07-27-2013, 10:59 PM | #26 |
Re: How to install a 60-62 windshield in 30 minutes
Find a glass shop that sells Pilkington Classics and get a quote. You can get them tinted but I'm not sure about the tint just on the top.
07-28-2013, 06:17 PM | #27 |
Ditto on great write up!! Ditto on where to get quality glass.
63 big window lwb bagged and shaved |
08-07-2013, 06:55 PM | #28 |
This is the same advice I got here in NE Oklahoma. Thanks to you guys, I think I can do this. I appreciate all of the advice, you all are great !!!
08-16-2013, 02:51 PM | #29 |
I followed this method without a rope. Only a pick and soapy water. Went in extremely smoothly. Took longer to put the seal on the windshield than to install the windshield. I used a Steele brand seal and put it in dry. I only put some weatherstrip adhesive where the seams are in the pinch weld and it looks like I don't have any leaks. It really helps if you have two people to help you install it. I found the rear window to be more difficult than the windshield.
08-16-2013, 10:58 PM | #30 |
64-66 CHEVY JUNKIE
GREAT INFO!!! Bookmarked!! Will be doing this in the near future, busted mine trying to get it back in
Thanks Cort. Posted via Mobile Device
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
08-18-2013, 08:29 PM | #31 |
I called 6 glass companies up over the past couple weeks trying to buy a new 60-63 clear window and have struck out. One place said they had it, came over and popped out my old windshield, scratched up the paint on the roof, ("what am I hitting") then pulled a green tinted windshield with a gray shade out of their truck. I was told by one of the glass companies Pilkington Classics hasn't made a clear kneekocker since 2005 and to order a new one from ecklers or classicindustries. I called both of them and someone at ecklers said they drop ship from j&r industries but neither knew if it made in the US. Going to keep looking for a clear glass, however if you like the green tint its only $260 installed if you don't mind the paint scratches..
08-18-2013, 09:08 PM | #32 | |
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
08-18-2013, 09:09 PM | #33 |
Great write-up. I have a set of trim for my '63 but have hesitated to try the install after all of the horror stories. I will certainly get a Precision Gasket.
08-20-2014, 11:49 AM | #34 |
TTT for the new guys. Will be doing this Saturday or Sunday myself.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-20-2014, 06:07 PM | #35 |
let us know how it goes!!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
08-21-2014, 09:38 AM | #36 |
Will do. Got the glass removed last night with help from Austin. Pinch welds are great, so clean up and finish sealing tonight...and color this weekend. I'll probably clean up the glass and get it sealed and taped into the gasket. Let it sit a few nights prior to install. I have the wide 60-61 trim to install also. And this will be good practice as I have the fleetside to do also.
08-21-2014, 12:42 PM | #37 |
I didn't have a windshield as my old one was cracked. called a place in town (Breaker glass) asked if he could get me a tinted w/s for my 61, he said in one day. I had my gaskets (precision) ft and rear. total cost for w/s and install both ft and rear. $361. all the venders want around $500 just to get it to your house. yes do it yourself if you have some help and don't need a new glass.
1961 chevy K10 my build is------------61K10 build |
08-21-2014, 01:19 PM | #38 | |
MY stepside has a Plinkerton...so its been replaced at some point.
08-27-2014, 09:15 PM | #39 |
Heres a follow up pic. Took a little longer than an hour and we ran out of light. Brian wants to let it sit a few days and do some small tweeking. He thinks it can still come in some.
08-27-2014, 09:20 PM | #40 |
just put a hinge on it like a willys jeep... nice job!!! i have my gasket on my glass now to beat it into shape ,i'll add the trim in a day or so, just gotta find my tape and get some cord!!!
08-27-2014, 09:56 PM | #41 |
Yeah, the cord helped. We used parachute cord. Soapy water and extra hands. Did the same steps as written in the description. Start with the top 1st and work it around a few times w/pressure on the outside.
I put movers blankets down on the cab floors and stood on the tires for leverage.
08-28-2014, 01:32 PM | #42 |
Nice job on the install 1963c-10, After I installed mine I felt it needed some tweaking also, what I found that worked in lieu of suction cups was having 2 people stand in the door openings and pancake the glass from the outside and inside with their hands and wiggle it up and around, the gasket also seated itself better after time in the sun and on the road, I think the biggest mistake that people do when installing the windshield is trying to seat the window with soft blows with the palm of their hand, if you don't hit it, it wont break.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
08-28-2014, 01:38 PM | #43 | |
Couple more pics I had on the build thread...
10-03-2014, 11:35 AM | #44 |
Nice write up, alot of help thank you. I also have a question. Someone had mentioned that the after market gaskets were not cut deep enough for the chrome molding trim to set right?
11-22-2014, 11:32 AM | #45 | |
Just here to tinker
I'm glad this write up has helped so many people!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
