#26 |
Re: CPP spindles
Well great news!! After two days of wondering if I was going get the old version spindle or the newer style smooth cast "original offset" drop spindle they arrived today and..... They are the new style spindle with the claimed stock track width. So I can confirm if you oder a cp4s4 from summit you will get a new style CPP spindle for a 73-87 truck. And for a great price too. Now just cant wait to get them on and see the a-arms laid out on the ground!!
#27 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: CPP spindles
Did your order Light Duty or HD drop spindles for 73-87?
(1" rotors or 1-1/4" rotors)
#28 |
Re: CPP spindles
Nevermind.
Looks like Summit Racing doesn't carry a CPP drop spindle for the Light Duty 1" 73-87 rotors. http://www.summitracing.com/search/b...p?autoview=SKU
#29 |
Re: CPP spindles
Yeah no light duty. If you go by CPP newest catalog it says uses the 1.25 rotors and bearing. And it also lists them at 2.5" drop still which is good cause I assumed they were only 2" like the "modular" ones. So damn confusing!!!
Posted via Mobile Device |
#30 |
Re: CPP spindles
The 1" rotor guys will need to know that this spindle will require you to change rotors, calipers, and switch to A5 inner bearings.
#31 |
Re: CPP spindles
So, hmmmmm.
Wonder what you'd get if you ordered for the 71/72 spindle? Posted via Mobile Device
1971 C10 SWB 350/350 A/C PS PDB |
#32 |
68 C 10
![]() Join Date: Aug 2010
Re: CPP spindles
I got mine in waiting on the rotors from break performance . Now i need bearings i guess all I need is bearings for a 82 chevy 1 1/4 hD rotor correct?
I got the modular spindals thou.
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
#33 |
68 C 10
Re: CPP spindles
My truck has a new 80's model crossmember in it with PB forward arms looking forwrd to putting these spindals on
#34 |
Re: CPP spindles
im still trying to figure out what the heck the damn rotors on mine are. it aparently has been changed from the 70 drum front to something along the lines of 73-87 a-arms, spindles, rotors and calipers.
http://67-72chevytrucks.com/vboard/s...d.php?t=575166 problem for me, is that i measure the rotors and come up with 1 1/8" pretty spot on. which obviously is bigger then the inch rotor, but not as big as id assume the 1 1/4" rotor is... so i cant decide what the hell i need for spindles... |
#35 |
Re: CPP spindles
Probably a 1-1/4 rotor that was turned.
#36 |
Re: CPP spindles
#37 |
Re: CPP spindles
This is a old thread but can anyone tell me why CPP doesn't make a 2 1/2 inch modular ( without the caliper ears) drop spindle.
Scott |
#38 | |
Re: CPP spindles
(supposed narrowed track width that's never been verified "how much", by anyone) Look at this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=526033
#39 |
Re: CPP spindles
Glad this post came back. I was about to place an order withh CPP and didnt realize all the differences.
So what Im doing is I just want to order some 2 or 2.5 drop spindles for my stock disk front end. I do need to replace my rotors anyway, and Im not sure if I have the heavy rotors or not. Can I just order the old school style modular rotors and instal heavy rotors with no extra bracketry or what else am I going to need? I always thought you just bolted these on... didnt know you may need extra parts unless you were going with big wilwood brakes or something.
71 swb 350/4sp manual 5/7 static drop |
#40 |
Re: CPP spindles
Thanks for the link Keith, I'm going with a big brake set is why I chose to go with the modular spindles. If rather have a 2 1/2 inch drop spindles. Just don't like the fact I will have to cut off the caliper ears on the spindles. For my project i've bought ss7 bags, Accuair stage 2, Porterbuilt upper and lower standard tubular A-arms up front. Not sure what tires yet, I guess I'll just buy a smaller tire to compensate for the 1/2 I lose.
Scott |
#41 |
Re: CPP spindles
So I want the old school modular spindles. Where can I find a set at? I need the narrower track. I would rather not spend the extra $150 for the newer style and the brackets.
#42 |
Re: CPP spindles
Scott |
#43 |
Re: CPP spindles
Those ones have the seperate caliper bracket. I would like the ones that are modular to get the narrower track and have the ears cast on them like the original.
#44 |
Re: CPP spindles
Those are them...I didn't know they sold the modular with the ears.
Scott |
#45 |
68 C 10
Re: CPP spindles
This is how mine turned out.
#46 |
Re: CPP spindles
Subscribed for reference material... Thanks guys.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#47 |
Re: CPP spindles
Mine should be in any day now. I wanted the modular for the narrow track, but couldnt see paying more for them and then paying another 80 bucks for brackets to install my brakes.
So I just ordered the old CPP style spindles through summit. 229 shipped and no extra brackets needed
#48 |
Re: CPP spindles
That is prob what I'm going to do as well. Can't justify the extra money
#49 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: CPP spindles
Wanted to buy from Summit, but I wanted to make sure they were the new modular spindles with the caliper mount cast in.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#50 |
Re: CPP spindles
Does anyone know if you can run the factory dust shields with the CPP modular drop spindles?
Panel Beaters C.C. |
