03-25-2013, 08:32 PM | #26 |
Re: 1949-50 3100
Wouldn't you just love to have a sit down conversation with the folks that did all that "fine" work! Kind of like on my truck~ a "reputable shop" did all the paint/body work~ yeah!argh!
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
03-25-2013, 10:19 PM | #27 |
Hollister Road Co.
Re: 1949-50 3100
Its sad to know shops like that exist. I'm just glad he saw it prior to blasting and still painted blue he would never have believed it was his truck.
03-27-2013, 09:18 PM | #28 |
Hollister Road Co.
Re: 1949-50 3100
It came back late today and its not good. The blaster said he had never seen so much filler on a truck. Almost every panel has a hole in it and the door was filled half way up. What they did was used screen and a patch then poured filler on it sanded it down and sprayed the back side of the panels with bed liner so it looked good on both sides. The fenders front and back, the hood, the left bed panel, around the windows front and back in all the hard to fix spots. The belt line is cheese. I'll take pictures tomorrow and post.
He had to grind off the liner in most spots and left it in places he knew we were cutting out anyway. The total on the blasting came to $1700. If anyone is looking for a blaster in Houston www.affordableblasting.com. They do a very good job, he delivered on time and he has experience with vehicles like ours. |
03-29-2013, 06:28 PM | #29 |
Hollister Road Co.
Re: 1949-50 3100
Here are some pics of the cab. If you look back you wouldn't think its the same one I sent to him. They bondo'd and back sprayed everything they tried to hide. None of this was visible prior to blasting.
03-29-2013, 06:28 PM | #30 |
Hollister Road Co.
Re: 1949-50 3100
More
03-29-2013, 06:34 PM | #31 |
Hollister Road Co.
Re: 1949-50 3100
More
03-29-2013, 06:37 PM | #32 |
Hollister Road Co.
Re: 1949-50 3100
more
03-29-2013, 07:02 PM | #33 |
Re: 1949-50 3100
Ouch! Looks like you've got your work cut out for you on that cab - lots of hidden "fun".
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
03-29-2013, 08:38 PM | #34 |
Re: 1949-50 3100
Well, I'd have to find another project cause there's no way I could fix all of that, at least in my lifetime! But I know you can fix it!
03-31-2013, 02:58 PM | #35 |
Hollister Road Co.
Re: 1949-50 3100
After thinking about this for a few days I decided that we will present to the owner that we replace the lower cowls and wheel houses, Upper cowl, outer pillar covers, roof, rear window panels inner and outer, and the lower back panel and corners.
We could fix the issues but still end up with places that may well rust through in a year or two. If we have to take some panels off to treat the existing rust then we may as well replace them entirely. The rear window and belt line will be a problem area if we don't. |
03-31-2013, 04:25 PM | #36 |
Re: 1949-50 3100
Man hours alone justifies another cab I would think that are a few in Texas
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 Last edited by Rude Dude; 03-31-2013 at 04:26 PM. Reason: Spelling |
03-31-2013, 05:33 PM | #37 |
Hollister Road Co.
Re: 1949-50 3100
If I can get one at a reasonable price. They want crazy money for trucks here. I've seen $2000 for a cab that needs another 2k put into it. That certainly will be something I'll keep an eye out for one.
04-05-2013, 08:01 PM | #38 |
Hollister Road Co.
Re: 1949-50 3100
Got the OK to do the cab work and parts are on the way. I think by the end of next week I'll have some progress pictures to post. I also got the dolly lock welded on and they work very well. You step on the outer lever to lock it down and the inner to unlock. Not cheap, I think about$80 shipped but they work great.
04-05-2013, 08:21 PM | #39 |
Re: 1949-50 3100
But I bet you will find that after using them for a while that they will be money very well spent.
04-05-2013, 08:42 PM | #40 |
Hollister Road Co.
Re: 1949-50 3100
04-05-2013, 11:18 PM | #41 |
Re: 1949-50 3100
I know a guy up here in North Idaho that has a few 5 window cabs that look to be in pretty good shape. I don't know what it would cost to ship one to you but it's an option. One problem will be he is in Portland OR for the huge swap meet till next week. Let me know if you want his number.
66 shorty |
04-15-2013, 06:41 PM | #42 |
Hollister Road Co.
Re: 1949-50 3100
We have the roof and back off. We used a plasma torch and slit the sheet metal all around the edges to get all the big metal off. then went back and busted all the spot welds with a seam buster. So its bare from the A pillar to the back of the cab. lots of rust that needs blasting. I think now I even more convinced replacing the roof and back was the right thing to do.
04-15-2013, 06:46 PM | #43 |
Hollister Road Co.
Re: 1949-50 3100
Before I go further I need to pop the doors on and make some braces to the firewall and floor pan. I don't want the door opening to get out of shape during all the metal work. The doors fit very well prior to us taking this apart and we made alignment holes in the hinges and panels so they would line back up as they were exactly.
04-15-2013, 07:09 PM | #44 |
Re: 1949-50 3100
Extraordinary work! I imagine the plasma cut through that in a flash!
dne'
04-15-2013, 07:10 PM | #45 |
Certified Car Nut
Re: 1949-50 3100
WOW. I thought my cab was in bad shape, but man that is some work right there. The good thing is doing it right, means not having to do it again.
04-15-2013, 07:40 PM | #46 |
Re: 1949-50 3100
This is a very interesting thread. Please post lots of pics as you progress through this build. Calling this a build is correct, looks like you are actually building a cab, LOL.
I feel bad for the owner to have gotten ripped off like he did. It's too bad that he doesn't have some way to recover at least some of his money. |
04-15-2013, 09:50 PM | #47 |
Hollister Road Co.
Re: 1949-50 3100
04-15-2013, 09:53 PM | #48 |
Hollister Road Co.
Re: 1949-50 3100
We are re sand blasting the areas that are now exposed. It will be 99% rust free and hopefully last until his son gives it to his son.
04-15-2013, 10:19 PM | #49 | |
Hollister Road Co.
Re: 1949-50 3100
It is really going to be a cab build once we remove the front cowl and the side cowls and the inner panels along with the front section of floor. The only things we are not doing is the dash, Door openings, upper firewall and rear floor pan but the firewall may go as well or be heavily modified to fit the 5.3. The rest of this week we will be making bracing from the firewall down to the dolly so when we remove the front floor and lower cowls it doesn't sag. We'll also add bracing across the floor up to the dash on each end. Across the door locks. I going to try and document what we do as it goes incase some of you need to do portions of this. I'm thinking we are going to do just about everything you can do to a cab. |
04-15-2013, 10:45 PM | #50 |
Re: 1949-50 3100
I see no reason why you should not guarantee that truck for the next 50 years!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
