02-13-2013, 05:33 PM | #26 |
Re: Whose Seat Belts Are You Using?
Couple pics I had...had to later make a cover for the roller mechanism and it's mounted with one huge bolt and a piece of angle iron to the floor, backed under the floor by a BIG heavy washer. Welded a nut to a washer and welded THAT from the inside up top. Taped it to a long paint stir stick and stuck it up the inside to get it positioned.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
02-14-2013, 02:12 PM | #27 | |
As to the mounting of the shoulder anchor, somewhere (maybe a Juliano's link to a magazine article?) that showed a piece of plate with a nut welded on it that was slipped behind the B pillar and welded there using two rosette welds to hold it until the through-bolt could be tightened. The rosette weld would be ground flush (I assume) so they'd be invisible after installation. Does this sound like what you did? Also, I notice on some donor vehicles the retract reel/mechanism is covered by plastic that also is the seat bottom "surround". So that won't especially work UNLESS I find or fabricate some other kind of box to cover the reel. What have you guys done? I'm thinking there oughta be some kind of metal box I could re-purpose as a reel cover. Paint it or have it chromed. |
02-14-2013, 06:38 PM | #28 | |
02-14-2013, 07:44 PM | #29 |
Oh, smart. I'd have never thought off wrapping in leather or fabric!
Posted via Mobile Device |
