are not listed in any catalog, for a slider
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
09-27-2013, 06:31 PM | #41 | |
Carpe manana
Thanks Larry!!
09-27-2013, 06:36 PM | #42 |
Carpe manana
Yep, same gasket you choose trim or no trim depending on whether you are using trim or not - just like that for regular one-piece glass. Pete
