Old 07-14-2013, 11:10 AM   #26
Katrina/10
Katrina/10's Avatar
Re: Project: Scott's IFS into 51 GMC
Made some more progress. I bought a new U-joint for the steering column. I cut the end off the van column to shorten it, and made it into a D shaft by grinding 2 flat spots in it.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-14-2013, 11:22 AM   #27
Katrina/10
Katrina/10's Avatar
This is what it looks like now. I added some 2 inch blocks in the rear to bring it down to the same level as the front.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 07-14-2013, 11:28 AM   #28
nvrdone
Gary - when you had the stock axle, what were you using for the power steering ?
nvrdone is offline   Reply With Quote
Old 07-14-2013, 11:34 AM   #29
Katrina/10
Katrina/10's Avatar
I had a home made power steering setup using a 75 C10 steering box mounted outside the left front frame rail, similar to the kits you can buy. I did not work well because I used the original steering arm on on the spindle, and it would not turn fully left or right. The kits use a shorter arm that is bolted to the top of the spindle, and should work better. But I can't say for sure, I never installed one.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 07-14-2013, 05:45 PM   #30
solidaxel
solidaxel's Avatar
That truck gets better looking every day !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-14-2013, 07:43 PM   #31
Katrina/10
Katrina/10's Avatar
Why, thank you very much! Now it's time to drive it and make sure everything works right.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 07-14-2013, 11:06 PM   #32
solidaxel
solidaxel's Avatar
How did the alignment go on the front suspension?
LS 3 4L70E
Old 07-14-2013, 11:44 PM   #33
nvrdone
Gary -thanks for the info. I've heard that setup doesn't work too well. I'm looking at using a Toyota land cruiser box that mounts on top of the frame rail. But that's in the distant future.
Old 07-15-2013, 05:24 PM   #34
Katrina/10
Katrina/10's Avatar
I adjusted the toe-in with a tape measure, and the camber with a level against the rim. Didn't mess with the caster, and it seems to drive fine. Very stable at any speed.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 08-09-2013, 09:38 AM   #35
Russell Ashley
Russell Ashley's Avatar
Still happy with it now that you have put some miles on it?
I'm sold on that setup, going to be my next upgrade probably this winter. I have to get the things I've already bought installed first before spending any more $$$ though.
Russell Ashley is offline   Reply With Quote
Old 08-09-2013, 10:20 AM   #36
Katrina/10
Katrina/10's Avatar
Hi Russell, the suspension is working great, no problems with it at all. The old truck is a pleasure to drive now!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 02-11-2014, 05:34 PM   #37
Russell Ashley
I think this thread convinced me that this is the way I want to go. I ordered mine yesterday so it should be here sometime next month.
Old 02-12-2014, 07:20 PM   #38
Katrina/10
Katrina/10's Avatar
Great! Be sure and make an install thread, I will anticipate reading it!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 02-12-2014, 09:32 PM   #39
DieselRat
Sweet looking truck and nice job on the upgrade!
DieselRat is offline   Reply With Quote
Old 02-14-2014, 11:58 AM   #40
Katrina/10
Katrina/10's Avatar
Thanks, it all seems to be working well. The truck looks better in pictures, of course, the paint job is really old, but still looks decent. It's a lot more pleasant to drive now, I think I am going to do a gear swap in the rear axle soon to bring the RPM down.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
