Old 06-18-2013, 03:41 PM   #26
markedgar5
markedgar5's Avatar
Re: Project : HITCHED
quote: Once engine was dropped in the task of bolting torque converter was made much easier with the fiancé rotating engine over with me underneath.
You have a great fiancé. Supportive, gorgeous, and common interests.
Congratulations to the two of you. Don't take that for granted. Not many good ones out there. About as rare as a rust free blazer.
markedgar5 is offline   Reply With Quote
Old 06-19-2013, 02:43 PM   #27
910hugger
910hugger's Avatar
Ordered seat covers from PICKUPMAN today. Black vinyl / Orange houndstooth
910hugger is offline   Reply With Quote
Old 06-22-2013, 12:05 AM   #28
910hugger
910hugger's Avatar
moving forward i began to start routing wires to starter, alternator, coil and eliminating unused wires. to my suprise the factory harness was in excellent condition with a few wires being cracked and brittle.
Old 06-22-2013, 07:09 AM   #29
910hugger
910hugger's Avatar
Any takers on what yellow, green wires are ?
Old 06-22-2013, 09:13 AM   #30
jaros44sr
jaros44sr's Avatar
Green is usually temperature sending unit, or horn. Yellow seems to be spliced into red and red in that area could be electric choke, yellow also could go to the starter along with the purple. If infact,the red is pink(which, in gm terms, means 12 volt switched) it could also go to the starter
Follow the wires back, and make sure the colors are correct. I would change the colors back to oringinal, if they are changed. If the wires are brittle, check all the way back where they are wrapped, id replace them. Connecters are available, and part of a safety check should include your electrical harnesses
Do you have a wiring schmatic, if not drop down to the electrical section, look in the stickies for a a colored one
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-22-2013, 06:22 PM   #31
910hugger
910hugger's Avatar
I printed a wiring schematic from the electrical section and it was sure helpful. After doing the engine swap I have a lot less to be connected:
Coil
Starter
Alternator
temp sensor
elec choke
I knew I should have labeled wires as they were removed
This is another pic of the wiring.
Next issue is that engine starts/idles great but falls flat as soon as rpm increases. All vacum lines are plugged/connected and it has clean fuel. Waiting for timing light to come in to check base timing. Not sure if its a little different because of the MSD diet/coil ???
Old 06-23-2013, 04:30 PM   #32
910hugger
910hugger's Avatar
More wires
Old 06-23-2013, 04:35 PM   #33
910hugger
910hugger's Avatar
Firewall wire harness looks to be in gret shape. No corrosion and no splices
Old 06-23-2013, 04:40 PM   #34
910hugger
910hugger's Avatar
Theres a lot of different ways to eliminate voltage regulator. Not sure what best option will be.
Old 06-29-2013, 08:42 AM   #35
910hugger
910hugger's Avatar
It wouldnt be a project if it wasnt " one step forward, two steps back " . Almost ready to move past the engine and start driving. Base timing set at 10deg, total advance 34deg, idle set at 700rpm. Starts great,idles smooth, no pinking or knocking on throttle but coughs and backfires under quick acceleration. Propane torch found the carb base gasket leaking and an increase of 75-100rpm. Almost unteaceable if it wasnt for the digital timing light. A friend lent it to me and now have to own one.
Old 06-29-2013, 08:47 AM   #36
910hugger
910hugger's Avatar
Originally Posted by 910hugger View Post
More wires
Comparing to a 72 Suburban these wires are for the emissions that mount on drivers side of intake manifold and are no longer needed. The BROWN/WHITE wire does have keyed 12V so it may come in handy once I check a few other things out.
Old 06-29-2013, 08:56 AM   #37
910hugger
910hugger's Avatar
Checklist to complete this week:
carb intake gasket ( replace )
Lokar billet throttle/kickdown bracket ( install )
Lokar TH350 kickdown cable ( install )
wire alternator, battery, gauges, tach
check coolant hoses for leaks
clutch fan, shroud ( install )
mount seats, seat belts, hood
power steering hoses ( install )
Then double check all fluids, check leaks ( hope none ) then test drive.
Old 06-29-2013, 09:01 AM   #38
910hugger
910hugger's Avatar
A few clips of engine. Other than carb gasket leak and exhaust gasket donut leaking it sounds pretty good IMHO.
https://www.youtube.com/watch?v=j8NTGkwWCjs
https://www.youtube.com/watch?v=oWbcBWY3DaU
https://www.youtube.com/watch?v=OhtuEYiInPc
Old 06-29-2013, 09:20 AM   #39
910hugger
910hugger's Avatar
Extra shop hands that dont mind staying late
Old 06-29-2013, 12:08 PM   #40
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Good looking dogs. You should start a thread dogs on plaid seats.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
Last edited by JayDubBlazer; 06-29-2013 at 12:11 PM. Reason: Incorrect identification of seats
JayDubBlazer is offline   Reply With Quote
Old 06-29-2013, 01:26 PM   #41
910hugger
910hugger's Avatar
Not plaid seat but good pic
Old 07-19-2013, 12:49 PM   #42
Slammed66
Needs a Big Block
Slammed66's Avatar
Great build!!
I remember the truck at Scott's.
I also know that orange burb you used for reference, I'm Ryan's # parts supplier. Hahaha.
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 07-24-2013, 01:25 PM   #43
docstheman
docstheman's Avatar
Nice Blazer!
~ It's a Learning Process ~
Click Here for my Blazer Build: 1971 Blazer 4x4
Click Here for my Work Truck Build: 1970 C10 LWB
Toys: 1970 C10, 1971 Blazer 4x4, 1976 Corvette Stingray L82, 2011 Cadillac CTS 6 speed, 2008 VTX 1800F
docstheman is offline   Reply With Quote
Old 07-26-2013, 09:26 AM   #44
910hugger
910hugger's Avatar
Progress has been steady and yesterday was the virgin run. Have to thank the help from guys in our Toyota Club, the TARSAND TOYOTAS. Its amazing how much work can be accomplished with a fridge full of beer, a few pizzas and lots of wings.
All things considered there are very minor details to workout. Engine seems to be running way to rich and is overfueling. It coughs under load and acts like an old worn out 2barrel small block. The brakes need to be bled, and rockers re adjusted but nothin major so far........
Not sure whats going on with loading pics so I will post another small vid
Old 07-26-2013, 11:09 AM   #45
910hugger
910hugger's Avatar
https://www.youtube.com/watch?v=0ku7...PH10qkZ3a5fqoA
Old 07-26-2013, 11:11 AM   #46
910hugger
910hugger's Avatar
Finally rescued this one for my cousin, a bit rough around the edges, body wise and is on a newer blazer frame ( 1977-87 ) but there is at least something to work with
https://www.youtube.com/watch?v=2h0T...PH10qkZ3a5fqoA
Old 10-29-2013, 12:55 PM   #47
910hugger
910hugger's Avatar
fuel tank and repro belts
Old 10-29-2013, 03:52 PM   #48
AHowe88
Nice, good looking pups too. I'm guessing you hunt them? My GSP is 12, but still can get out for a few hours of hunting.
AHowe88 is offline   Reply With Quote
Old 10-29-2013, 07:29 PM   #49
910hugger
910hugger's Avatar
the dogs get hunted for sure. After stripping the rubber from origional tank straps I replaced with rubber from outdoor floor mat and used silicone as sealant
