Old 09-27-2013, 10:38 AM   #26
Angryman117
Re: Pre-LS swap questions
Here is a link to my build.
I am using the Performance online Engine and transmission cross members. My oil pan hangs about 1 inch if that below the front axle. I am also using home made motor mounts so that might have something to do with it. When I get the engine and transmission back in the frame I will try to post some pictures.
Angryman117 is offline   Reply With Quote
Old 09-28-2013, 10:31 PM   #27
Root2812
Root2812's Avatar
Angryman, thanks for the info. I'll look forward to seeing your project come along.
Today I made a few more steps forward. I got the motor out of the trailer and onto an engine cart. I just picked up the $50 cart and northern tool because I'll take it to my dad's shop to do most of the work to the motor. I just needed something so I could move it around in my garage. I took the wiring harness off so I think that is where I will spend my winter. I spent most of my savings on the motor and the intake I got today.
I purchased an LS6 intake off of a ZO6 Corvette. It was complete with throttle body, fuel rails, and injectors for $400. I'm happy. I can't wait to get it on the motor but I want to replace all the seals and all the gaskets in the motor first. This is exciting.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 09-28-2013, 11:11 PM   #28
Andy4639
Old member
Andy4639's Avatar
Wink Re: Pre-LS swap questions
Man it looks like several of us are going to have winter projects to get done.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-29-2013, 01:18 AM   #29
Angryman117
I would love to have my truck done by next summer so I could drive it home to visit my parents in northern MN and then head on down to back to the 50's fest at the state fair. Will see how much the 5 month year old cooperates and how much work on the truck the wife will let me do!
Old 09-29-2013, 02:32 PM   #30
Root2812
Root2812's Avatar
Where in Northern MN? I plan to take mine to back to the 50's next year. I missed this year with brake issues.
My 1950 Chevy build
Old 09-29-2013, 04:34 PM   #31
Angryman117
Bemidji area.
Old 10-03-2013, 09:13 PM   #32
Root2812
Root2812's Avatar
Hey guys,
So today I picked up what is supposed to be the exhaust manifolds from a C5 corvette. I was told by forum members that the corvette manifolds would clear my frame so when these came up on CL I bought them. By looking can you guys confirm they are the right ones? It looks like the ones I see online.
My next question is what are these two holes on the exhaust? I assume the lower one is the O2 sensor but I am not sure. I looked at my truck manifolds and they didn't have either of these holes. I only gave $75 for the pair so I'm not heavily invested but I hope they are the ones I needs.
My 1950 Chevy build
Old 10-04-2013, 09:21 AM   #33
Jonboy
Slots go on anything!
The upper one looks like it was an EGR tube, and the lower one should be for the O2 sensor.
1974 Jimmy- 5.3/4L80e/NP241
Old 10-04-2013, 10:58 AM   #34
Angryman117
The smaller holes up top are for a EGR system. I am going to block those off on mine. The lower holes are for O2 sensors, you will need them if you plan to run EFI. Your manifold look slightly different than mine, but look like they should still work.
Here is a picture of my passenger side manifold.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Old 10-21-2013, 09:33 PM   #35
Root2812
Root2812's Avatar
Well my LS6 intake arrived today. Its broken. The box was beat to hell and looks like it got dropped right on the back of the manifold. The part with the MAP sensor and vacuum ports got pushed into the intake and cracked around the circle. I don't know if it can be fixed or not.
I sent pictures to the seller and he is sending me another one so I hope that one arrives in one piece. Either way he doesn't want me to send this one back. Do any of your guys have experience fixing these plastic intakes?
My 1950 Chevy build
Old 10-21-2013, 09:47 PM   #36
Billett
Billett's Avatar
More trouble than it's worth
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 10-22-2013, 10:22 AM   #37
Angryman117
Maybe rough / scar the area up and use some 2 part epoxy?
Angryman117's
47 Chevy Build
Old 10-22-2013, 08:29 PM   #38
Root2812
Root2812's Avatar
That's one of the things I've read people doing. Apparently this type of plastic is really hard to bond back together. I would like to find a professional plastic welder if I can .
My 1950 Chevy build
Old 11-04-2013, 01:05 AM   #39
Root2812
Root2812's Avatar
Hey guys,
So this weekend was supposed to be the weekend of progress on getting the motor all cleaned up and what not. Unfortunately my 2000 GMC Jimmy decided to suffer from the all too common bad injector spider. I ended up spending my Saturday replacing that spider with the upgraded Multiport FI system.
Anyhow, my new intake did arrive and was in good condition. The guy I got it from didn't ask me to send the broke one back so now I have 2 sets of fuel rails, throttle bodies, and injectors. Spare parts may be useful later.
I also have been giving some thought to what has been said here by all of you and I am going to go with the 4l60e instead of the 700r4 I already have. It came down to easy of hook up with out having to deal with a tv cable and the fact that by they time I buy the adapter kit and tv cable I'm almost to the cost of the 4l60e. I just gave the 700r4 to my dad. Its going to go in a 57 bel-air behind a 283.
So here is a question. I have read that there are many differences in the 4l60e's. Could I run one that came out of a 2002 with a 4.8 when my motor is a 2000 5.3? I think I could but I want to check with you guys first. A local guy has that tranny in 2wd with 130,000 for $400. I can get him to come down. Up here in the north the 2wd trannys are harder to come by because most guys buy 4x4 trucks.
My 1950 Chevy build
Old 11-04-2013, 01:10 AM   #40
66C06
66C06's Avatar
Hey guys,
That transmission will work no problem. If it was from a car you would have to change the tail housings but there is no difference between a 00 and 02 2wd transmission. Good luck with the build! Can't wait to see more progress!
66 SWB Stepside: Project C-O6
06 ZO6 MSM 6spd 562/520rw N/A
06 Caddy CTS The Daily
07 Hayabusa - absolute chaos
66C06 is offline   Reply With Quote
Old 11-04-2013, 01:52 AM   #41
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
huh?
You would only need to change the tail shaft housing if it was a 4wd tranny, the 2wd tranny is fine as-is. The other tailshaft change was switching to a 6bolt talshaft housing for the 1998 revamp. That would only apply if he was trying to use an old 4l60e, which would also have a 300mm shaft, different planetary etc etc.
and no car ever had a 4.8 or 5.3
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-04-2013, 02:08 AM   #42
66C06
66C06's Avatar
Originally Posted by BR3W CITY View Post
huh?
If you re-read my post I clearly stated there is no difference between a 00-02 2wd transmission. I should have been more clear and was just stating a fact the if the trans came from a car, more specifically an f-body, you would have to change the tail housing.
oh and the 06-07 monte carlo ss, 05-08 Grand Prix GXP, 06-09 Impala SS, and 08-09 Buick lacrosse had a 5.3. jus sayin.
Old 11-04-2013, 04:30 AM   #43
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
torque arm brackets can be added without switching the tailshaft housing, and none of the cars you listed used a 60e.
Old 11-04-2013, 04:45 AM   #44
66C06
66C06's Avatar
I suppose you wouldn't have to change the tail shaft housing if the torque arm bracket wasn't going to be used. And you said no cars came with a 5.3, you said nothing about them having a 4L60e...
Old 11-04-2013, 11:51 PM   #45
Root2812
Root2812's Avatar
First things first. Before I can stab the motor into the truck I needed some front suspension and boxed frame rails to weld motor mounts too. My complete hub to hub kit from Fatman fabrications will be here soon. I'll post pics when I get it in.
My 1950 Chevy build
Old 11-05-2013, 12:43 AM   #46
oldman3
oldman3's Avatar
Would like to know how you feel about this front end, during installation, etc. Have a friend that is thinking about one also...Jim
oldman3 is offline   Reply With Quote
Old 11-06-2013, 01:45 AM   #47
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
As for the torque arm thing; you still wouldn't have to change the tailshaft housing even if you did need to run a torque arm mount (which doesn't apply). There are relocation brackets and crossmembers designed for the cars that DO use torque arms. The tailshaft mount torque arm brackets can brake housings in high power applications, it wasn't the greatest place for it to start.
Remember the context of the thread; he asked a trans question about the 2000 and 2002 4.8 and 5.3 in question. There is no car with a 4.8 or 5.3 that could possibly apply to his situation, they all used the fwd configuration. Further, those all use the ls4, which isn't the same as the iron blocked 4.8 and 5.3 we are all referring to. It doesn't even have the same bellhousing pattern.
Don't get lost trying for a pissing match, its not helpful to the op.
Old 11-06-2013, 11:54 AM   #48
SparkyRnD
SparkyRnD's Avatar
If you are still looking, we also make a bolt-in aluminum crossflow radiator for the LS conversions, with the correct inlet and outlet, both on the passenger side, along with the steam port and trans cooler for no additional cost. They are USA made, by hand, and fully TIG welded with no plastic or epoxy. Forum member discounted price is $425. Let me know if you have questions or would like to order one. We are also a supporting vendor on this site.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 11-06-2013, 08:24 PM   #49
Root2812
Root2812's Avatar
I'll keep you in mind when I get to that phase of the project. I still need to finish my suspension before I get to dropping the motor in.
My 1950 Chevy build
Old 11-07-2013, 11:17 PM   #50
Root2812
Root2812's Avatar
So now that I decided to go with the 4l60e I'm in a predicament. I haven't been able to score a tranny yet but I want to get my suspension and motor mounts all welded in. Can I use the 700r4 for mock up or are they too different in shape? I won't weld the tranny cross member in but I want to have on there when I make the motor mounts so I can get a good idea of how/where to position the motor.
My 1950 Chevy build
