Old 01-10-2013, 10:22 AM   #26
198plus
198plus's Avatar
Re: How To Restore and Detail an Original Gauge Cluster
Thanks for sharing
198plus is offline   Reply With Quote
Old 01-10-2013, 12:09 PM   #27
aggie91
I'm just glad to be here!
aggie91's Avatar
I always enjoy your work. For a young guy you have great skills and an eye for detail.
If you have a bezel that the lower center screw hole is cracked, what do you do to fix it?
I will be doing mine this year, but mine is only the idiot light version so I will have less work to do ..
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-10-2013, 09:01 PM   #28
theastronaut
theastronaut's Avatar
I've never repaired one that was cracked, but it would probably be best to grind out the crack completely to keep it from spreading. Thick two part epoxy might work to fill the gap since there isn't much strain on that area. I don't think it can be welded since it's pot metal.
theastronaut is offline   Reply With Quote
Old 01-10-2013, 09:14 PM   #29
theastronaut
Originally Posted by LostMy65 View Post
Added to Faq's
http://67-72chevytrucks.com/vboard/s...79#post5807579
Thanks, I've never seen that FAQ list! I've seen others on here but completely missed the one for my "home" 60-66 section.
Old 01-11-2013, 02:01 PM   #30
jsdoyle
jsdoyle's Avatar
Awesome tutorial! I had planned on replacing mine with a Dakota cluster but after seeing this I'm going to do a restore first. I just hope I can come close to the fine job you do on these.
Still waiting to hear a source for the tach. I know you aren't done with the tutorial but hope you include that info.
Thanks!
Scott
65 Chevy C10 Fleetside
jsdoyle is offline   Reply With Quote
Old 01-11-2013, 02:12 PM   #31
theastronaut
Cool Re: How To Restore and Detail an Original Gauge Cluster
Thanks!
Scott
Thanks! Jason at Greenback Decal custom built the tach for me. It looks stock but has a 10k range instead of the original 5k. He used my original block off plate and he supplied the tach guts, made the 10k decal using original colors and fonts, and calibrated the tach to the new face. Original style 5k tachs are available from places like LMC, Brothers, and Classic Parts.
Old 01-11-2013, 04:37 PM   #32
jsdoyle
jsdoyle's Avatar
Thanks! I found the tach at LMC. Didn't see that there before!
Adding up the parts and material costs it looks like it could exceed 400 easy with the tach cost being the biggest expense. Adding a clock/air/vacuum gauge to the other side will bring it up even more.
Less than a new cluster from Dakota and original. Both good things depending on your taste.
Scott
Old 01-11-2013, 04:43 PM   #33
theastronaut
Scott
LMC will probably be the most expensive. Shop around and I think you'll find one cheaper. I imagine they're all made by the same manufacture. You're not kidding about cost adding up; I'll have around $600 in this one not counting the donor cluster or the Air gauge that I already had.
Old 01-11-2013, 05:53 PM   #34
McCoyAZ
McCoyAZ's Avatar
Anyone ever source out a clock that would fit into a restored gauge cluster like these?
McCoyAZ is offline   Reply With Quote
Old 01-12-2013, 02:26 PM   #35
dallas71
dallas71's Avatar
Awesome write up!
dallas71 is offline   Reply With Quote
Old 01-12-2013, 10:18 PM   #36
64shortbox
64shortbox's Avatar
Thank You for the write up.
64shortbox is offline   Reply With Quote
Old 01-13-2013, 03:48 AM   #37
PoDuck
This is pretty cool. I've been looking for this kind of info.
By the way, you don't have to get a new lens if you're just dealing with surface scratches on plexiglass. There are all sorts of products that will polish that stuff out of plastic. You don't even need the expensive headlight repair kits. A polishing wheel on a grinder and a plastic buffing and polishing compound would work better.
The only issue is when the plastic is cracked on a gauge cluster. There are ways to "repair" that, but none will be flawless, and when they don't make a repop lens for your gauge, it's a bear.
My lens actually has a crack in it, as well as scratches. I can replace it with clear plexiglass, but the numbers and things that are engraved into the plastic will be lost, and I've been exploring options on how to reproduce that.
I could design a stencil on the computer and reproduce those things with a flat painted look, but it won't look original.
I could find someone with a cnc machine, but that doesn't allow someone to do it in their own house unless they have one, and it would possibly end up more expensive than just finding an old gauge cluster in decent shape.
I'm not sure what could be done in such a situation, but it would be nice to figure something out.
PoDuck is offline   Reply With Quote
Old 01-13-2013, 08:29 AM   #38
McCoyAZ
McCoyAZ's Avatar
[/QUOTE] I could design a stencil on the computer and reproduce those things with a flat painted look, but it won't look original.
I'm not sure what could be done in such a situation, but it would be nice to figure something out.[/QUOTE]
Take it to a JEWELER that has an engraving system or a Laser Engraver.
Old 01-14-2013, 01:39 PM   #39
theastronaut
The lettering on the original lens isn't engraved, it's just printed straight onto the plastic. The main reason for replacing the lens is to get rid of the faded letters and have the correct pale green coloring. Even if hazing and scratches can be sanded and buffed out, the color will still be faded. Jason at Greenback Decal can reprint the lens, and also modify the lettering. He is currently working on a 160 mph lens for the cluster I'm rebuilding.
Old 01-14-2013, 01:45 PM   #40
theastronaut
Pic of the color difference.
Old 01-14-2013, 02:12 PM   #41
PoDuck
The lettering on the original lens isn't engraved, it's just printed straight onto the plastic...
I should have made it clear that I was talking about the 1962 lens. It is engraved. If not, I could have made a stencil and painted the new piece myself.
Old 01-14-2013, 02:25 PM   #42
benwah
benwah's Avatar
I have 2 62 dash clusters one with a tac, and one that can be modified to insert a tac. How rare is the factory tac in a 60-63 truck? I see the 64-66 on FEEBAY but never 60-63.
benwah is offline   Reply With Quote
Old 01-14-2013, 02:56 PM   #43
theastronaut
I didn't know that about the early lenses, I've only had 64-66 clusters.
Old 01-15-2013, 09:07 PM   #44
theastronaut
Wiring harness details added.
Old 01-16-2013, 07:20 AM   #45
brokenspoke
brokenspoke's Avatar
FYI....Echlers Vete site has orginial non adheasive tape for wrapping harness
brokenspoke is offline   Reply With Quote
Old 01-16-2013, 08:58 PM   #46
DoubleL
DoubleL's Avatar
I think those tachs are pretty rare although the 64-66 are pretty hard to find as well. I believe the '62 tach will need a sending unit.
My 1965 C-20 project
https://67-72chevytrucks.com/vboard/...d.php?t=835095
DoubleL is offline   Reply With Quote
Old 01-22-2013, 12:39 PM   #47
theastronaut
Originally Posted by Woogeroo View Post
theastronaut :
epic thread Sir.
Thank you very much for taking the time to do that, photograph it all and then upload an caption everything.
I for one know how time consuming all of that can be.
-W
Thanks Woog, I enjoyed doing it! I was already going through the cluster so it wasn't that much more work to put this together. I appreciate you adding it to the FAQ, and also all the work you've put into the FAQ.
Old 01-22-2013, 01:44 PM   #48
skip64
Subscribed and agree with everything Woogeroo wrote!
skip64 is offline   Reply With Quote
Old 01-22-2013, 02:57 PM   #49
ljackson
ljackson's Avatar
Nice Job. Thanks for your effort.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 01-22-2013, 07:08 PM   #50
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Great write up!!
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
