Old 05-14-2013, 08:10 PM   #26
HOTFUN
HOTFUN's Avatar
Re: 65-66 Factory A/C
Originally Posted by LT1 Burb View Post
Did you notice too on the X-bars they are offset to give room for the AC condenser whereas the non-AC bars I believe are straight.
Wow Never noticed that till you stated this so I checked my 66 air trucks today and one original 66 non air 283 pickup. This is now the easiest way to visually check for a factory air assembly line install. Two had the X brace with the bars bent outwards a few inches from each end and the non air trucks were perfectly flat bars. All had the lower end of the bars riveted to the support and a bolts to the upper ends. My one ac truck which was not factory installed air did not even have the X bar replaced from the dealer installation!
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 05-14-2013, 09:32 PM   #27
Flea Jr.
I would love to see a pic of that if anyone has one so I can replicate It on mine
Flea Jr. is offline   Reply With Quote
Old 05-14-2013, 11:18 PM   #28
cortcomp
cortcomp's Avatar
Pic of that air deflector piece thing, and some of the riveted on bottom and bolted on top offset crossbars.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 05-14-2013, 11:29 PM   #29
HOTFUN
HOTFUN's Avatar
Forgot I had that ac cowl metal piece shot from a 66 C10 with factory air.
'72 GMC K2500 4x4
Old 05-15-2013, 01:23 AM   #30
LT1 Burb
LT1 Burb's Avatar
Good pic Cortcomp and Mark, that Xbar as far as I would be concerned is a sure fire way to prove it. I guess it would be easy to add or hard to replace if you had a wreck.
LT1 Burb is offline   Reply With Quote
Old 05-15-2013, 01:35 AM   #31
Flea Jr.
Thank you cortcomp. Looks like I can reproduce the bend in the x brace pretty easily. As far as the little air deflector I'm still not convinced that was an A/C only part.
Old 05-15-2013, 07:46 PM   #32
VictoriaHardware
VictoriaHardware's Avatar
My AC cab has this little extra air deflector on it, can anyone else confirm this as an AC only piece.
My 1966 February Fremont built 1966 Thrift-Air Heater truck has it.
VictoriaHardware is offline   Reply With Quote
Old 12-30-2017, 02:23 AM   #33
1966 K10
1966 K10's Avatar
So this is a dealer install? Bent cross bars but nut/bolt at the bottom.
Anyone have a pic of a factory stamped dash?
1966 K10 is offline   Reply With Quote
Old 04-02-2019, 07:34 AM   #34
Ronster66
Originally Posted by corvettejim1968 View Post
does yours have the blue a/c sticker on the back window?
Mine had the sticker in the rear glass and it was the green tinted glass. Unfortunately, while the truck was at the body shop in the mid 90’s, all of the glass was removed and the rear was broken. It wasn’t in good shape to begin with. It had a bunch of burnt/melted spots that looked like someone had ran a welder next to it or something. Who knows? Regardless, I intended to re-install it just because of the sticker and the tinted glass wasn’t available in those days. So, my truck has clear glass and a repop sticker.
'66 Custom Cab BBW SWB Fleetside 327/TH350 Factory A/C
‘96 Dodge Ram 2500 Laramie SLT Club Cab 4X4 8’ bed V10/47RE
Ronster66 is offline   Reply With Quote
Old 04-06-2019, 12:10 PM   #35
jocko
jocko's Avatar
Interesting discussion, I thought the a/c option also pulled in soft-ray glass - but as I read thru the above posts, not sure that is the consensus(?) Only documentation I could find doesn't seem to mention it though. Is there a definitive answer on this - was this a later year thing wherein a/c and soft-ray were linked together?
Old 04-06-2019, 09:37 PM   #36
rws1012
I just bought a 1966 truck for parts that has factory air in it. Is it better to restore the factory air system and put it in my non a/c truck (66), or buy an aftermarket unit? Thank you in advance for any replies.
rws1012 is offline   Reply With Quote
a/c, factory
