Old 08-26-2013, 11:14 AM   #26
Kim57
Kim57's Avatar
Re: 58 3600 build
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-28-2013, 04:36 PM   #27
Gmforce
Gmforce's Avatar
Re: 58 3600 build
Very nice...Liking them there headers
Geoff
Gmforce is offline   Reply With Quote
Old 08-28-2013, 05:55 PM   #28
6.7l
Re: 58 3600 build
Headers are is night mare I bought them off eBay from dale wich he claimed American made built of old hookers design made by him to his spec I get drop shipped patriont Mexico made 55-57 fenders wells I paid 309.99 patriots are everywhere for 235 shipped sellers didn't understand my problem escallated case to eBay , he said return them wich he didn't want to at first or offer cash back for being deceptive so I sent them back at 40.32 were they came from know he claiming the supply center will probably discard them because I didn't send them back to him he claims he gave me return address wich he didn't so I just escalited case for eBay to decide
6.7l is offline   Reply With Quote
Old 08-29-2013, 10:13 PM   #29
6.7l
Re: 58 3600 build
update as of 10;00 last night ebay closed the case in sellers favor so i was out 310 for headers and 40.32 for shipping and no headers, i spent over 1 hour on the phone today talking to ebay resolition center and after i finally got a manger he agrred with me he said he would of sent them back were they came from himself if he wasent provided a alternative address to ship them to , so he granted me a 309.95 credit and i bought a set of the same ones from jegs today for 235.95 shipped
Old 08-29-2013, 10:29 PM   #30
shadow1967
shadow1967's Avatar
Re: 58 3600 build
Glad you got a favorable outcome. Nice project!!
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 08-31-2013, 10:26 AM   #31
6.7l
Re: 58 3600 build
thANKS I GOT A SPECIAL SUPRISE COMIN FOR YOU GUYS THIS WEEK ILL POST PICS WHEN I GET IT
Old 11-03-2013, 11:51 AM   #32
6.7l
Re: 58 3600 build
sorry for my delay i have been quite busy getting the truck together it now runs and drives ill try to walk you guys thru the process and question or comments just ask.
i guess i should start with the cab and frame were i left off firewall had been cut and needed to be delt with and the frame had driveline sitting in it i made some plates in a brake and recessed the firewall center back 4" to gain needed clearence
i also filled the 4o some unneeded holes in the firewall and mounted the pedals
at the same time as i was finishing cab i stipped the front suspension down again and wased painted and reassembled it with loctite
i also got a chance to paint the blower wrinklefinish black
Old 11-03-2013, 11:59 AM   #33
6.7l
Re: 58 3600 build
heres the suprise i was talking about, you may have noticed i ran out of room for a power steering pump, so i found a solution , enter the world or elec power steering , mount it anyware, 3 wire hook up , remote tank. if any one has any questions on what i used feel free to ask the setup was quite cheap. well i was mounting it i installed a starter shutoff switch antitheft it is a cat battery disconnect switch great part is even if you find it i dout anyone will know what kind of key it takes
Old 11-03-2013, 12:02 PM   #34
6.7l
Re: 58 3600 build
i then got time to reset the cab to the frame, and had to flip the 2 tubes on drivers headers from next to the tire to the back
Old 11-04-2013, 12:49 AM   #35
Kim57
Kim57's Avatar
Re: 58 3600 build
Looking good.
Kim
My build thread
Old 11-07-2013, 04:09 PM   #36
6.7l
Re: 58 3600 build
after getting the cab on i went to work on wiring i did some of it with the cab off like starter main cables fan steering alternator etc.
all gauges are stewert warner and the tack is a 60/70's cable drize unit i got lazy gator to make the alum bezel to hold the tack and speedo
Old 11-07-2013, 07:06 PM   #37
Kim57
Kim57's Avatar
Re: 58 3600 build
Gauges look good.
I can't wait until I'm at the wiring stage.
Kim
My build thread
Old 11-08-2013, 11:22 AM   #38
Gmforce
Gmforce's Avatar
Re: 58 3600 build
Hey....This truck is crazy cool man....love the vette suspension. That steering wheel is bad azz looking... I'm running the poor man independent jag suspension under my 65 so I been checkin on this build for some time..
P.s. I think you truck is beautiful man
Geoff
Old 11-08-2014, 10:13 AM   #39
6.7l
Re: 58 3600 build
hers a long needed update im currently in rebuilding truck phase 2 it was complete i had it together until aug when a valve dropped and cracked block, to my suprise when i disassembled engine i found left bank all pistions were 180deg off. so i got aggervated and said the hell with the 3mpg fuel sucker, i removed engine and trans and began selling off parts. hers some pics off the truck done i took home a oldskool24 award in the old skool round up in syracuse nationals , and was also a reads ride in rat rod magazine last issue.
With all this in mind i dug out a 6cyl i had sitting apart for the last few years and started a mockup
Old 11-08-2014, 10:16 AM   #40
6.7l
Re: 58 3600 build
next i need a trans i had a few but they were 4wd so i got on car-part and located a nice clean nv4500 2wd out of a 2001
Old 11-08-2014, 10:32 AM   #41
6.7l
Re: 58 3600 build
next i went for alittle more mock up had to enlarge bellhousing area in firewall i already moved back 4"
then i started to clean and paint motor it only has a bit north of .25million miles its seasoned and not stock
Old 11-08-2014, 12:22 PM   #42
Kim57
Kim57's Avatar
Re: 58 3600 build
That's a pretty slick looking engine.
Kim
My build thread
Old 11-08-2014, 03:08 PM   #43
6.7l
Re: 58 3600 build
Thank Kim i lost over 100ci and gained at least 500lbs motor is listed at around1100 dressed plus heavy clutch flywheel and trans is listed as 300lbs
Old 09-19-2015, 08:07 PM   #44
54 jimmy
54 jimmy's Avatar
Re: 58 3600 build
love the build. had a great time talking to you at lester car cruise. the truck is great.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
