Old 09-27-2013, 12:21 AM   #26
HOT WRECKS
HOT WRECKS's Avatar
Re: Project "HOT WRECK" 62 Short box DUALLY
This weeks progress is not that exciting picture wise, but at least it was progress.
Got the cab off my hoist
This tank with its 160'' WB doesn't quite fit on my hoist. Had to stack 2X8s in front and make a ramp to drive on to them. front of truck is right up against bolt bin, and door just closes. very tight fit I have to crawl over deck to get to the other side
I have removed all the rusty nuts and bolts holding the deck on and have replaced them with new 3/8 bolts finger tight. had to do some cutting at bumper where it was welded to frame. tail lights are loose and duct taped on, and a gas can is in the cab plumbed to fuel pump.
I'm going to drive it to the metal scrap yard and have them remove it with their big magnet. I'm hoping to get 60 HOT WRECK dollars from it.
Anyone can restore It, but it takes a real man to Cut It Up!!
http://67-72chevytrucks.com/vboard/s...65#post6274665
HOT WRECKS is offline   Reply With Quote
Old 09-27-2013, 09:01 PM   #27
HOT WRECKS
HOT WRECKS's Avatar
Bye-Bye Welding deck!
received $90.90 HOT WRECK dollars
Old 09-28-2013, 10:28 AM   #28
erock805
erock805's Avatar
oohh did you get a pic of that big thing in the air? that's amazing to me. keep rollin
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 09-29-2013, 01:16 AM   #29
HOT WRECKS
HOT WRECKS's Avatar
That was the plan but I managed to turn off my camera mid action instead snapping the picture LOL!
Old 09-29-2013, 02:29 AM   #30
HOT WRECKS
HOT WRECKS's Avatar
Had to work today until 2:00PM but got started stripping the 1 ton as soon as I got home. It looks like this as of 9:30 tonight.
Name:  stripped 1 ton 001.jpg
I have to remove 45'' of length. I'm Not just going to cut out a 45'' suction of frame and weld it back. I'm going to move the spring hangers up 45'' into the nice clean section of frame and build fresh from there back. recycling as much frame as I can
Name:  stripped 1 ton 002.jpg
So as of last night I decided that I am going to use the 1980 cab floor and the lower portion of the fire wall. This way I will not have to make new cab mounts on the frame. And since the floor and cab mounts are in very poor condition on my 62 cab this will take care of me having to repair them. Other benefits are all the clutch linkage and peddles are where they need to be. As are Steering column, hydra boost brakes, and E-brake pedal assembly...... But the best part is I'm going to channel HOT WRECKS body 2-3''
Name:  stripped 1 ton 005.jpg
Need longer hoist.....or better yet a shorter truck!
Old 10-13-2013, 01:24 AM   #31
HOT WRECKS
HOT WRECKS's Avatar
Ok lets get up dated!
Name:  80 frame 009.jpg
Everything removed from 1980 cab. Floor, fire wall, pedal/column assembly &
e-brake pedal are all that remain.
Name:  80 frame 012.jpg
I spent a few hours getting my hoist absolutely level front to back, and side to side. Laying out and squaring up 115'' WB on hoist deck. you can just see the markings for the centre line of the rear wheels just ahead of the MSD sticker
Transferred the centre line of the rear spring hanger bolt to the top of the frame. Measure forward 44'' to locate new hanger centre line.
Old 10-16-2013, 11:29 PM   #32
HOT WRECKS
HOT WRECKS's Avatar
Time to start the kick up in the frame for the rear diff flip.
I have shortened two 73-87 truck frames before but never lowered them to the extreme that is one is going to be. So where to start?? After a few well spent hours of locating the new diff centre line for 115'' WB and some more figuring of where the axle is going to sit after the flip and moving up the spring hangers 2'' I knew that the bottom of the frame over the axle was going to have to be 2 1/2'' higher than the top of the straight frame rails after the cab. And I want a 8'' of frame length over the axle. 4'' on either side of the axle. My frame angles at the kick up will be 45 degree angle.
the frame width is 7 1/2'' tall after the cab and 4 3/4'' tall at the rear bumper
So starting with this info here's how I made my templates. starting with some card stock I cut one strip at 7 1/2'' wide (front frame) one strip at 4 3/4'' wide (rear frame) and one strip at 6 3/4 this strip represents the piece of frame just over the rear axle. 4 3/4'' for the frame and 2 1/2'' for the distance between the original frame and where my new frame bottom will start. from there I knew that my length of frame just over the axle is going to be 8'' so at 2 1/2'' up on my 6 3/4 piece I measured out 8'' line and at the end of the line on each side I drew a 22.5 degree angle to the top that gave me my starting piece. 8'' short to short of a 22.5 degree angle 4 3/4 tall.
Name:  more frame 002.jpg
now with this template done and in position I took the 7 1/2 strip and cut a 22.5 degree angle long at the top and lined it up with the 22.5 degree angle on the first template, then copied that 45 degree angle onto the frame. Intersecting the two lines (they have circles around them in pic) at the top and bottom of the frame gave me my 22.5 degree angle that the frame will be cut at. and then transferring that measurement back onto my template gives me 10'' long to short 22.5 degree angle template. I then used a straight edge to taper the 7 1/2 side at the bottom up to the bottom of the 22.5 angle on the 4 3/4 template.
Name:  more frame 004.jpg
Name:  more frame 003.jpg
the rear most template is the easiest. it will be 10'' long to short of a 22.5 degree angle just like the front one but with no taper. just 4 3/4'' the entire length.
Name:  more frame 007.jpg
Its a little wordy but I hope it makes some sense.
Old 10-17-2013, 08:38 PM   #33
Bomp
Bomp's Avatar
Definitely have my attention. Are you going to fish plate the inside or box the frame for added strength?
Like all the templets and measurements.
Bomp is offline   Reply With Quote
Old 10-18-2013, 10:17 AM   #34
HOT WRECKS
HOT WRECKS's Avatar
well Mr Bomp if I have your attention then I must be on the right track. I've been following your build and your fab skills are Dynamite!
As for strengthening the frame I will be fish plating it. Being that it is 1/4 inch thick by 7 1/2 tall I bet I could get away with a good double sided weld. Since it will never haul any real weight any more.
But I want to tow my 24'' holiday trailer with it. Its better to be safe than sorry.
Old 10-20-2013, 01:13 AM   #35
HOT WRECKS
HOT WRECKS's Avatar
The drivers side frame rail cut off at a 22.5 degree angle and bolted onto the passenger side, aligning all the factory holes in frame. Now the angles on both sides is exactly the same, even if the angle is off a degree or two.
Name:  frame kick up 004.jpg
Now the drivers side frame rail becomes the passenger side frame rail. Aligning up the short sides of both 22.5 degree cuts becomes the
45 degree kick up
Name:  frame kick up 015.jpg
Using my template I can transfer the new shape of the first piece of frame for my kick up
Name:  frame kick up 016.jpg
The centre triangle will be removed and then I will have my tapered piece of frame from 7 1/2'' to 4 3/4''
Name:  frame kick up 018.jpg
Old 10-20-2013, 11:02 AM   #36
Bomp
Bomp's Avatar
Looking good.
Dig the tag line. ""Anyone can restore It, but it takes a real man to Cut It Up!!""
Old 11-17-2013, 03:24 PM   #37
HOT WRECKS
HOT WRECKS's Avatar
All right. It's been awhile since I've posted any progress. Life got in the way of my HOT WRECK project, but I have slowly and steadily been hammering away at it.
Name:  frame kick up 019.jpg
I cut my templates down the centre and laid them on the top and bottom of the frame rail, removing the centre. Turning all my 7 1/2'' frame rail into
4 3/4'' frame rail so that it will match the factory rear most frame rails
Name:  frame kick up 021.jpg
here is the centre removed and the two halves placed back together
Here's all the frame bits cut for the D/S kick up. I have done the exact same for the P/S.
Yahoo!! it looks like a frame rail again. All welded back together using a very healthy Bevel on both sides to allow more penetration for a stronger weld. All factory hold have also been filled. Then ground all welds smooth, and sand blasted it
A fishplate has been added at both 22.5 degree vertical joints for added strength. Since this picture was taken the welds on the fishplate have been die grinded and sandblasted for aesthetics.
Old 11-17-2013, 03:34 PM   #38
NASTY-LSX
really cool project. Cant wait to see the end result!!!
NASTY-LSX is offline   Reply With Quote
Old 11-17-2013, 03:50 PM   #39
Bomp
Bomp's Avatar
That is some seriously nice finish work there.
Old 11-17-2013, 07:58 PM   #40
C@rnut001
Wow, this is going to be one amazing truck! Keep up the awesome work on your build and thanks for all of the updates. I think it is great that your son is helping you and learning from you. I am definitely going to be following along as you complete this one!
C@rnut001 is offline   Reply With Quote
Old 11-17-2013, 09:56 PM   #41
Narxoleptic Customs
Thumbs up!! Keep the pix and progress coming.
Narxoleptic Customs is offline   Reply With Quote
Old 11-18-2013, 01:55 AM   #42
HOT WRECKS
HOT WRECKS's Avatar
Thx. I can't wait to see the end result myself!
Thx you just put a great big pride smile on my face
Thx. My son is loving this project. He will talk about it endlessly to who ever will listen
Thx This is my first forum build and I'll tell you it is really satisfying sharing my passion with others who appreciate it also. It really keeps me motivated to trudge forward and show everyone the prior weeks of work
Old 12-01-2013, 01:45 AM   #43
HOT WRECKS
HOT WRECKS's Avatar
Here's some pictures of the start of the build of the rear section of my frame build before I got side tracked rebuilding my rear diff.
disassembly of rear most section of frame rails
test fitting stock rear frame rail to custom built section
same as last picture different angle
trimming the back side of the frame rail along the line shown to keep the frame rails the same width then entire length of the frame.
welding up all the factory holes
Old 12-01-2013, 03:14 AM   #44
HOT WRECKS
HOT WRECKS's Avatar
upper spring is the stock one ton, 10 leafs plus the heavy over load spring at the bottom. and at the top is the over load spring helper pack.
the lower spring pack is what I will be using. five leafs, Plus I will be adding the heavy over load spring to the bottom of the pack
Name:  truck stuff 019.jpg
At the sand blasting yard. blasting the disassembled 14 bolt diff
(dam it's heavy) plus all the leaf springs, brackets, and rims.
spent $300 sand blasting WOW!! it's not cheep
Name:  truck stuff 023.jpg
Primed and painted all parts gloss white.(frame and all suspension parts will be gloss white) Spent another $300 on Trem-Clad rust paint, Canadian version of Rust-Oleum.
Even building a rat rod is not cheap!!
Old 12-01-2013, 11:36 AM   #45
Dinos63
chevy only
Dinos63's Avatar
buddy awsum start!! and it looks like you have some great help and great skills
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-01-2013, 01:22 PM   #46
Bomp
Bomp's Avatar
Its not cheap but you sure make it look good.
Old 01-05-2014, 08:35 PM   #47
HOT WRECKS
HOT WRECKS's Avatar
Ok lets get project ''HOT WRECK'' up to date.
rear frame rails leveled, squared, and welded. but still far from complete.
Name:  62 c30 023.jpg
Here's the D/S front spring hanger.Hard to believe this repair was on a welding truck
Name:  truck stuff 012.jpg
I wanted to raise the spring hangers up 2'' so I laid out two lines 2'' apart on my work surface and lined up the top of the hangers the first line and marked the second line onto my hangers and made my cuts there.
Name:  more 63 003.jpg
Name:  more 63 002.jpg
Squared up the frame to the hoist on which I have already have the 115'' WB marked out. marked the frame for the axle centre line, then measured from there forward and back for the attaching points of the spring hangers (I recorded these measurements before I took disassemble the original hangers)
Name:  62 c30 029.jpg
Old 01-05-2014, 08:49 PM   #48
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Subscribed! Gonna be a cool build!!!
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 01-05-2014, 09:22 PM   #49
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
K I'm watchin
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 01-05-2014, 09:37 PM   #50
flashed
Im in on this one .
flashed is offline   Reply With Quote
