Old 04-16-2013, 11:19 PM   #26
1project2many
Re: Converting coil style ignition to HEI........what is involved?
The BAT wire is actually switched power. It will come from the ignition switch or relay (if you use one).
1project2many is offline   Reply With Quote
Old 04-16-2013, 11:44 PM   #27
solidaxel
solidaxel's Avatar
How is the rear axle, done yet?
Do you have a measurment for the driveshaft, or is it installed?
Is the rad and fan installed?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-17-2013, 01:08 AM   #28
NW Task Force
NW Task Force's Avatar
The rear axle is installed, pinion angle set, driveline currently being built this week. The radiator is installed now too, along with the fan shroud. Unfortunatey, Speedway Motors sent me the wrong electric fan size and I am waiting to have the correct one shipped back out to me. In the meantime I am staying busy with checking & double checking electrical circuits wired throughout the truck.
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original
NW Task Force is offline   Reply With Quote
Old 04-17-2013, 01:32 AM   #29
solidaxel
solidaxel's Avatar
Good Job, looks like you are on schedule !
Your truck will run fine with a switched 12VDC (10awg) (keyed) but that HEI will like the 14.2 VDC that is direct from the battery (starter)/alternator, BUT you must use a Relay for that.
Take a look at the drawing, get some good 10 AWG, a relay and some spade terminals, a ring term, to fit the starter.
This will be a HOT wire so it needs to be secured and protected to the HEI.
Let us know when you are ready, you will have help
LS 3 4L70E
Old 04-17-2013, 01:42 AM   #30
solidaxel
solidaxel's Avatar
Once you get the hang of relays, you will want them on your head lights and for sure your electric fan.
This may be a good time to look for a Buss (fused isolated and insulated 1/4 inch bolt& nut) that brings the 12VDC from the starter/battery to a common location for all three relays
(#30)
LS 3 4L70E
Old 04-17-2013, 01:50 AM   #31
solidaxel
solidaxel's Avatar
Relay!
LS 3 4L70E
Old 04-18-2013, 12:24 AM   #32
NW Task Force
Wow! Thanks Solidaxel! Lots of great info! I think I have the wiring handled now. I'll update as I go.
Old 04-18-2013, 09:06 AM   #33
solidaxel
solidaxel's Avatar
Keep a eye on the calendar July is going to be here before you know it !!!!
Get that truck on the road !
LS 3 4L70E
Old 04-24-2013, 12:29 AM   #34
NW Task Force
Question Re: Converting coil style ignition to HEI........what is involved?
Just "bumping" this subject back up and wanting to clarify some things. My ignition switch has the following spads on the back................
SOL
IGN 1
IGN 2
BAT
ACC
Which of these spads should have the HEI wire going to it?
Old 04-24-2013, 12:56 AM   #35
solidaxel
solidaxel's Avatar
The one that has 12V when the key is tuned to on............... and it must have 12V when the key is in the start position, and goes to zero when the key is turned off.
Switched 12VDC in the on position AND start position
LS 3 4L70E
Old 04-24-2013, 06:38 AM   #36
fabguy
Elev8r Man
fabguy's Avatar
Wow, this thread is perfect. Starting my wiring next week on my truck and this thread has helped me ALOT.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 04-24-2013, 08:16 AM   #37
Rude Dude
Rude Dude's Avatar
Do you have a cover for the relay box and where did you get it?
Relay!
Rude Dude is offline   Reply With Quote
Old 04-24-2013, 08:25 AM   #38
Rude Dude
Rude Dude's Avatar
Relay!
Old 04-24-2013, 09:48 AM   #39
solidaxel
solidaxel's Avatar
Yes the plastic box came with a rubber seal on a hard cover from Elliot Electrocnis a local component supply house here in town (Tucson)
LS 3 4L70E
Old 04-24-2013, 10:44 PM   #40
NW Task Force
Question
So is "switched" considered to be SOL or IGN1? I am still a little confused on where exactly on the back of the ignition switch wires are to be plugged in.
Old 04-24-2013, 11:43 PM   #41
solidaxel
solidaxel's Avatar
Do you have a meter (Volt-Ohm)
HF sometimes has free ones with purchas
LS 3 4L70E
Old 04-25-2013, 01:40 AM   #42
NW Task Force
Yes, I have a nice Fluke Multimeter. I am pretty comfortable with using it too. I have gotten those Harbor Freight "freebie" ones before and given them out to friends who needed something to throw in the glovebox.
Old 04-25-2013, 07:03 AM   #43
1project2many
Wires in one hand, switch in the other, and no idea how to connect them. And staring you in the face is SOL. Boy, if there was ever a case that the universe has a sense of humor, this is it.
SOL is starter SOLenoid. Connection should exist to BAT only in crank position.
IGN1 and IGN2 are both connected to BAT in run position. Use the multimeter to determine if one or both are connected to BAT when key is turned to crank position.
ACC is connected to BAT in accessory and ignition position but typically is not connected in crank position.
All of this should be confirmed with the meter.
Old 04-25-2013, 08:23 PM   #44
NW Task Force
Red face
Thanks! This helps a lot. I do understand what the initials on the switch stand for.......just double checking to see what is the correct wire connections to each component.
Old 06-01-2013, 01:10 AM   #45
NW Task Force
Question Need some help!
Tonight I tried to start my truck for the first time. I hit the key and the starter cranks the engine over perfectly. Next, is pulling a spark plug and cranking to see if I am getting spark. Yup, it sparked real good a couple of times. I cranked it over some more and no more spark!!! I wiggled wires on the ignition switch........nothing. Checked HEI under the cap and connections........good. I used a test light and meter at the back of the ignition switch to verify power. The following is what I discovered: The BAT has power all the time (correct) SOL is energized only when cranking (correct) IGN 1 is energized when switched to on. When switched momentarily to the start position, IGN 1 loses power completely. Basically, my HEI has power in the on position, but no power when switched to start. I used a test light and it seems sometimes the light stays on and sometimes goes off when touching IGN 1 while cranking. It seems like the internal ignition switch is bad/intermittent. The switch is brand new from an aftermarket truck catalog. I suspect its made in China or Taiwan? The back of the switch has IGN 1 & IGN 2.......... IGN 1 only is powered while in the on position and IGN 2 is only powered when cranking. Don't I need HEI power both during on & start positions? Does IGN 1 & IGN 2 need a jumper to work? What am I missing here to make spark happen to my HEI system?
Old 06-01-2013, 01:51 AM   #46
NW Task Force
Exclamation
Hhhmmm........I may have found something that explains my dilemma.
Check out the diagrams I found online............
My ignition switch is a repro V8 style that fits 55-59 pickups. The terminals on the back have BAT/ACC/SOL/IGN1/IGN2 I noticed that some other ignition switches later on had BAT/ACC/SOL/IGN/GRD. I am wondering since mine is an early style reproduction that using a jumper between IGN1 & IGN2 is really the way to make it work.
