Old 04-22-2013, 07:35 PM   #26
vegadesign
vegadesign's Avatar
Re: 69 LWB Power Tour Rig
looks good keep up the good work
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 05-01-2013, 10:24 PM   #27
69SCSS
69SCSS's Avatar
Quick update. I pulled the back cover in sunday, the gears and posi look solid, no real wear issues I could see. Oil looked black but nothing shiny in it (I was expecting glitter...). Pulled the pin and the c-clips and slid the axles out.
Got the backing plates off yesterday and will be cleaning them up and painting them tonight... then assembling the brakes. I have the outer bearings now, so once I find a slide hammer I'll slap those in and button the whole thing back together. Then the fun cleaning the axle!
Pics probably this weekend, my garage is too dark for my camera to take decent pics. I need a few more lights!
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 05-02-2013, 06:19 PM   #28
69SCSS
69SCSS's Avatar
Today's progress. Also picked up an adjustable panhard bar from CPP. Hoping to have the axle done by next weekend. Then I can move to the front.
My 68 SWB
Al Silveira Music
Old 05-02-2013, 06:34 PM   #29
Fattback
Fattback's Avatar
Looking good
Rob
Fattback is offline   Reply With Quote
Old 05-03-2013, 01:39 AM   #30
Bomp
Bomp's Avatar
Stomping out the small fires,,,,er ah... Nice work. Onto the front.
Bomp is offline   Reply With Quote
Old 05-03-2013, 09:59 PM   #31
69SCSS
69SCSS's Avatar
Yep. A little at a time, I'll get there. I have a lot of the parts already, mostly missing the engine, trans, and a bed. Other than that I can make this thing a roller with the parts I have. Holding off on the drivetrain until I have the rest done and... I have room for it!!! My garage is already packed full of parts!!!
Just snagged a pair of big block stands, decided the truck's an original big block truck, and i don't have an engine... ok, twist my arm. So when I get close to done with the chassis I'll start looking on CL for a 396/402/454. See them all the time for reasonable prices, and about the same as for a small block, so again, twist my arm.
My 68 SWB
Al Silveira Music
Old 05-12-2013, 10:02 PM   #32
69SCSS
69SCSS's Avatar
Well tried to pull my axle bearings with a slide hammer today, good thing I'm replacing them... they blew apart the second I hit it with the slide hammer! The race is all that's left in there.... and it won't come out with the slide hammer. Can't even get a hold of it. Brainstorming to figure out WTF to do with this
anybody have any ideas?
My 68 SWB
Al Silveira Music
Old 05-16-2013, 02:41 PM   #33
69SCSS
69SCSS's Avatar
Got the bearing races out. I tried a couple things but the simplest way wound up being ridiculously easy.
I grabbed a 2.5" flat washer from Ace last night for $1.20. This morning I cut off 1/2" from 2 sides, then ground down the outsides to 2 3/8. Put the washer over the bolt for the slide hammer and a smaller washer to keep it flat. Slipped it into the axle tube, 2 whacks of the slide hammer, and it's out. Same on the passenger side. Took me about 15 minutes of grinding to get the right shape for the tube, but worked like a charm. No more fighting with 12 bolt axle bearings.
My 68 SWB
Al Silveira Music
Old 05-21-2013, 01:19 AM   #34
69SCSS
69SCSS's Avatar
Got the axle stripped and painted yesterday. Trailing arms are next, along with the shock brackets and U-bolts. Can't wait to see this all assembled.
My 68 SWB
Al Silveira Music
Old 05-21-2013, 01:29 AM   #35
ddubbs
ddubbs's Avatar
Welcome to the forum. Great start. Subscribed
LIFTED OR LOW THE ONLY WAY TO GO!!!!
Check out my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=517346
Projects
56 Chevy pickup Porterbuilt FR/RR dropmembers
ddubbs is offline   Reply With Quote
Old 05-21-2013, 11:32 AM   #36
Bomp
Bomp's Avatar
Couple of washers.... I'd never thought of that. Great Job.
Old 06-10-2013, 08:10 PM   #37
Hardesty454
Hardesty454's Avatar
Havent looked at your thread yet. Looking good. Cant wait to see a big block in there! BTW, what did you do with that 69/70 grille?
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 06-10-2013, 08:20 PM   #38
69SCSS
69SCSS's Avatar
Got rid of that last year sometime, when I decided to go for the 68 front end. Wasn't in that great of condition. Looked better in pics than it actually was.
And yea, truck is a BBC truck, gotta put a BBC back in.
My 68 SWB
Al Silveira Music
Old 06-14-2013, 05:23 PM   #39
69SCSS
69SCSS's Avatar
Started to tear apart the front suspension last night and pulled the front springs. This is what I found... I'm thinking these were cut down to 7" drop!!!! Think must have rode like a tank. Those are stock springs they are next to.
My 68 SWB
Al Silveira Music
Old 06-16-2013, 07:05 PM   #40
69SCSS
69SCSS's Avatar
Today's disassembly. Still have to unbolt the crossmember and remove the brake lines. Past that all I have to do is remove the parking brake cables, fuel and brake lines, rear wiring harness, and transmission crossmember and I can drag the frame out to the sandblaster's. Then the fun part, painting and reassembly!!!
My 68 SWB
Al Silveira Music
Old 06-16-2013, 07:06 PM   #41
69SCSS
69SCSS's Avatar
And after:
My 68 SWB
Al Silveira Music
Old 06-16-2013, 07:09 PM   #42
69SCSS
69SCSS's Avatar
More random pics. Also my handy dandy axle bearing removal tool. 2.5" washer, cut down to fit. The non-cut one was for installation with a socket. Worked like a charm.
My 68 SWB
Al Silveira Music
Old 06-25-2013, 02:27 PM   #43
69SCSS
69SCSS's Avatar
Whipped this together this morning while the girls were at the library. Handy Dandy Cab Dolly. Only cost me the screws and the casters, I had a bunch of 2x4's left over from building a room in the garage... putting them to good use finally.
My 68 SWB
Al Silveira Music
Old 06-25-2013, 02:46 PM   #44
67cheby
67cheby
67cheby's Avatar
making some great progress !
67cheby is offline   Reply With Quote
Old 06-25-2013, 02:50 PM   #45
Hardesty454
Looks good Al! Like that dolly!
Rob
Old 06-25-2013, 03:19 PM   #46
68GMCburban
68GMCburban's Avatar
Looks good! Keep up the great progress.
-Holden
1983 & 1972 Chevy Longbeds
(16) 67-72s (Rollback, 402's, Sierra Grande, Shortbeds, Shortsteps, Longhorn, etc)
1968 GMC Suburban- (Current project) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=569806
(6) 60-66s (shortstep, rollback, two-ton, longbeds)
(3) 47-59s half tons
+ MANY more and always looking for more
68GMCburban is offline   Reply With Quote
Old 06-25-2013, 07:56 PM   #47
69SCSS
69SCSS's Avatar
Thanks guys! Rob, took me an hour and $32. Probably less if I didn't have the dog bugging me every couple minutes to throw the toy for her!
My 68 SWB
Al Silveira Music
Old 06-25-2013, 08:55 PM   #48
Bomp
Bomp's Avatar
On the Cab Dolly
Old 07-05-2013, 03:11 AM   #49
69SCSS
69SCSS's Avatar
On the Cab Dolly
Here it is doing it's job!
Nice and LOWWWWWW....
My 68 SWB
Al Silveira Music
Old 07-05-2013, 03:15 AM   #50
69SCSS
69SCSS's Avatar
So I got some serious work done today, got the frame out from under the cab, and dragged it out into the driveway. Pulled all the crap out of the garage and cleaned the whole thing out for phase 2 - ASSEMBLY! The frame is getting sent to the sandblasters on tuesday, so while it's gone I will start painting some of the other parts and getting ready to put the chassis together. Can't wait to get this thing back and put it together!
Here's some pics of the pulling the frame out.
My 68 SWB
Al Silveira Music
