Old 07-13-2003, 12:28 AM   #26
Gee_Emm
Todays progress, took the rockers off, trimmed up the WS header.
Next step is to sand blast the cab and repair the rocker backing plates.
The header panel is two pieces that I left spot welded together, it is just laying there, needs some more tweeking still.
Gee_Emm is offline   Reply With Quote
Old 07-13-2003, 08:22 AM   #27
chiphayes
blazerman,the windsheild frame worked out great,i hope to post some pics soon,got the paint picked out wed,orange sherbert.my 72 sb is painted,lime sherbert,ive got a 68 thats going to be,blue sherbert.
chiphayes is offline   Reply With Quote
Old 07-13-2003, 10:11 AM   #28
Gee_Emm
Where did you make the cut on the frame?
Old 08-05-2003, 10:00 PM   #29
Gee_Emm
Nothing much going on, been sandblasting everything. Got the rear suspension parts ready to paint and have both rocker backing plates ready to go in.
Old 08-05-2003, 10:02 PM   #30
Gee_Emm
Any ideas how to fix this up? This is my good one!
Old 08-05-2003, 10:04 PM   #31
Gee_Emm
Yup!
Braze, lead? Help!
Old 08-05-2003, 10:09 PM   #32
Gee_Emm
The aftermath, the bed isnt even in this pile yet.
Old 08-05-2003, 11:10 PM   #33
Alexis
Member since 2000
Alexis's Avatar
Finally got my helmet. i also have a few days off from work and going to practice welding. next thing you know I'll be right where you are at on the body Any work is good work unless you have to take a few steps back. Keep up the good progress!. I have this thread bookmarked to keep me on my toes.
Alexis is offline   Reply With Quote
Old 08-06-2003, 09:18 AM   #34
Gee_Emm
Have you ever welded on patch panels?
Old 08-06-2003, 10:20 AM   #35
jays68yak
jays68yak's Avatar
Put it on the low setting, tack it every so often, dont weld in one spot too long it will heat up the metal and warp it. then you get to spend 2 years doign body work to only have to one day go back and redo it. On the brightside my car is blue so with all the waves it looks like and ocean.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 08-06-2003, 12:26 PM   #36
Alexis
Member since 2000
Alexis's Avatar
No i haven't, just heavy steel for suspension components.
Old 08-06-2003, 01:12 PM   #37
Gee_Emm
I have done other panels but on this cab.
I finally figured out the secret. You have to space the joints of the two panels out about 1/16 to 1/8 " don't butt them up close. It took me only an afternoon to cut out and weld in one of those backing plates and I must say that its my best work ever using my new found method.
Old 08-06-2003, 01:28 PM   #38
JHickson6
I Love This Stuff!
JHickson6's Avatar
uhh Greg you forgot to add something to the scrap pile.
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 08-06-2003, 01:37 PM   #39
Alexis
Member since 2000
Alexis's Avatar
Yeah i keep in mind on what i have read from the pro's on here when someone asked about welding. i think that was one of the tips to keep a little crack between the pieces you are trying to bring together.
Jhickson- lol
What tool do you use to grind down the welds? I got to post some of my improvement pictures. I've been using a sheet of 22 gauge steel to mess around with even though it thicker then a body panel but it works to practice.
Old 08-06-2003, 01:39 PM   #40
jays68yak
jays68yak's Avatar
Are you making a lip on either one of the panels or just butting them up to each other? I bought a little air powered tool that makes a lip on the sheet metal. This way to will line up, as long as you dont get the metal too hot.
Old 08-06-2003, 01:41 PM   #41
jays68yak
jays68yak's Avatar
Jhickson- lol
I found that OSH sells a really cool sand paper type of grinding wheel. It makes cleaner grinds then a regular grinding wheel. Also done grind in one spot too long cuz you can warp the metal that way too.
Old 08-06-2003, 01:45 PM   #42
Alexis
Member since 2000
Alexis's Avatar
I work at OSH, hahaha to bad they don't have a great selection of air tools.
Old 08-06-2003, 01:47 PM   #43
jays68yak
jays68yak's Avatar
but dont you get a discount at sears too?
Do you know what grinding wheels im talking about then?
Old 08-06-2003, 01:52 PM   #44
Alexis
Member since 2000
Alexis's Avatar
no we don't get a discount at sears
i've seen two kinds of grinder, one with a 5 inch pad and one that uses a small pad that has a thread on the back to connect to the tool. man we've hijacked this thread.....sorry Gee_Emm
Old 08-06-2003, 02:00 PM   #45
jays68yak
jays68yak's Avatar
na we just keeping it up top for him. haha
I use a 4.5 inch grinder, ill see if i can get a pic of the wheel that I use. I cant for the life of me find one on the net.
Old 08-06-2003, 04:16 PM   #46
Gee_Emm
I forgot to add this earlier but another reason I am having so much success this time is due to the grinding wheels I am using,
I discovered flap wheels, they are like a regular disc with a bunch of little squares of sandpaper glued on. They are more expensive but worth EVERY penny IMO. It is way hardered to heat the metal up and the pad is kinda soft yet still ridgid so it conforms to the surface.
Old 08-06-2003, 04:21 PM   #47
Gee_Emm
A flange tool? So you would have two thickness of metal when the seam is done?
I am just butting them with a space in between.
Old 08-06-2003, 04:27 PM   #48
jays68yak
jays68yak's Avatar
Those are the ones are was talking about.
Ah heres a pic of one:
http://www.epinions.com/Shop_Tool_Ac..._36_Grit_26152
Old 08-06-2003, 04:29 PM   #49
jays68yak
jays68yak's Avatar
you are correct. for my car it didnt matter and it was easier to weld the skins on. The only time you see it is when you look inside the trunk.
There are some pics of my sheetmetal replacement here:
http://f1.pg.photos.yahoo.com/bc/jas...dir=/68+Lemans
none of them show the flange tho.
Old 08-06-2003, 04:32 PM   #50
Gee_Emm
i would think that could be a potential for rust though, if moisture got in between the two layers.
