Old 08-12-2013, 08:34 PM   #26
chev3600
chev3600's Avatar
Re: 49/54 LS driver
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 09-04-2013, 09:41 PM   #27
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Size:  55.6 KBSlowly cleaning up the engine bay, ran some a/c hoses. Still need ideas for a cleaner intake.
Made a panel to house heater controls and ducts.
Old 09-04-2013, 09:45 PM   #28
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Posted via Mobile DeviceName:  image.jpg
Old 09-04-2013, 11:19 PM   #29
oldman3
oldman3's Avatar
Re: 49/54 LS driver
Looking good...Jim
oldman3 is offline   Reply With Quote
Old 09-05-2013, 09:48 AM   #30
alaska gasser
alaska gasser's Avatar
Re: 49/54 LS driver
Originally Posted by chev3600 View Post
Ive almost finished the windshield wiper setup using a surplus boat wiper motor found online (Thanks mknittle)
I like your idea for the wipers. Have you been happy with the application and what exactly did you use?
alaska gasser is offline   Reply With Quote
Old 09-05-2013, 12:12 PM   #31
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Thanks Jim.
Alaska- the wiper motor is a surplus boat motor from a website I found on this board. The linkage is a stock 54 linkage, with a collar welded to the pivot bracket. It functions well enough, but I've noticed that there is a lot of slop in the stock parts. I'm looking into replacements, but the stock linkage is tough to find.
Old 09-05-2013, 12:22 PM   #32
Bierkan
Bierkan's Avatar
Re: 49/54 LS driver
Thanks Jim.
Can you install brass bushings into the stock linkages to take up the slop?
James "Bierkan" Vierkant
1950 3100 on a 1972 C10 Chassis
Truck Blog
Motorcycle Blog
Bierkan is offline   Reply With Quote
Old 09-05-2013, 12:44 PM   #33
chev3600
chev3600's Avatar
Re: 49/54 LS driver
I hadn't thought of that one yet. The parts seem to be a pot metal type material, so I'm not sure if I'll be able to drill it out. Certainly not afraid to try! I think I've got a couple spare parts, maybe I can dig in this weekend. Thanks for the ideas.
Old 09-06-2013, 01:16 PM   #34
Wybrow
Re: 49/54 LS driver
Great project. Lots of ingenuity and the right drivetrain.
Wybrow is offline   Reply With Quote
Old 12-13-2013, 04:42 PM   #35
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 49/54 LS driver
Any progress on this
--Josh
Old 12-14-2013, 06:50 PM   #36
Franken51
Re: 49/54 LS driver
Hey, good looking build so far. Ive got a 51 that Im going to put a LQ4 in. did you have to build any trans tunnel in your truck? Ill have a 4l85. Im jealous, I can get enough time to do much to mine right now so I have to live it out through what I see on This site.
Franken51 is offline   Reply With Quote
Old 12-14-2013, 09:01 PM   #37
99 to Life
99 to Life's Avatar
Re: 49/54 LS driver
I wanna see these wipers in action. I seen that motor on ebay for like 60 bucks, looks like a very simple setup you got. Sure seems like it would beat paying 150-200 for a newport kit which seems to take up more room.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-15-2013, 10:07 PM   #38
skymangs
skymangs's Avatar
Re: 49/54 LS driver
x2 on the wiper setup... Looks slick
skymangs is offline   Reply With Quote
Old 12-15-2013, 10:26 PM   #39
sqrlnts
Re: 49/54 LS driver
Chev3600, great looking build you have going on here. Does your wiper motor use a rocker switch like this one?
sqrlnts is offline   Reply With Quote
Old 12-15-2013, 10:44 PM   #40
chev3600
chev3600's Avatar
Re: 49/54 LS driver
I didn't use the model with the rocker switch built in. Not sure how you could reach it. I used a hot rod wiper switch in the stock location on the dash. Probably going to use the one on the turn signal lever eventually. I'd still like to build a better linkage then the stock one, as there is a little more slop than I would like. If I could figure out how to post a video....
Old 12-15-2013, 10:53 PM   #41
chev3600
chev3600's Avatar
Re: 49/54 LS driver
I didn't have to do much of a tunnel. I just redid the trans cover to accommodate a lokar shifter, but prior to that the floor was pretty much completely flat. Just split the floor and raised the stock hump about 1/2".
Old 12-15-2013, 11:10 PM   #42
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Wiper vid? Maybe? You can see that they don't go all the way down to the cowl during normal operation. The major selling point of that motor was the self park feature and it works fine. But... When stopped I can push the wiper arms the rest of the way down to the bottom of the windshield by hand. It looks better down.
Old 12-20-2013, 10:37 PM   #43
vht
Re: 49/54 LS driver
Need to see more pics and progress!
vht is offline   Reply With Quote
Old 01-05-2014, 03:33 PM   #44
Root2812
Root2812's Avatar
Re: 49/54 LS driver
I have a few questions for you. Did you get the 3 or 4 row champion radiator? With the electric fan attached how thick is your radiator/fan assembly? I'm using the truck accessories too and my cab is off so I'm trying to get some measurements to place the motor. I don't have the radiator yet but if I place my engine off the radiator location then I should be able to make it close enough to avoid firewall mods.
Also, I am using an explorer 8.8 and I want to use leafs. Did you use the explorer leafs?
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 01-05-2014, 07:33 PM   #45
chev3600
chev3600's Avatar
Re: 49/54 LS driver
I don't recall which core, but it's not a 4 core. It's 2 1/2 inches thick.
I'm not running an electric fan, but where my engine is placed, you could comfortably run any electric fan 3 inches deep or shorter. I also tilted the radiator forward at the bottom just a bit.
I'm running s10 rear springs and hangers because I had them laying around. Really, my placement was based on desire to run mech fan and use an unmodified s10 driveshaft.
Old 01-06-2014, 09:05 AM   #46
solidaxel
solidaxel's Avatar
Re: 49/54 LS driver
Yes you are right on the rocker switch!
I bought one of those BUT there is no way to turn it on -off, so on the shelf with the rest of the "overstock" items !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-06-2014, 01:03 PM   #47
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Solid- is there a way to remove the switch and extend the wires to a nicer switch?
Old 02-06-2014, 12:34 PM   #48
dante81_98
Re: 49/54 LS driver
Awesome build man. Are those the stock truck manifolds? Did they clear the steering okay? Also, did you have to move the ac compressor up or were you able to get it to fit with it sitting low? I am just starting to look into the LS engine swap for my 50 chevy.
dante81_98 is offline   Reply With Quote
Old 02-06-2014, 12:39 PM   #49
dante81_98
Re: 49/54 LS driver
Actually, nevermind. going back I see you have a front clip on yours. I am running the stock frame. Probably just going to have to stab it in and see what we come up with.
Old 02-06-2014, 12:54 PM   #50
chev3600
chev3600's Avatar
Re: 49/54 LS driver
No matter the frame, stock truck manifolds likely won't clear. I used trailblazer SS ones and it's still tight. Good luck!
